Question about Samsung DVD-VR357
Volume not working
I have a Samsung Plasma TV and a Samsung DVD player. I used to have surround sound so I would turn the volume on from the receiver. I don't have surround sound anymore but now I don't have volume coming out my TV when I use the DVD player.
Can you help??
  • katherineh Mar 05, 2009
    ok, I will try that, will be asking again if it doesn't work. Can that be the only problem?
  • 463 Answers
Make sure you have patch cables hooked up from the audio out of the dvd player to audio IN of the Television, using the same named input (Video 1, 2, Fnt, Bck, Aux) that you used for the video in.
Posted on Mar 05, 2009
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
I have background sound on my TEAC HTX1800 DVD player, but I can't hear the people talking. Please help?! Regards /Hester
Chances are you are playing movies coded for Dolby Digital Surround. Depending on what kind of receiver your DVD player is plugged into, the receiver may not have the Center channel operating or turned up. Most all dialog comes from the center channel of a surround sound system. The receiver usually has a separate output for a center channel speaker, and a separate volume control as well. This will adjust the dialog volume up.
If you are not using a receiver, or plugged directly into the TV, check the audio settings on the TV. They may not be set up for the surround, hence why you are missing the dialog. Good Luck
Feb 21, 2011 | Audio Players & Recorders
I have a dvd surround sound and LCD TV both Samsung. The surround sound has no input for coloured cable connection Can I use a HDMI cable from the dvd surround sound unit to the TV to make the TV work as...
Yes, and no. You can connect the HDMI cable from the DVD player to your television for audio and video, but you will not get true surround sound as designed by dolby or dts.
Dec 12, 2009 | Onkyo HTR500 Receiver
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Nov 20, 2008 | RCA RTD155 System
We have recently just bought a samsung htx250r home cinema. we have a 50 inch samsung plasma, the dvd player sound works using the hdmi cable but the surround sound does not work when we are watching...
Salutations ddog,
Really this is a question of sources. The reason your able to hear surround sound when connected to your DVD player is that is what is providing your audio and video source. When your watching television it would depend on how your getting your broadcasts. If you are either receiving an over-the-air broadcast or cable directly to your set, your television becomes the source. As your television is providing the signal, you would need it to loop back to your receiver to provide that surround sound.
Now for the good news, if you have a cable or satellite box these should have outputs to connect to your receiver to provide the audio source.
Also keep in mind not all broadcasts provide a version of surround sound. Most newer home theater systems will replicate surround sound artificially.
I hope this helps.
Jon
Go Ahead. Use Us.
Jul 05, 2008 | JBL SCS200.7 Home Cinema Package System
No audio on my samsung FPT5084
cHECK IF THE VOLUME IS IN THE MUTE STATUS TRY TO CHECK THE CONTROL
Jun 06, 2008 | Samsung FPT5084 50 in. Plasma HDTV
Samsung surround sound wont connect up properly to samasung plasma tv
i have a plasma samsung 42 inch and i dont know how to connect my jacks red,white, yellow from the dvd to the plasma and what channel should the plasma be on to see the dvd ???? thanks anthony
Mar 28, 2008 | Samsung HT-Q100 System
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
How to get sound through speakers with tv and not just dvds
Just wire your TV audio out to one of the receivers (DVD player) audio in and select AUX when you want the TV sound to play through the surround sound. You also might want to turn the volume down or off on your TV to get the full surround sound feeling, but that's your call.
Jan 06, 2008 | NexxTech ESDVD100 System
Samsung DVD-VR357 Logo
170 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
