Hi - I need to replace the fuse on my Sansui Q-55 and wanted to check to make sure which was the proper replacement fuse - is it 1 A? Thanks, Mark
  • 120 Answers
The old fuse you take out should be marked,just put the same kind in.
Posted on Mar 08, 2009
Cost to replace plasma on Sansui 42 inch TV
Hi Richard,
An original Sansui stand could be expensive try to find a universal stand to suit your TV here are some that should accommodate your TV: MISC STAND 3755BB 37 55 Lcd led plasma Stand
Jan 24, 2016 | Sansui Televison & Video
Kitchenaid microwave no power
Open up and replace fuse. Also check to make sure that the door safety switch is closing and working properly. If both are good you may have a bad magnetron (tube).
Go to site for parts Search Over 2 1 Million Appliance Parts
Aug 25, 2017 | Cars & Trucks
No power
If your television has no power, try the following:
1. Check the power cord for breaks, tears, or exposed wires .
2. Check to be sure that the power cable is fully inserted in the outlet and that the outlet is working.
3. Go to your fuse box or circuit breaker box and check the fuse or circuit breaker of the circuit your TV is plugged into. Replace the fuse or reset the breaker if necessary.
4. Replace the batteries in the remote control, and then try turning on the TV using the remote.
5. Unplug the TV, wait five minutes, plug the TV back in, and then try turning on the TV.
If the recommendations above do not resolve your problem, most likely the power supply in your TV has failed and your television needs service.
Thank you !!
Jun 04, 2010 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
Sansui AU-7500 volume control problem - need replacement
Hi...
Is that the fancy pot with more than 6 leads..kinda square looking?
This place has some.
http://angela.com/
Rate my help if this helps...Thanks
Mar 11, 2010 | Audio Players & Recorders
Strandby power indicator flashes 6 times repeatedly
According to the symptom the problem is of thermal fuse which needs replacement, the part number is given below:
1-910-006-44
The method to change it, is given below:
1-Remove rear cover
2-Remove sub-woofer speaker box
3-Remove metal backing plate
4-Remove Exhaust fan
5-Remove Optical block screws
6-Remove Open thermal Fuse
7-Install new Thermal Fuse
8-Reassembly Connection & Wire-dress.
Act according to the instruction and it will solve the problem.
Thanks
Nov 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Model TDC2075A Sansui Had lightning storm, lost power no close lightning strike. TV will not power up, don't know if it has internal protection or is power supply went out
you mite try replacing the ac fuse 1 time-if it blows again there is a short in the power supply-i would then check rectifiers in the primary of the power supply-then check the fet-if any of them are shorted replace them
Sep 04, 2009 | Sansui CDVD1900 19" TV/DVD Combo
The tv shut off and will not turn back on.
1. you may have a bad fuse inside, or a poped capcitor witch caused the fuse to go.
2. Check you outlet unplug your tv and replug it back in.
9/times out of 10 its a fuse or bad cap inside that needs a simple replacment.
Thanks and please rate.
Aug 21, 2009 | LG 55LH90 55 in. LCD HDTV
13" sansui AC/DC 12 volt use
Did you check the fuse inside the plug on the 12volt cord?
Feb 01, 2009 | Sansui COM312AD 13" TV/VCR Combo
 Grubhead
Grubhead
