Question about Nintendo Wii Console
I have a modified wii...not homebrew..i still managed to play back up games. i just wanted to know how to prevent the firmware from updating from the games only?I'm just scared that when inserting a new game with update it get updated and my wii gone forever!! Please help..
  • 21 Answers
Hi -- That can easily be avoided by either removing the update partition before burning using WiiBrickBlocker or just launch your games with any loader. All of the newer Loaders will automatically bypass the update partition so that the game cannot update your Wii on it's own.
http://www.wiilovemario.com/The-most-up-to-date-Wii-Homebrew-and-Backup-tutorials-known-to-mankind
Posted on Dec 28, 2009
  • 434 Answers
Read up on the chip you bought. Some of them, like the Wiikey, have built in update protection. So even if you click on update, it will not pass through the chip. Hope this helps...
Posted on Oct 07, 2009
My wii is semi-bricked?
Wat is your wii version On YouTube type in homebrew channel thn your wii version there should be som links in the descriptions download them the put the file boot.elf or boot.dol and private then put in your wii if you have version 4.0 or higher click the blue ad card at the bottem of your screen it will load up thn run then install homebrew channel and DVD x leave boot mii alone click exit put your sd carad back in your computer and create a folder called apps then go to wiibrew.org and serch homebrew browser downlad it and put it in the apps folder then put back in your wii and load up homebrew channel and there your done Hope this helps Bye
Jul 09, 2010 | Nintendo Wii Console
Tip
Wii - How to SoftMod, Guide.
This post will explain How to SoftMod Nintendo Wii on any firmware, Region and make its Homebrew enabler for play Wii games, backup, Homebrew applications on your wii, And all without needing a wii modchip!
Requirements: A SD card, (1GB should be enough for Installer and Backup), formatted to FAT32. Some SD card is not compatible to be used to backup the wii nand, but its work for use as boot2 of bootmii, so you might be need 2 different memory, for installation and nand backup.
Download: All files can be found **Here..!
*SD Card Pack
*cIOS38_rev14-Installer
*IOS60 Patched.
*Trucha Bug Restorer
*WAD Manager v1.4
*AnyRegion_Changer_v1_1b
*AnyTitleDeleterDB
*Backup Launcher WBKL
*Firmware Updater v4.1 -299Kb. (Need Wi-Fi connections).
*preloader v0.29 -214Kb. (OPTIONAL).
Installation Procedure:Adding Files.
  1. Extract ‘SD Card Pack’ and copy all contents to the root of SD Card, and copy a second of ‘IOS38-64-v3610.wad’ to ‘wad’ folder - ‘SD:/wad/’.
  2. Extract ‘cIOS38 rev14 Installer’, ‘Trucha Bug Restorer’, ‘WAD Manager’, ‘Any Region Changer’, and ‘Any Title Deleter’, into ‘apps’ folder - ‘SD:/apps/’.
  3. Extract ‘IOS60 Patched’ and ‘Backup Launcher WBKL’ into ‘wad’ folder - ‘SD:/wad/’
  4. Preloader is also an optional install, if you don't want it just skip.. Extract ‘Preloader’ into ‘apps’ folder. ‘SD:/apps/’.
  5. Extract ‘Firmware Updater v4.1’ into ‘apps’ folder. ‘SD:/apps/’. This updater require wi-fi connection, If you want to use offline updater, you will need wad updater (*.wad) and put its into ‘wad’ folder. IMPORTANT!! Make sure you have select the right one for your region..! E=Europe, J=Japan, U=USA, if you use a firmware from a different region, it will BRICK your Wii.!
Install BootMii & Homevrew Channel.Homevrew Channel is a channel on your wii menu that will allow you to put applications (homebrew) on your sd card and put them on your wii, this may include emulators, games, and installers.
Insert the SD card into Wii. then, Go to ‘Wii Options’ > ‘Data Management’ > ‘Channels’ > ‘SD Card’, then you will get a message saying ‘Load boot.elf?’, select ‘Yes’ and the Hackmii installer will run.
Press ‘A’ to continue, Install the ‘Homebrew Channel’ (HBC), and follow the on screen instructions. When done, the HBC will appear on wii channel.. Now go back and install ‘Bootmii’ as ‘boot2’ (recommended), if you can't install it, try different SD card. When it done, reboot your wii with it SD card, and wii will load into BootMii menu..
Backup Wii NandMaking a NAND Backup with Bootmii is highly recommended, it will recover your Wii from bricks. make sure there is at least 530MB free on SD Card.
Boot Wii into BootMii menu, if bootmii is installed as an IOS, go to the Homebrew Channel, press ‘home’ on your Wiimote then select ‘Launch Bootmii’.
