Question about Philips 47PFL3603D LCD TV
TV in black and white
I just purchased this TV...got it hooked up, but there is no color.
I have sound & a black and white picture. I don't know if it's hooked up wrong or not. Help please!
    Problem Solver:
  • 5 Answers
I did the same thing... the wiring is hooked up wrong...If you are not using HD then use the side hookup...Probably a better way but it worked for me..
Posted on May 29, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Trying to hook up digital converter box but cant get reception
This seems related to the TUNER and the IF section as the sound- audio and picture- Y signal does not process with the correct alignment.
Dec 06, 2011 | Audiovox VE727 7 in. Under Cabinet TV
I have hooked up all the wires to corresponding color. we have a picture, sound. but it is in black and white.
Check the wire connections again.Change the color system of the TV.In order to change the color system use TV remote.Set the color system to Auto
Jun 14, 2011 | Televison & Video
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
Just purchased Sony Blueray from Costco and all movies are showing in black and white-went through menu and cannot figure out how to change to play in color.
What video cables are you using?
It sounds like you have you component video cables hooked up improperly. If you are using the Blue Green Red connectors for video make sure they match those on the TV. If you have the Yellow plugged into the green or vice versa you will get a black and white picture.
Let me know if this helps,
Cheers!
Jan 20, 2010 | Sony BDP-S350 Blu-Ray Player
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
No color
Please set your TV on Auto Color system to get colors on VHS and DVD.
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Black and white picture
you have the cables hooked up the wrong way
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Same as other poster: Player only plays black and white
It sounds like the circuitry which actuates the color drives for the screen are not working, this would ba analogous to adjusting for a B&W picture on a color TV you have color but the screen shows black and white. I would get a schematic for this set and measure the voltages on the color processor that connects to the screen since you know that the external jack has color. If possible I can help you troubleshoot this, if you need me to help out.
Aug 19, 2007 | Durabrand PDV-705 Portable DVD Player
Color
Have you tried to hook up a DVD player or any other source? If so does the color come back? If not then I recommend you call for warranty service if the set is in warranty, sounds like the vidoe processors are bad on the main board
Feb 18, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Philips 47PFL3603D LCD TV Logo
239 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
