Question about Zebra LP 2844 Thermal Printer
Tags are not printing centered
My tags are printing off to one side and I don't knwo how to realign the printer. Anyone know how?
    Problem Solver:
  • 7 Answers
This printer should be self centering. Make sure roll is on holder and guides are set or call Andrew @ 908-725-1699
Posted on May 08, 2009
Printer printed 5 tags but there is wrinkles in the tags so i tried to realign the ribbon and now it will not print
Ribbon wrinkles are due to:
- Ribbon too large.
- Print Head misaligned.
- To much heat.
- innapropriate Transfer film.
check with your tag dealer
Apr 24, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
I know there is a set of bar codes you can scan on the NCR 7875
Yes sir, I think NCR refers to them as "hex tags" but anyways one of the hex tags is labeled "Diagnostic" I think that is the one that will tell you the current settings. I found the tags on the manual for a different model (pages 282-296 on the pdf in the first link). After you get the tags printed from this link just use the manual for 7875 (second link) model to know what sequence to scan these tags good luck! http://ncrpr.ncr.com/web/rsdmkt/dealerReady/docs/User_Guides/HighPer_Scanner-User-Guide.pdf
https://docs.symbol.com/manuals/3765801a.pdf
Apr 03, 2010 | NCR 7875
Just one of the double tags is printed on
I assume by double tags you mean 2 labels across the roll.
You need to tell your software that the roll is 2 across.
If using the software that comes with the printer, Zebra designer.
Set your label width to twice the single label and copy the barcode so that you have 2 across the label, then print
Feb 10, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Dell 1320c prints black as light grey. Tonor cartridge is new . Tonor saver setting is NOT on.
This isn\'t a fault with the printer, IT IS A FAULT WITH THE WAY IT HAS BEEN SET UP! The problem is, not all of the tabs have been removed from the PHD unit inside. In order to remove these, you need to open the front cover of
the printer, move the four tabs 90 degrees and pull the whole PHD out.
You will then see the four yellow tags on the side.
Having printed with the tags in means the PHD has been potentially
damaged. If you\'re lucky, you\'ll get away with removing the tags now and
it will return to normal after about 50 pages, it not then you\'ll need a
new PHD. The reason the problem manifests itself with black first is
because the black is the most commonly used colour.
For info on removing all the tags, see here:
http://support.euro.dell.com/support/edocs/systems/prn1320c/en/ug/1320c_en/section04.htm#1055182
Feb 04, 2010 | Dell 1320c Laser Printer
The 'eye' won't read the space between the labels,
recalibrate the sensors and check your label lengths and gap size
Mar 31, 2009 | Toshiba TEC B-472 Thermal Label Printer
Printer problem
I called CAM Commerce Solutions, the retail POS software we use, and they were able to fix my problem. I was missing another component of the print program that only CAM Commerce has.
Dec 17, 2008 | Zebra Eltron TLP 2742 Thermal Label...
Zebra TLP2844 Prints Centered and Half the Width
create a word template document with the page size the same size as the label. Set the margins to 0 and fill the label up with text. This should make the printer print right the way over the bale.
Nov 21, 2007 | Zebra Eltron TLP 2844 Thermal Label...
Zebra LP 2844 Thermal Printer Logo
369 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
