Question about Crosley CDE6000 Electric Dryer
Dryer is shuting down after twenty minutes cycle time, seems to be overheating.I haved cleaned the vent.
  • 163 Answers
Sounds like motor is going bad.eventually it wont start all you will hear is a humm from motor
Posted on Mar 05, 2009
Dryer seems to be overheating within 3 minutes of turning on. No lint in trap or outside in the trap. What else could I check??
may want to check inside the housing, u may have had a lint build up somehow? Ur cycling thermostat or thermal cut off may be going haywire on you and u should check them with a multi-meter. for continuity. is it overheating and shutting off? If so u may have bad motor windings which will heat up rapidly then shut down the machine? but they usually will atleast let u run it about 20 minutes b4 shutting down
Dec 27, 2014 | Dryers
The dryer shut off mid-cycle. It smelled overheated.
Hi
Your thermostat is shutting you off on mid-cycle because your overheating the dryer...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me thumbs up.
Sep 18, 2011 | Maytag PYE2300AY Electric Dryer
The gas dryer heats then does not heat. The sensor says 99 minutes to dry close. Tried it on timed heat and it dries then stops drying. Sometimes shutting off completely!
Hello,Cheack to make sure your venting is clean and clear..If its blocked the safty thermostat will shut the heat down to prevent overheating.. If the vent is clean i would check the coils.When they start to fail it will heat then not cycle back on..
Jun 18, 2011 | Maytag Neptune MDG5500AW Gas Dryer
About 12 to 20 minutes into the drying cycle, the dryer stops and all of the led lights start flashing (drying, cool down, press saver, clean lint filter". Also, the dryer doesn't seem to get warm,...
sounds like a restriction in the venting process, i would first disconnect the vent tube and run the dryer, if that clears the problem then I would clean out the vent tube. If not then I would take apart dryer and clean out all of the lint. Hope this helps Tim
Nov 26, 2010 | Dryers
I have a ge profile gas dryer. It never seems to get hot enough to dry clothes the first cycle. Even if it's an hour and twenty minutes long. Any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 19, 2010 | GE Dryers
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
Dryer runs a few minutes then shuts off, after sevearl minutes, you can turn it back on, then shuts down again, any suggetions
it's overheating,you could have a bad motor or the dryer just needs to be cleaned out,when was the last time you cleaned it out? try disconnecting the vent line from the back of dryer and run it for a while,you should see a difference but you'll still need to clean out the duct that the lint filter slides into unplug the dryer first,vac out the inside of dryer where the motor is and if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean out the vent line,just make sure the outside vent isn't blocked with anything because if it is the vent line can pop.you should clean the dryer once a year,your clothes will dey on time,less parts will go on you and you won't have to worry about dryer fires
Apr 16, 2010 | Hotpoint NBXR463EBWW Electric Dryer
Dryer takes 4-5 hours todry clothes dryer seems hot just not drying
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Dec 08, 2009 | GE Dryers
Not heating properly, many cycles to dry loads
Check the following to address this issue--
1. Venting
2. Thermostat
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Crosley CDE6000 Electric Dryer Logo
71 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
