Question about Gateway 310S (2900621) PC Desktop
Disk dirve not being read.
I have two disk dirve in a Gateway Model 310S. It did read both but now wont read either one of them. One is a DVD burner and the other is a DVD drive.
What is there I can do to fix the problem? Is there a wiring diagram to where I can see if them are hooked up right?
  • 3 more comments
  • tazman052186 Mar 05, 2009
    A new drive was put in by someone elas and before that is read now it wont read any of the two.
    A DVD drive was installed. But Im not sure if the drive was new or not. Because before the one was installed it was reading that there was a Local D in the My Computer file. Now there isnt any there. The is just Local C and a Floppy. Under My Computer file.
  • pixelpowered May 11, 2010
    Either the dvd-drive is not jumpered correctly (there is physical jumpers that tell the drive how to react on the cable) or the device is not getting power from the power supply (there should be a 4 pinned molex going in the rightside of the drive). A good diagram step process for looking into this to emphasise this: http://compreviews.about.com/od/tutorial...
    I started the link at step 4 because step 5 shows what a power cable is looks like.
    Unfortunately you will have open the computer to view all this. If you have a camera to take a picture of the setup it would be great. You might also have to consider asking the person who installed the drive to assist in opening it.
    Most likely the installation of the new drive (was it a new DVD or HDD drive?) was not jumpered correctly. Please note what was installed and what is installed currently in the machine. Manfacturers of the drives will allow a better guide on a proper diagram for installation.
  • Jeremy Husby
    Jeremy Husby May 11, 2010
    Would there be a reason they would not be hooked up right?
    Problem Solver:
  • 19 Answers
I agree, it's either not jumpered correctly or the IDE cable isn't seated all the way. May have been partially pulled loose from the MoBo when the new drive was installed...
Posted on Mar 06, 2009
Dvd recorder in commputer wont read any discs
is the light on?can u put disk in it?if answer is yes,then check the lens of dirve.maybe it is need to clean.
Aug 09, 2010 | Computers & Internet
Why my DVD burner does not read JVC empty DVDs?
If your DVD burner does not read a disk you should try a few other disk, if it still does not read any disk you should check the connections to make sure no cabe is slack or loose.If the problem still exist please got to the manufacturer website and download drivers for you DVD burner you should also go to www.cnet.com and download and install codec for your DVD burner.
Jun 13, 2010 | LG GSA-2166D DVD RW Dual Layer Burner
Wont recognize burned disk
Is the burned disk recognized in some other computer?
Is any "official" (purchased music CD, or purchased DVD video, or purchased Microsoft software) disk recognized when inserted into the device?
If you burn a disk on your computer, can your computer then read that burned disk?
May 29, 2010 | Toshiba PA3761U-1DV2 DVD-RAM Burner
Just bought a new DVD burner, its a LG Super Multi DVD ReWriter 22x (Gh22LS40) I also had to buy a sata to IDE converter for my motherboard that has only IDE connectors on it. I can not get Windows 7 to...
ok here's what you need to do.....
first check your dvd burner if its is detected properly on your cmos. If it is located properly try to re install windows 7 again i've encountered this problem before and i just reinstalled windows 7 and it worked like charm.
If the dvd burner is not detected on cmos try to check the jumper settings for both hard disk and dvd burner one orf the other should not be on the same setting ex. if your disk drive is on master you should set the dvd on slave and vice versa. then redo the first step. hope this helps
Jan 11, 2010 | Gateway GT5220 PC Desktop
My LG GWA 4146b wont read any disk i put in, just
is it for a particular disk or all??
assuming for 'all' and with all data cables n jumpers r sitted correctly....
if u r a professional, open it up, with the lens assembly there is a small preset, turn it using a screw driver a little anti-clockwise..clean the lens with clean cotton using isopropyl alcohol..
if not done, replace the lens assembly..
or else, replace the drive with a standby n see..
..contact ur System Admin/Vendor....
Oct 27, 2009 | LG GWA-4164B DVD±RW Burner
My dvd drive wont read disc
It is probably due to the scratches on the disk that makes it unreadable. It can also be the reading lens is dirty of it wont reach reach the surface of the disk.
Sep 29, 2009 | Samsung SH-W162 Burner
My cd/dvd burner stop working it won't read
Try cleaning the laser lens with alcohol and a Q-tip. If this does not work then the burner is tired.
Aug 11, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
My dvd burner wont read or recognize a copyed disk is in drive
My Optorite DD0405 will not burn a DVD+R DL disk? is this because its not supported by the burner? I have Nero 9 and would like to burn 4.8 GB of a file from my desk top to a DVD DL with 8.5 GB space. How can I do this
Thank You
Dec 03, 2008 | Optorite (dd0405) DVD±RW Burner
Cd drive
You must take out the hard disk of your laptop and attach it to any other working laptop to take the back up of your files like picture,video..Just contact any technical person in your area to get the hard disk out and attach it to any other laptop.........
Jul 21, 2008 | Gateway 310S (2900621) PC Desktop
Gateway 310S (2900621) PC Desktop Logo
57 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
