Question about Gateway GT5014 PC Desktop
GT5014 won't boot
I have power going to the computer the light (green) below the inlet is lit. The power button on the front and the operation light blink quickly when I hold the power button in. But nothing happens. Nothing
  • 749 Answers
Generally this means there is a problem with the power suppy as it is not giving a correct voltage to the motherboard to start the computer. check your fans on the power supply, make sure they start when you try to start the computer . A power suppy may be purchased and installed fairly easy. and you should spend no more than 50 dollars on the parts.
Posted on Mar 05, 2009
  • Jeff Strader
    Jeff Strader Mar 05, 2009
    Please post here again if you need help installing it
Dell Latitude 6500- the power button lights up when plugged in and keyboard will light up but nothing else happens. The machine has a weak battery so I operate it without the battery plugged in.
First of all, you need the battery for a lot of the computer functions to operate. The wrong time and date can really cause problems for your computer. Replace the battery. Have your motherboard checked. Also, run setup when your computer starts to boot to make sure your system settings are correct.
Sep 15, 2014 | Dell LATITUDE Computers & Internet
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
My unit indicates a system error due to amber LED was lit whenever I press the power button. I tried to press the remind button in the operator panel but no LED will lit to indicate what maybe the problem....
Interesting, sound like a failure of the button because most system either work with a greeg lit up led or fail with an amber or orange lit or flashing.
In this instance the amber could mean something has gone bad but the fact you can hold the button and have it boot up is strange.
Does the led turn green after holding the button for a while to let the machine boot?
regards,
mike
Oct 19, 2012 | IBM System x3500 (7977F2U) Server
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
My computer won't start, it appears to have no power. For the past 2 weeks when ever I would start up it up I would have to constantly push the start button 3 to 5 times till it would power up. Now it...
Most likley you have a fried power supply. Try this first unplug the computer from the power cord for 5 minutes then plug back in and go into safe mode see how to go into safe mode below.
To start the computer in safe mode 1.
You should print these instructions before continuing. They will not be available after you shut your computer down in step 2.
2.
Click Start and then click Shut Down.
3.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
4.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
5.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
6.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Chris Thrash
B52computers
Please Vote
Jan 10, 2011 | Gateway GT5014 PC Desktop
Cant use
Try this steps Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jul 07, 2009 | Office Equipment & Supplies
Ink absorber full Canon MP210
(11/24)
<Service mode operation procedures>
(11/24)
button pressing
1 time Orange Service pattern print See APPENDIX 1:
SHIPMENT INSPECTION
PATTERN 1: PRINT
SAMPLE
2 times Green EEPROM print See APPENDIX 2:
EEPROM INFORMATION
PRINT
procedures below.
procedures below.
(12/24)
<Destination setting procedures>
At Logic board replacement, make settings for each destination.
button pressing
LED Destination Paper for defaulte setting
0 time Green No change
1 time Orange Japan A4
2 times Green Korea A4
3 times Orange US/Canada Letter
4 times Green Europe A4
5 times Orange Australia A4
6 or more times Returns to a menu selection A4
<Waste ink counter reset procedures>
At the waste ink absorber replacement, reset the waste ink counter for the replaced waste ink absorber.
Setting operation for the waste ink counter (The counter setting value is selected by pressing the Reset button.)
The number of the Reset button
pressing
LED
0 time Green Reset the main waste ink counter to 0%.
1 time Orange Reset the platen waste ink counter to 0%.
2 times Green Reset the Main & platen waste ink counter to 0%. (Reset
collectively.)
<Button / LCD checking operation procedures>
At Operation panel unit replacement, check the button / LCD.
1. When pressing the Stop button two times, the machine will be moved into an LED confirmation mode.
2. As often as the Color button is pressed one time, each LED is lit one by one, and the machine get in the mode in which each
button is acceptable.
3. As often as each buttons on the panel is pressed from the left to the right, the displayed number is counted up.
Pressed button Display
Maintenance 1
Fit to Page 2
SCAN 3
Paper size 4
+ 5
Black 6
Color 7
Stop / Reset 8
On / Off 9
4. When all buttons are pressed, [1] will be displayed. Then, LED[8.5 x 11 Plain Paper] and LED[8.5 x 11 Photo Paper] will be lit on
the panel, and the machine will be in a service mode menu selection mode.
May 20, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Gateway GT5014 will not boot.
Ok, this is a mother board issue. the entire mother board seems to be malfunctioning. the blinking amber/green light is confirming this. the mother board may have some fried circuitry and it will have to be replaced in this situation.
I would recommend extracting the mother board and stripping it. look for any discoloring factors that will lead to a burn out location. this will direct you to the necessary repair zone.
Please rate and have a great day:)
May 13, 2009 | Gateway GT5014 PC Desktop
Dell 4600c will not power up -- green power button lit -
i think it may not power supply problem.it may be ram memory problem.try this,remove your ram and clean it with cloth and restore back.
Dec 16, 2008 | Dell Dimension 4600 PC Desktop
Service Error with my cannon printer 160
TRY THIS STEPS...
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
Oct 24, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Gateway GT5014 PC Desktop Logo
131 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
