Question about IBM ThinkPad T21 Notebook
Starting ibm 600e
I have an ibm thinkpad 600e. and can,t get it to start. it does different things like error 163 can anyone help
  • IBM Master
  • 19,396 Answers
Error 163 is date not set.
When you get a set of errors like 163, 192 and 161 (invalid date and time and invalid cmos settings) , and the thinkpad not starting, that means that the cmos battery is completely drained and must be replaced.
The Cmos battery is located on the lower side of the motherboard, and can be accessed from the memory compartment.
You can order the battery at a local reseller, or buy it on Ebay for a small fee.
See the guides below on how to replace the CMOS battery.
Replacing CMOS battery on IBM Think
Replacing a CMOS battery on a IBM ThinkPad 600
Thinkpad 600e - CMOS battery replacement
eBay Guides - CMOS Backup Battery Replacement IBM Thinkpad 600
how to mend it .com - thinkpad 600 error 161 163
Posted on Mar 05, 2009
  • IBM Master
  • 4,806 Answers
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
I have ibm 600e 2645...error 161 and 163....Replaced my bois battery and still get the same error. I reset the clock and I still get back to the OFF and ON site which leaves me nowhere
after the error you need put the right date and hourly push ok later hold the button to off - turn on if the problem continued is a motherboard problem
Mar 18, 2010 | IBM ThinkPad 600E 2645 Notebook
Error 163 173 ibm 600e laptop when turned on these errors occur
this error is the battery by the sound of things, you need to replace the cmos battery , then enter the configuation utlity and set date and time, hope this helps
Nov 29, 2009 | IBM ThinkPad 600E 2645 Notebook
Error 161 and 163
The ThinkPad 600E is at least 5 years old? If so, have you changed a RTC Battery (CMOS Back-up Battery) 3V Button cell type that goes somewhere inside the Laptop and sits on the System/Motherboard. I hope you put it back the right way polarity is critical. If not then i have no idea to what it is, though someone will be able to help also you might want to try http://www.computing.net/answers/hardware/ibm-thinkpad-bios-error-code/ good luck, Bastian
Jun 03, 2009 | IBM ThinkPad 600E 2645 Notebook
Starting ibm thinkpad
Errors 161 and 163 mean the time and date are not set in the CMOS. This typically means the CMOS backup battery is dead / going dead.
Mar 05, 2009 | IBM ThinkPad T21 Notebook
Error message
the bios battery is dead and your machine is losing the date and time when u shut it down. you can get one on ebay for about 3 bux
Oct 05, 2008 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
Error codes for ibm thinkpad 600E
Your bios battery needs replacing
http://www.bioscentral.com/misc/ibmdiag.htm
Hope that fixes it for you? :)
Jan 06, 2008 | IBM ThinkPad 600E 2645 Notebook
Thinkpad 600E
IBM Thinkpad error code 19990301 is a Hard-Disk sector problem. Basically your hard-drive is faulty and you need to replace it. This is why it wont boot; because the area of the hard-drive that stores data is damaged.
Sep 20, 2007 | IBM ThinkPad 600E 2645 Notebook
My ibm s showing a certain error no. on startup
Without seeing the error, you may be best just typing the number into Google.
Feb 20, 2007 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad T21 Notebook Logo
664 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
