Question about Hummingbird Exceed 10.0
Exceed not working on office network
My exceed is working when I am on my VPN network (accessing from home) but as soon as I come to office and login using WiFi/LAN it doesn't work. I am able to launch Exceed properly. But from my Unix when I set DISPLAY and then run the program nothing happens.
  • Anonymous Mar 17, 2009
    Installed Exceed Version 2007. COnfigure exceed for single monitor and xdmcpBroadcast. WHen I launch exceed the sceen goes to the system I want to run on but screen turns grey and doesn't work.
  • 45 Answers
Well, first, what is your internet connection bandwidth?
Most of the vpns drop the connections when the speed is not good enough, and that means your application won't work fine.
Also, when you use WiFi you can transmit upto 54megabits per second only (the wired network speed is 100MBPS), unless you have wifi N.
Anyway, first I would check the internet speed/bandwidth, test with a faster one, and if everything goes fine, then you know what the problem was :D.
Posted on Mar 19, 2009
I have 2 different magnia sg20 servers. One is in the office and the other one at home. Now I want to access one server from the other network. But as both of them have the same ip, I am blocked. So I...
No. You are on two different networks. Regardless of the hardware. Treat the home server just like any other PC or tablet. Make sure it has a dynamic IP via DHCP from your home router or ISP modem. Then connect via VPN.
You will not be able to network the two servers unless you have right equipment and network configuration. You would have to work with your service provider to obtain static IP's.
Internal IPs are irrelevant, because you can assign them your self internally. That means no one else sees them.
Mar 08, 2013 | Toshiba Magnia SG20 Server
Tip
VPN in Microsoft Server 2003
The full form of VPN is Virtual Private Network. VPN gives extremely secure connections between private networks linked through the Internet. It allows remote computers to act as though they were on the same secure, local network. Allows you to be at home and access your company's computers in the same way as if you were sitting at work.
Almost impossible for someone to tap or interfere with data in the VPN tunnel. If you have VPN client software on a laptop, you can connect to your company from anywhere in the world. VPN goes between a computer and a network (client-to-server), or a LAN and a network using two routers (server-to-server). Each end of the connection is a VPN "endpoint", the connection between them is a "VPN tunnel".
When one end is a client, it means that computer is running VPN client software. You can use a virtual private network (VPN) to connect components to one network by using another network. VPN do this by "tunneling" through the Internet or another public network. With a VPN, connections across the public network can transfer data by using the routing infrastructure of the Internet, but to the user, the data seems to travel over a dedicated private link.
A VPN gives you the benefit of a dial-up connection to a dial-up server, plus the flexibility of an Internet connection. Using an Internet connection you can connect to resources all over the world. If you have a high-speed Internet connection at your computer and at your office, you can communicate with your office at full Internet speed. This is much faster than any dial-up connection that uses an analog modem.
VPNs use authenticated links to make sure that only authorized users can connect to your network, and they use encryption to make sure that others cannot intercept and cannot use data over the Internet. A Tunneling Protocol is a technology that helps make the transfer of information over the Internet more secure from one computer to another.
VPN technology also permits a corporation to connect to its branch offices or to other companies over a public network, such as the Internet, while helping to maintain secure communications. The VPN connection across the Internet logically operates as a dedicated wide area network (WAN) link.
VPN in Windows 2003 Server: You need a high speed Internet connection to configure and run VPN server. Two individual lan card must be present in a single system where you want to configure a VPN Server. The lan cards should ping each other. Also need a User which's Dial in allow access should be enable. Microsoft 2003 server two tunnelling protocols for a secure VPN connection, one is PPTP (Point-to-Point Tunnelling Protocol) which Provides data encryption using Microsoft Point-to-Point Encryption. The other is L2TP (Layer Two Tunnelling Protocol) which Provides data encryption, authentication, and integrity using IPSec.
Steps to create VPN Server in 2003 Server: At first I go to Start and point to Administrative Tools, then click Routing and Remote Access. Then I click the server icon that matches the local server name in the left panel of the console. If the Routing and Remote Access service was previously turn on, you may want to reconfigure the server.