Readmore...
on Aug 28, 2009 | Sony PlayStation Portable (PSP) Console
How do i modify the Wii console?
Install the Homebrew Channel (softmod) is extremely easy these days. A lot has happened since the softmod came out and it takes about 10mins to install now. It's completely safe. Here's a great up-2-date guide on doing everything to your Wii:
Dec 01, 2009 | Nintendo Wii Console
Wii not starting up!
  1. Buy or rent a new Wii game that is made by Nintendo and intended for use in your region
  2. Step 2 Turn on the Wii, insert the game and let it load.
  3. Step 3 Wait as the firmware checker in the video game checks that the Wii's firmware needs to be updated. If this does not happen, it means no firmware checker is on the disc and another game will have to be obtained to try it again.
  4. Step 4 Follow the directions presented onscreen when the firmware checker has finished checking. The firmware will now be updated.
  5. Step 5 Eject the video game disc when the update is done and restart the Wii.
  6. Pray
Aug 21, 2009 | Nintendo Wii Console
Is there a way to downgrade the nintendo wii firmware from the maintenance screen
I don't think you can unless you format the system (this will delete ALL information including game saves). I personally have never done that so it might not work. Why would you want to delete the firmware though? If it's for Homebrew the last time I checked you could still homebrew on the latest update.
Jul 27, 2009 | Nintendo Wii Console
Downgrade wii from 4.0 to 3.4 or lower
The Following Steps assume you have the Homebrew Channel:
STEP 1- Load Wad Manager from the Homebrew Channel (hbc) and install
"iosinstaller.wad"
STEP 2- Load Custom Wad Manager from hbc and install "cios-fix.wad"
STEP 3- Load IOS Downgrader from hbc. Follow all directions until it tells you
that it has been completed. **KEEP IN MIND that this is different from
"cIOS Downgrader"!**
STEP 4- Load cIOS Downgrader from hbc **KEEP IN MIND that this is
different from "IOS Downgrader"!**
-L@@K---> MAKE SURE YOU PICK YOUR CORRECT REGION <---L@@K
-For example: 3.2U= USA/Canada; 3.2E= Europe; 3.2J=Japan
-OPTIONAL: You may choose another system firmware other than 3.2
if you want. My intention is to help guide you to downgrade to 3.2.
Remember that System Menu 3.2 is considered the 'ideal' firmware
for homebrew (if not all) to work properly.
STEP 5- (You may skip this if you wish) At this point you should be on System
Menu 3.2 (or other firmware). You may check your Wii settings to see
for yourself.
~~Again if your NOT in System Menu 3.2 you will not be able to do Step 6~~
STEP 6- Load Starfall from hbc. After reading the discalimer you will be
instructed to press B+1 instead of B+2. Press B+1 to continue on to
the next screen.
-As of version 0.5 Starfall has 8 options/patches to the Wii in which
you can install. The last 3 are the most important ones. Some people
just install everything which is fine.
-STARFALL comes with these options (the ones in red are the important ones):
~Replace healthwarning with back menu
~Region free GC games with video mode patch
~Region free Wii Games
~Region free channels
~No Mainmenu BGM (Background Music)
~Start rescue-menu when Y is held on 1st GC controller (Usefull for
recovering bricks)
~Remove rescue-menu diagnostic disc check
~Skip disc update check
~~~~~~~~~~~~~~~~~Complete~~~~~~~~~~~~~~~~~
Congratulations you have successfully downgraded your Wii along with
a rescue menu if have accidently bricked your Wii.
Apr 14, 2009 | Nintendo Wii Console
Hacked Wii have something to do with guitar + drums not syncing?
TWILIGTH OR WATHEVER THE NAME IS XD MESS UP YOUR WII TRY HACKING IT AGAIN WHIT THE BOMBARD OR SOMETHING LIKE THAT I HAD THE SAME PROB. SEARCH FOR IT IN HERE WIIBREW.ORG OHH AN SOME NICE HOMEBREWS XD
Feb 25, 2009 | Nintendo Rock Band for Wii
Help!!
U NEED TO GET AN NEW MEMORY STICK
Nov 06, 2008 | Sony PlayStation Portable (PSP) Console
PSP
The game you have on your memory card is an image file (an illegal copy) and it would have been running under modified firmware such as Homebrew.
Now that you have upgraded and gone back to official SONY firmware you will be unable to play this game as SONY do not support illegal files.
Apr 01, 2008 | Sony PlayStation Portable (PSP) Console
Nintendo Wii Console Logo
104 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
