Question about Whirlpool 24 in. GU3200XTPS Stainless Steel Built-in Dishwasher
The upper rack doesn't not appear to get all the dishes clean. Why does this happen?
  • 188 Answers
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to because the door will be open, but if you feel more comfortable shutting off the power to the dishwasher, do so.
Posted on Mar 05, 2009
  • 105 Answers
SOURCE: dishes not washing clean
check water level in machine
may be not filling enough and the wash pump is starved from water thus not pushing water to upper arm
drain water from machine dismantle and clean out air tube to pressure switch take off air tube at pressure switch and blow back into sump then pinch air tube with fingers to stop air from flowing back up tube then refit to p/s
run and see if that solves problem
Posted on Feb 24, 2008
aborcass
  • 2651 Answers
SOURCE: broken nozzle and upper spray arm
the spray arm just screws back on, unless of course its cracked in which case needs replacing( chances are since it fell off its cracked) heres the part num 154478202
Posted on Mar 15, 2008
aborcass
  • 2651 Answers
SOURCE: Upper Rack not cleaning
id try removing hte lower filter plate . 5 torx 15 screws will gain oyou acess to lower sump and 2 more torx screws that will acess you the chopper assy, prhaps filled with debris not allowing good water flow,
Posted on Mar 25, 2008
  • 161 Answers
SOURCE: upper rack dishes dirty
Is it filling with enough water. Look or if you don't know how much water is supposed to be there , Just add a gallon of hot water to the machine after it fills. If this solves the problem check the filter in the fill valve or replace the valve.
Posted on Jul 05, 2008
SOURCE: Not cleaning upper rack
You'll need to clean the food chopper in the base. Make sure you've got a torx screwdriver.
http://forum.appliancepartspros.com/dishwasher-repair/8174-kitchen-aid-dishwasher-wont-clean-top-rack-items.html
Posted on Nov 06, 2008
Glasses do not come clean in the upper rack but do in the lower. Is there someplace that should be cleaned out to make the upper rack work again
Not knowing what dish washer you have I would check on the sprayer make sure it turns or is not blocked in any way. If the water can't spray up you will not get clean dishes.
Apr 28, 2017 | Dishwashers
Top dish rack dishes don't get clean model 8575637
Most dishwashers have a rotating spray bar underneath the upper rack. Over time bits of food can clog up the holes and then dishes won't get clean in the upper rack. Check to make sure all the holes in the spray bar are clear and that it is rotating freely.
Mar 22, 2017 | Dishwashers
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
Mar 15, 2012 | Kenmore Dishwashers
GLD5900N00WW
You need to remove the top wash arm and check for any blockages in the holes, clean them out and make sure the arm spins freely.
Mar 06, 2012 | Dishwashers
MY DISHWASHER DOES NOT APPEAR TO BE CLEANING MY DISHES
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 11, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Top rack dishes not getting clean
Hey- Two things could be wrong.- clog, or bad motor. Sump screen needs to be cleaned of debris. Removal of sump cover to access screen requires torx bits and some patience. Replacement of pump requires pulling out dishwasher to access bottom. Motors fail when seal between motor and pump fails. Will still operate, but become weaker over time. Parts available- motor about 100$ at appliance parts pros.appliancepartspros. Hopes this helps- Thanks- ED
Feb 26, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Nov 13, 2009 | KitchenAid Dishwashers
Whirlpool GU3200XTP dishwasher - No spray on upper rack
Sounds like the hose assembly that attaches to the rear of the upper rack has come undone. just pull out the upper rack and reconnect it.
please rate my answer as a fixya! thanks.
Feb 14, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Open Questions:
Whirlpool 24 in. GU3200XTPS Stainless Steel Built-in Dishwasher Logo
227 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
