Question about Bunn A10 Coffee Maker
Our Bunn A10 Coffe Maker has no brew timer on the left side. How can we adjust the coffe maker so that we can get a full pot?
  • 125 Answers
Hello. I need to know if you have an automatic unit, or a pourover. The pourover will not have a timer at all. The difference is you have to pour the water in to get coffee out, an automatic would be connected to a water line, and you just push a start button. If it is an automatic unit, there has to be a timer somewhere to adjust the amount. Here is a web address that has your manual, and a parts breakdown should you need to find where the timer is located.
Hope that helped, and thank you.
Posted on Mar 15, 2009
My bunn 10 coffe maker just died
not brew if no water coming in to filll the tank
Jul 11, 2014 | Bunn GRX-B
I can program or not and just brew. The coffee maker will change the clock time, how many hours the pot stays on (2-4) and just shut off automatically for no reason. Any help would be appreciated. ...
the coffe make is on a sencer timer built in coffe make for securty reasons its shots off after so many min. they built them that way so just in case someone forgets to turn off coffe maker and no ones home and burnes the place down.
Feb 24, 2011 | Cuisinart DCC-1200 Coffee Maker
The coffe pot will not produce full pot of coffee it only produces 1/3 then stops i cked water supply that is fine when restart it will only produce another small portion so it is three or four times for...
Check programming.This is very simple;turn switch on and hold brew switch until you here 3 clicks to start brew timer .When desired level is reached turn off on/off switch on front panel to set brew time.Check brew level now.
Jan 24, 2011 | Bunn CDBCF 15 APS Coffee Maker
What can I clean my Bunn proffessional coffee maker with ?
mcdevito75 here, Contact Bunn for their recommended cleaning material for your coffee maker, or see any large store that carries coffee makers for their cleaning kits.
Jul 11, 2010 | Bunn VPR Coffee Maker
Bunn omatic won't make full pot-even with water line hooked up
Use the dial with numbers on it and adjust to a higher number. Remember to go in half steps such as 2 adjusted to 2 1/2, 3 adjust to 3 1/2 etc.
If you only have a High Low knob, that is to set your water temp.
If you have an electronic circuit board, you will need to follow the batch instructions pasted on the inside cover (facing the lower burner) to adjust for water level/batch. This cover has 4 screws.
Sep 08, 2009 | Bunn VPR Coffee Maker
Water leak on a Bunn coffee maker model B8W, leak only when brewing a pot of coffee
Where is the leak coming from? If it is from the back of the unit or the bottom then it is cracked and you will just need to replace the coffee maker. If it is leaking from the top then it is a seal issue in the water valve that brings the water from the tank and into the coffe filter and into the pot.
Apr 26, 2009 | Refrigerators
Water over filling pot
There is a brew timer on the left side of your machine near the heater switch. you need to remove an access panel to access it. turn this down a little, let the water heat up, then try another brew. Adjust as needed, brewing another pot between each setting.
Jan 07, 2009 | Bunn-O-Matic Coffee Brewer GRW8
I just received my cuisinart coffe maker DCC1200 and I wanted to brew a pot of coffe but I am unable to open the glass carafe to obtain my coffe filters. Is there a specific way to open this? Your...
Hmm. Better late than never. Just got home with ours. Same problem. Called Cuisinart 800 number. Catch is on top of handle. There is a slight lip on each side there. Pop it up with pressure on both sides simultaneously. To replace, line up lid carefully with top of carafe and press firmly until it pops back on.
Jun 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Hamilton beach coffee maker Model 49464
Leave the carafe off the hot plate and place the basket in holder with the lip under hinged flange so it sits flat. Then replace the carafe and the basket should not move up when the Pause and Serve button opens. I just bought this pot too and
love it but except for the basket placement problem.
Feb 18, 2008 | Coffee Makers & Espresso Machines
Bunn A10 Coffee Maker Logo
207 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
