Question about Kenmore Washing Machines
Ty for being here. I have a kenmore stack washer
Ty for being here. I have a kenmore stack washer dryer. Washer is a model 417.94802 301. The hot water feed work fine comming into the machine. However the cold feed only comes in at a trickle. I disconted the cold hose from back of machine. Turned on the cold water valve. Thier is plenty of hot water comming to the machine. Checked the wire filter inside the the feed where the cold water hose attaches to machine. it was clean, no plugs. I tried to take out the adapter where the hot and cold go into the machine. no luck without takeing the back off the machine.
Is it possible somewhere inside my machine from where the cold water feeds in and where it dumps into the wash machine tub i have a plug? How can I check this? Got a plug somewhere.
  • Kenmore Master
  • 19,396 Answers
Inside the machine you have a valve called inlet.
The inlet water valve will collect the cold and hot water lines, and open alternatively one or the other during cycle.
To access the inlet valve you need to take apart the machine, and that is not an easy task.
If you DIY remember to unplug power, there is high voltage running inside your appliance.
Below the inlet valve for your model:
1014350
Posted on Mar 05, 2009
SOURCE:
Can stacked washer dryer be separated?
no that's a one peace stacked washer,dryer
Nov 27, 2017 | Kenmore Dryers
Kenmore stacked washer-dryer 41794802301 dryer wont start
dryer working washer not for a kenmore 41794802301 washer dryer combo
Apr 18, 2010 | Kenmore Dryers
My stacking kenmore washer dryer will only run hot water.
That would be a problem with your water inlet valve. Before checking that make sure the screens in the hose is clear and when you disconnect it from the washer there is a screen inside the valve. Here is a video on checking the water inlet valve. Different unit but procedure is the same. www.appliancehelponline.com/servicemanual.html
Mar 03, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore washer model no.4174102000 that has broken and was advised it cannot be fixed. I have a Kenmore stackable dryer model no.41781042000 and am being told by Sears that I have to buy a new...
a stack unit is a very risky investment, altho it's understandable if you have limited space. if the hold downs on the washer are rusted out or broken thru you need to have someone weld them for you. That's how we used to do it where I worked but stacks are not usually easily worked on. I'm afraid you will probably have to get an entirely new unit or maybe a used one from a reputable used appl. dealer in your area. Check around, you might get lucky and find one relatively inexpensive
Aug 24, 2009 | Kenmore Washing Machines
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Where is the model #on my Kenmore stacked unit?
possible locations
Top- or front-loading washer-dryer combination unit
  • Inside the dryer door, on the door frame
  • On the top of the dryer
  • On the side of the washer, near the bottom, front
  • Under the washer lid
  • Feb 13, 2009 | Kenmore Washing Machines
    Kenmore model 98702
    No - it is one body. it cannot be replaced - only repaired.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Oct 05, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Dryer door
    I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
    Aug 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
    No rinse
    Make sure that you have both, hot and cold water connected and turned on. Some models will not advance through rinse if one of the hot or cold is off. See if this solves the problem, Catriver.
    Jul 21, 2006 | Kenmore 80754 Top Load Stacked Washer /...
    Washing Machines Logo
    130 people viewed this question
    fordexpert
    Kristen Denison
    Kristen Denison
    Level 1 Expert
    Jim Chinnery
    Jim Chinnery
    Level 1 Expert
