Question about Science & Laboratory
Stage slowly falls causing unfocus
I have a Carlsan single occular compound microscope. The course and fine adjustment knobs raise or lower the stage to focus. Lately once I have my slide in focus and I let go of the adjustment knob the stage level begins to slowly decend thus unfocusing the image. As this is happening I can see the course adjustment knob slowly spin. The ends of the fine adjustment knobs have heads that look like they could be adjusted with a flathead screwdriver but the ends of the course adjustment knobs have no such head. It seems like I need to get some more tension between the knobs and the track that they move on. I appreciate any help.
Try holding the Right knob so it does not move, whilst firmly moving the Left knob towards you (clockwise), this is the adjusting method used on Zeiss Jena 1960's High End microscopes, e.g Eduaval & Ergaval.
Good luck,
Alan Mowle
Posted on Mar 20, 2009
Why does the mechanical stage for my microscope keep falling to the bottom-most position?
Maybe there is some wear at the thread where the stage fits, causing that the stage cannot hold.
Mar 19, 2016 | Nikon Labophot trinocular Microscope...
The stage is not moving when the focussing Knobs are moved. The stage moves freely vertically. It's not attached, I'm sure it needs to be re aligned and a screw need tightening, but which screws?
Hi Faye , we will probably need more info
Does the stage move freely on its own without the course focus knobs
Can you move the stage up and down with either of the course focus knobs
Instrument details / picture would help .
Oct 07, 2015 | Science & Laboratory
After focusing it drifts out of focus. The knobs do not stay in the same place
There is a tension adjustment just inside the coarse focus knob. (same side as the switch) It looks like a chrome ring with 2 or 3 holes in it. You may have an odd looking tool that came with your microscope that is used to make this adjustment. Tighten it just a bit until the stage stops falling. You don't want it too tight or it will begin to make it difficult to adjust your coarse focus.
Dec 01, 2010 | National Optical 131 Monocular Microscope
The stage slides down on its own and the view gets out of focus.
Just inside the coarse focus knob you will see a "chrome" ring with holes it it. That ring needs to be tightened just a bit. It will make the coarse focus knob stiffer so tighten only enough to stop the downward drift of the stage. A funny looking tool should have come with the scope. It is used to adjust this "tension" ring.
Oct 22, 2010 | Swift M2251C Monocular Microscope
The focus knobs drift
Oct 13, 2010 | National Optical 138-MS Monocular...
Why should the coarse focusing knob not be used when focusing with the higher-powered objective lenses
There are two reasons. One reason is that when on high power you are working so close to the glass slide that it is easy to misjudge how much you are moving the specimen toward the lens that you can break a slide before you realize it. The coarse focus moves the stage with the specimen on it very fast and you only have a very very short distance within the focus plane before you run the objective lens into the slide.
Secondly, it is just harder to control the minute adjustments needed at the higher powers with the "coarse" focus knob. If you start at the low magnifications find what you want to concentrate on with the coarse focus knobs and then work your way up to the higher powers, you will have very little trouble moving to the fine focus controls at 40x and 100x while still having control of your image.
Sep 17, 2010 | Zhumell LOMO P-111 modular brightfield...
Stage slides down after focusing
There is a tension adjustment for this. It is located on the coarse focus knob which is on the same side as the switch. It looks like a chrome ring with about 3 holes in it. A strange looking tool should have come with the scope. It is designed to fit into these holes and allow you to adjust the tension on the coarse focus knob. You need to tighten it just a little bit. Not too much or you will have trouble operating the coarse focus knobs smoothly.
Jul 08, 2010 | Swift M2251C Monocular Microscope
My microscope drfits out of focus, how can I fix this?
The problem is that the stage is heavy and the adjustment screws are loose. You need to tighten the coarse adjustment knob screws in order to create more friction so that the stage stays put. That, or don't adjust anything and keep holding on to the coarse adjustment while you're using it.
Nov 19, 2009 | Boreal WW3111900 Microscope
Microscopes
sir,
Diffrent company having their own system for microscope arm balacing.
Tell me which one microscope you have.
Auxillary arm or microscpe body sloly come down ward.
tell me problem is consult with which part..
INDRAVIJAY
Jan 02, 2008 | Tasco 750 Monocular Microscope
Science & Laboratory Logo
815 people viewed this question
Top Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
