Question about HP Photosmart C6180 All-In-One InkJet Printer
HP photosmart C6180 - printer shut down problem
I was trying to scan a document and had an error so I went to shut the printer down and re-boot and it's now stuck in "shutting down" mode...
  • moonstarr132 Mar 28, 2009
    I was printing and realized I was printing the wrong thing. Naturally I hit "cancel" on the printer and it just froze. I hit the power button to rebooot it and now it's stuck in shutting down mode.
5 Suggested Answers
sagarjd
  • 95 Answers
SOURCE: HP C6180 ''Unable to scan, copy or send a fax''
Check the following steps:
Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord
Try to check the result.
Regards,
Sagarjd
Posted on Nov 21, 2008
  • 2692 Answers
SOURCE: Scan error with HP Photosmart C4480
Link to your documentation:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us〈=en&product=3418705&
Posted on Mar 05, 2009
SOURCE: HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Posted on May 11, 2009
  • 67 Answers
SOURCE: How do I scan a document from HP Photosmart?
Follow thes below steps to scan to PC and save it without using HP software.
WIndows XP:
1. === Scanning with Paint: ===
1. Click the Start (Windows) icon.
2. Click All Programs.
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
Windows Vista:
1.Click the Start (Windows) icon.
3. Click Windows Photo Gallery.
4. Click File and then click Import From Scanner or Camera.
5. Click Import.
6. Click Scan.
Posted on Oct 07, 2009
  • 100 Answers
SOURCE: HP Photosmart C6180 turns off and on repeatedly
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fix stopped my printer from power cycling and also fixed the ink system failures the Printer was having.74b7f9c.jpg
I ordered parts from mouser.com, but DigiKey.com may have better prices. I ordered 3 of these and 1 of these
Posted on Sep 28, 2010
How can i fix my C6180 HP photosmart computer with msg of improper shutdown from wall switch
Try what they call a hard boot. In other words completely power down ththe printer by either removing the power cord or shutting down via the power button. If this does not work try to enter the menu and clear the arror code manually. Hope this helps.
Sep 08, 2012 | HP Photosmart C6180 All-In-One InkJet...
What can I do to fix this problem? HP Photosmart
hi
to solve this issue, write down everything you see oin your computer and/or the printer control panel. send it to me and i will investigate further to help solve the issue.
go to this link and review the instructions (1st link)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01369982&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=1153494
if this deosnt solve issue go to the second link below, and review related soltions.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=27286&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=1153494
please rate my solution
Nov 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
My printer don’t start its boot up program. Haw do upgrade, reparation or install new these?
HP Photosmart C6180 All-In-One InkJet Printer driver download
Download and install the printer's driver.
Restart computer.
This is the link for other usefull tools for your printer .click here
Thanks for choosing FixYa
Oct 11, 2010 | HP Photosmart C6180 All-In-One InkJet...
I get a line through my scan with my hp photosmart C6180, What can I do?
If it is a vertical line, you could review the HP support documentation for your Photosmart C6180 here:
HP Vertical Lines Bands Streaks
For horizontal lines, try using the HP "toolbox" to clean the print heads. You may need to repeat this process until you achieve a satisfactory result.
Dec 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Wireless HP 6180 PhotoSmart All in ONe will not scan document to my computer
Well its the issue with the printer drivers taking a dynamic ip address.all you need to do is uninstall the printer network drivers,insert the s/w cd that came with the printer and then click on add a device ,it would install the printer drivers all over again.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
May 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 won't scan to word or document viewer etc etc
the save as function is in the print/scan manager, not the software..you'll need to point it to where you want it to save, and also what format
May 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
334 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
