Question about Philips HTS3544/37 Theater System
Paper stucked in the dvd tray.
My son inserted a paper in the dvd tray. It opens but when I try to use it it can't read the disc. How can I take out the tray? I need to look for the paper inside.
  • 463 Answers
You must take the "lid" of the main unit itself, and remove any boards and/or circuitry that are blocking your access to the tray. usually there's not a lot in there coveing the tray.
Disonnect the unit from the mains before removing the lid, of course.
Posted on Mar 05, 2009
Panasonic BTT268 tray wont open
Dear Scott,
If there is a CD stuck inside a CD/DVD reader, you could try using a medium sized paper clip straightened up. Insert it in the small hole in the front of the DVD player bezel and push it till it opens the mechanism. Please, have a look at: http://www.youtube.com/watch?v=fa_4CsS7MKw
The problem can also be caused if one of the rubber band that moves the DVD drive "door" has dried out, or even if the power supply in not properly connected to the drive.
Hope you may find this info hopeful!
Best regards,
Miguel Luiz Martins
Nov 19, 2013 | Kenwood DV-605 Multi-disc DVD Player
How to get a dvd tray unstuck
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
May 19, 2013 | Televison & Video
My dvd will not eject from my e drive
You can manually eject the disc by straightening a paper clip and insert it into a small hole just below the disc tray. Gently push the paper clip into this hole and the disc tray will unlock and pop out. You can now pull the disc tray until the tray is fully opened and this will allow you to remove the DVD disc.
Sep 16, 2011 | Acer (KV.16X04.007) DVD Drive
Hello, my otiplex Gx620 cd/dvd drive will not eject the cd it in. Is there any way of releasing it ? many thanks hannah x
Hi and welcome to fixya!
Just follow these few steps and it should fix the problem (but if the problem keeps on happening, it maybe time to change the ODD).
    • 1 Locate the optical drive that contains your stuck disk. You'll see a small hole on or immediately below the disk tray.
    • 2 Straighten the paper clip.
    • 3 Insert the straight end of the paper clip in the hole and push. You should feel it catch inside the latch mechanism.
    • 4 Pull the paper clip out gently. The disk tray will come with it.
    • 5 Remove the CD or DVD and close the tray.
Read more: How to Eject a Stuck DVD/CD Drive ' eHow.com http://www.ehow.com/how_2324439_eject-stuck-dvdcd-drive.html#ixzz1RJn98iTa
Jul 06, 2011 | Dell for Optiplex GX620 CD-RW/DVD-ROM...
Disc draw will not open
Manually eject the disc tray
  1. Disconnect the power cord and any other cables connected to the console.
  2. Uncoil a paper clip.
  3. Position the console horizontally, as you would position a DVD player.
  4. Find the yellow sticker behind the vents on the left side of the console.
  5. Insert the straight end of the paper clip into the eject hole which is located just above the yellow sticker (as shown in the picture below).
  6. The disc tray should pop out slightly. Pull the tray out the rest of the way with your fingers.
Note If a disc is in the tray, make sure that it is not sticky and does not have a label that might prevent the tray from opening again in the future.
If you cannot get the disc tray to open, please see the following article: 906936 The disc drive of your Xbox 360 console does not open
uparrow.gifBack to the top Original Xbox 360 console: How to manually eject the disc trayFirst you need to remove your console's faceplate. Here's how:
  1. Unplug the power and A/V cables from the back of your console.
  2. Position your console horizontally, as you would position a DVD player.
  3. While holding your console firmly, push the faceplate away from the console with your thumbs.
    Note You will need to use some force to remove the faceplate.
  1. Uncoil a paper clip.
  2. If your console has holes below the right side of the disc drive, insert the straight end of the paper clip into the hole as shown in the picture below.
    If your console does not have the holes pictured below, skip to step 5.
  3. Push the paper clip until you feel some resistance (approximately 1" or 2.5 cm into the hole).
  4. If you're successful, the disc tray will pop out slightly. Pull the tray out the rest of the way with your fingers and skip to step 9. If the disc tray does not open, try the next step.
  5. Find the two holes below the left side of the disc drive, and insert the paper clip into the first hole on the left.
  6. Push the paper clip until you feel some resistance (approximately 1" or 2.5 cm into the hole).
    Note Make sure you are pushing the gear mechanism and not the metal plate.
  7. If you're successful, the disc tray will pop out slightly. Pull the tray out the rest of the way with your fingers and skip to step 9.
  8. If the disc drive is still stuck closed, insert the paper clip into the adjacent hole (to the right) and push again. If you're successful, the disc tray will pop out slightly.
  9. Now plug the power cord into the back of the console. Press the eject button to open and close disc drive. If the disc drive works properly, reattach the console faceplate.
If you cannot get the disc drive to open, please see the following article: 906936 The disc drive of your Xbox 360 console does not open
uparrow.gifBack to the top Xbox SupportPlease visit the following website for information about how to contact Xbox Support: support.xbox.com/pages/contact-us.aspx
Apr 09, 2011 | Microsoft Xbox 360 Console
DVD disc stuck?Press Eject, door won't open. disc spins up loads, then flashes fail
Find a paper clip. Unbend the outside piece of wire so you have a 1 inch or so pice sticking out.
On the front of the DVD, look for a hole about the size of the paper clip. Stick the long piece you bent out into the hole and push slowly but firmly until the tray just barely pops out. Slowly pull the tray the rest of the way out and remove the disc.
I've seen this caused by putting a second dvd/cd on top of one already in the tray, actually fairly common when you cant see the dvd drive tray from the top.
Aug 29, 2010 | Computers & Internet
Will not eject DVD is working is stuck I think I might need to open laptop
Power down the laptop and restart it. As soon as it restarts press the open button on the dvd drive and it will open. You may have to try a few times but it will work.
Sep 29, 2009 | Dell Studio 1737 Laptop
Jammed tray
try checking the tray for something that jams the tray.
May 27, 2009 | Yamaha DV-C6660 Multi-disc DVD Player
DVD/CD tray will not load
With the R800, you must slightly open the paper feed panel door, lift it vertically about an inch and then lay it open horizontally away from the printer. Without doing this, there is no way to insert the disc tray.
Mar 13, 2009 | Epson Stylus Photo R800 InkJet Printer
CD drine issue
To manually open the CD Drive, straighten a paper clip and insert it into a tiny hole in the front of your CD drive and push the paper clip gently into the drive and the tray should then pop open.
Open and close this several times, then insert a disc into the drive and see if it will read the disc.
If not the drive is dead and needs to be replaced.
Nov 18, 2008 | Acer (KV.16X04.007) DVD Drive
Philips HTS3544/37 Theater System Logo
87 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