To reconfigure the server Right-click the server object, and then click Disable Routing and Remote Access. Click yes to continue when you are prompted with an informational message. Then Right-click the server icon and then click configure and Enable Routing and Remote Access to start the Routing and Remote Access Server Setup Wizard. After that click Remote access (dial-up or VPN) to turn on remote computers to dial in or connect to this network through the Internet. Then I have Click to select VPN. In the VPN Connection window I click the network interface (Lan) which is connected to the Internet and go the IP Address Assignment window, then I click Automatically because there was present a DHCP server in network. However, if DHCP is not available, you must specify a range of static addresses.
If you use from a specified range of addresses, open the Address Range Assignment dialog box and Type the first IP address in the range of addresses that you want to use in the Start IP address box. Type the last IP address in the range in the End IP address box. Windows calculates the number of addresses automatically. After that I have accept the default setting of No, use Routing and Remote Access to authenticate connection request and finally Click Finish to turn on the Routing and Remote Access service and to configure the server as a Remote Access server.
For the remote access server to forward traffic properly inside your network, you must configure it as a router with either static routes or routing protocols, so that all of the locations in the intranet are reachable from the remote access server. It also need for security purpose.<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Verdana','sans-serif
on Mar 22, 2011 | Microsoft Windows Server 2003 Enterprise...
Cisco 7942G IP phone works in home office but it does not work in remote location
Hi J,
Typically corporate use VPN for these kind of critical service access. Check with your IP Tele/Network admin and get VPN access or may be OfficeExtend or any other solution employed. Corporate don't expose their UC servers on internet w/o security.
HTH
-Karthik.
Oct 14, 2012 | Cisco 7942G IP Phone
My employer gave me a Dell 6400 Latitude Laptop to use at home through a VPN connection. I have a plug in connection at home. How do I hook up my laptop at home?
Connect your ethernet cable from your Broadband modem into your laptop. Make sure you can browse webpages. Open the VPN software installed by your employer, and enter your login credentials assigned by your employer to authenicate. Once connected, you will have Network Access and Intranet Connections to your workplace. This will work from WiFi hotspots, hotels, Internet cafes, etc. If you do not yet have your VPN software installed, or have your credentials, speak to your employer as they may need to create and account and a certificate for your VPN connection.
Nov 10, 2009 | Dell Inspiron 6400 Notebook
BSNL BROADBAND DOWNLOAD LIMIT EXCEEDS
This can happens when Automatic Updates Feature is Turn On. Your antivirus definitions updations. By using peer to peer softwares like bitcomet, bittorrent, Bitlord etc., These can work in bacground and downloads the updates and softwares and shares the resources of the downloads. By these the limit can exceed.
To reduce these risk factors
Change 250 Plan to 500 limited plan or 750 Home unlimited.
If not disable the autoupdates feature.
Hope this will be usefull
Thanks & Regards.
Nanda Kishore
Mar 10, 2009 | Sony VAIO FX150K Notebook
Private network > VPN > network firewll > priv net
Add a static route on the Sonicwall 2040 : 192.168.1.0/24 with the RV082 as gateway (the ip of the network shared between the RV082 and the Sonicwall)
Another solution is to enable NAT on RV082 for 192.168.1.0/24 network. Routing is preferable.
Feb 14, 2009 | Linksys RV082 10/100 8-Port VPN Router...
VPN connection timed out
please tell me that who is your ISP at home?
Oct 25, 2008 | Trendware 54Mbps 802.11g Wireless AP
Exchange server access problem.
If your cisco vpn client is behind the natted device then you need to allow nat traversal in the head office firewall and if you connect the vpn client through data card it will connect,
Aug 01, 2008 | D-Link NetDefend DFL-700 Firewall
Sort out my VPN issue
On my 4350, if I go Settings -- Connections -- Tasks, there's a task "Set up a new VPN connection," which will walk me through network IDs and authentication. I worry that that isn't there in WM2003SE, but have a look. As to your second question, one serious flaw to the current communications software is that there's no way to save multiple settings sets. So when you're home or go to a public hotspot you'll likely have to empty out all your office settings, then re-input them when you're back in the office. Good luck.
Sep 11, 2005 | HP iPAQ HX2750 Pocket PC
Hummingbird Exceed 10.0 Logo
1,129 people viewed this question
Top Hummingbird Computers & Internet Experts
Les Morrison
Les Morrison
Andrew Taylor
Andrew Taylor
Are you a Hummingbird Computer and Internet Expert? Answer questions, earn points and help others
