Question about Whirlpool ED2FHGX Side by Side Refrigerator
Where is the thermostat located on a whirpool refrigerator side by side
  • 163 Answers
Thermostat is in freezer behind back panel wall.the thermostat will be located at the top of coils.
Posted on Mar 05, 2009
Refrigerator whirpool is only working after tapping on the front control system panel? which part has to be replaced?
Whirlpool side by side fridges with the control panel across the fridge section have thermostats that will fail. Tapping on that control panel will cause the fridge to work temporarily. You will need to replace the refrigerator thermostat if you see small black specks under the thermostat.
Oct 21, 2016 | Whirpool Refrigerators
Freezer with excess frost despite temperature control at proper setting
This is a defrost issue, consisting of three components: Defrost Timer, Defrost Thermostat, and Defrost Heater. In older whirpool refrigerators it is almost always the Defrost Timer. You can easily replace this your self. Just send your model number and I can direct you through your repair. You can order the part you need at, Reliable Parts
Thanks, Repairman45
Dec 19, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I have a new whirpool side by side seems to run all the time. is this normal
Ask the dealer, check the thermostat inside has not been turned up excessively also. check that the door/s are closing properly after it's been restocked etc'.
Oct 02, 2009 | Refrigerators
I have an older Whirpool fridge it isn t cooling
does the motor run if not change the thermostat but if it runs the gas level are low in the system
Jun 16, 2009 | Refrigerators
Ice and water don't work
This could be several reasons, water valve on back not working, thermostat in ice tray not working, heating element below ice maker not working, we just need to start with the dual water valve on back first. The side that feeds the ice maker needs the solenoid checked. I am ready to help you solve this, Let me know, Thanks, Sea Breeze
Apr 16, 2009 | Refrigerators
Whirpool gold
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
WHIRPOOL ED2
Not enough model to get the wire diagram. It sounds like a diode is out in the water valve harness. If it is using the triple valve on that unit.
May 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ED2FHGX Side by Side Refrigerator Logo
207 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
