Question about Refrigerators
Hose comes off back of the refrigerator going into ice maker
When water comes into ice maker the white hose comes off and water goes to floor.
  • 163 Answers
You have a clog.you need to remove ice between hose going in to freezer and where water comes thru to ice maker
Posted on Mar 05, 2009
I have a great model # tpx24srya-bs refrigerator and when the icemaker is on it leaks water from I don't know where. When Ice makers off there's no leak.
There is a solenoid valve and a plastic water hose that connects to the ice maker. Looking at the rear of the unit you can see where the plastic tubing connects from behind the air shield into the solenoid. A second hose connects from the solenoid to the water inlet connection on the wall. The connection to the wall is probably OK because it would leak with the ice maker off if it did,
It is the hose that goes up from the solenoid through a hole at the upper right top that is the most likely culprit.
Look for water coming from a failed hose at or near the solenoid valve connection where the ambient heat is the highest. It is the heat of the hot air that deteriorates the hose. Replace the hose.
After ten years many are known to fail?
"Protect floor before rolling filled refrigerator out from the wall!" The weight will scar the floor from the wheels including hardwood floors!!"
Hope this helps?
Nov 07, 2016 | Refrigerators
Ice maker/ water dispencer "locked"
have whirlpool ice and water waterand ice will not come come out--right no ice wil come push the ice have ice ill not go back to water
Sep 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Ice maker doesn't work. How do I check to see if it's the actual icemaker or the water inlet valve?
go behind the fridge where the water comes into it. the hose should go into a valve. if you have water and ice in door. there will be two hoses coming out the other side. what I did was find the hose that goes up to the ice maker and unhook it and there was no water coming out while it was trying to make ice. that valve is replaceable and are even on ebay. on mine the water worked in the front door, but ice maker did not. I think the valve is common problem.
Mar 28, 2011 | Whirlpool ED2GHEXN Side by Side...
Have a Whirlpool ED20PK unit and the ice maker hasn't been working however the water fountain has. I moved the unit out today a few feet but did not stretch the water supply hose. Now it is leaking water...
Feed tube to ice maker may be frozen. This can cause water line going up back of unit to come loose from the pressure created by blockage. If it is frozen, thaw it and replace water valve.
Nov 18, 2017 | Refrigerators
Water not comeing in ice maker
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Aug 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Maytag MZD2766GES Side by Side...
Water in door but no ice?
there is no pump, just water psi from your house.
check inlet valve to ice maker/water float
Sep 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Frigidaire frig ice maker line leak
Could you put a small circular hose clamp on the hose line?
Apr 23, 2017 | Refrigerators
Leaking water
Dear Elizabeth,
please rate this following solution if it mends ur needs,else choose fixya.
please perform the following checks,
Water on floor outside of freezer
Water inside the freezer
  • Check for a clogged drain tube
  • If you have an ice-maker, check freezer and ice-maker for level
please rate this following solution if it mends ur needs,else choose fixya.Thank you.
Dec 17, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Dripping water from a ge fridge with a ice and water dispenser. why is the water spout dripping?
hello ghreay..
do u've Water on floor outside of refrigerator? plz do the follwing..
do u've Water inside the refrigerator? plz do the follwing..
  • Clean the drain tube
  • If you have an ice-maker, check refrigerator and ice-maker for level.
thank you for using fixya..
Sep 27, 2008 | GE Refrigerators
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
