Question about Samsung HL-S5086W 50" HDTV
TV Turning off shows 3 blinking leds and got worse over time
The TV started shutting down after 20 minutes about 3 months ago. The problem got worse over time and today the TV will shut down after 3-4 minutes. The lamp goes off first, after 1 or 2 seconds also the audio goes off and the 3 lights in the front of the TV start blinking simultaneously. There was also a very slight grinding noise which
suggested a potential problem with the fans or with the color wheel. Based on these symptoms I succesfully replaced the following parts: fans, lamp and color wheel. After each replacement the symptoms did not change (except that I do not have the grinding noise anymore), the TV will function perfectly for 3-4 minutes and then shut down and show the blinking lights in the front.
This TV set had a very short life (the service menu reports 4100 hours) and I believe that every part that could be replaced within reason with the symptoms described has been already replaced. I checked also the termostat on the lamp and the switch when you open the back panel to replace the lamp. All works well. After so much effort I am ready to give up, what am I missing and is there any hope that I can fix this TV without spending a fortune in more parts?
  • 3 more comments
  • iloromero Mar 07, 2009
    I changed the ballast as advised. It did not work. I keep getting the 3 blinking lights
    Yes I had checked the wheel, (air bearing not ball bearing) and it was the same as the one I replaced so I did not change any jumper.
    Yes I followed the procedures and diagrams in the links provided. What exactly do you mean by reset procedure? Is it something you do from the service menu of do you mean a hard reset (i.e. leave the TV unplugged from power for several hours)?
    I did a hard reset, I also reset the service lamp hours from the service menu. At first all seems to work fine but then I get the 3 usual blinking lights. The only change after the recent replacement of the ballast is that now the TV turns off after a longer time (10-12 minutes instead of 3-4 minutes but I guess it will get worse over time).
    The fans are the first thing I replaced, both are working fine and I did not set the TV to shut down. So to recap I replaced both fans, then the lamp, then the color wheel, the the ballast and I still get the TV to shut down and give me the 3 blinking lights. The only difference after I replaced the ballast today is that now the TV shuts down after 10-12 minutes instead of 3-4 minutes (but when I started having this problem the TV was shutting down and blinking after 20 minutes and got worse over time).
    Top Expert:
  • Samsung Master
  • 77,544 Answers
The shut down is caused by excessive current draw, most likely by a hi voltage circuit board that has a transformer on it, the transformer field windings may be shorted.
Posted on Mar 07, 2009
    Master:
  • 404 Answers
I think the fans are not doing enough cooling so the tv overheats and that's why its shutting down. otherwise it could be just as simple as settings, you accidently set it to standby or shutdown after 3 minutes. check the menu.
    Sergeant:
  • 320 Answers
After replacing each part there is reset procedure to be done other wise it will not work aS i assume you have replaced bulb,colourwheel and ballast but not done reset procedure after replacing each.as reset procedure should help
how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
  • 10,594 Answers
Please replace Ballast power supply in TV. It is power supply to Lamp.
It is available in www.partstore.com
Posted on Mar 05, 2009
  • Samsung Master
  • 19,396 Answers
3 blinks is a light issue, you meay need to replace the lamp.
  • 1 more comment
  • Ginko
    Ginko Mar 05, 2009
    If you already replace the lamp, and the color wheel, then there must be some stupid problem that keeps the TV on protection mode with 3 blinks.
  • Ginko
    Ginko Mar 05, 2009
    Test the ballast board, as already suggested, but also check the color wheel assembly, some color wheel has a jumper that must be set in position depending on what chassis is mounting.
    Also check the lamp cage door is closing well , many models have a sensor in there.
  • Ginko
    Ginko Mar 05, 2009
    The ballast board is the small AC high voltage board that powers the lamp, you test it reading the voltages out, carefult that there is AC power in there, do this test only if you are a qualified technician, reading voltages with power on must not be done by home users.
    The board also has a resistor that blows.
    If it is the board you have no power to lamp and no light.
    If you have light check the lamp installation and color wheel assembly.
    As usual there are also a couple of weird faults on main board that can give you 3 blinks and it is not lamp, but to test Jungle and protection IC in there you will need the service manual.
T.V shuts off and power light blinks.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 21, 2017 | Sharp LC-32SB23U 32 in. LCD TV
Shuts down after 5 minutes blinks green
Once the set shuts down, wait for the unit to stop blinking. Once it stops hold in the input and menu buttons for 5 seconds. The TV will then give you an error code. A 6-1 or a 1-8 error code would indicate a bad Color wheel. Which I think is the problem you have.
Jun 19, 2012 | Mitsubishi WD-65735 Television
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Stalling coming on
LG's are known for having bad capacitors in the power supply. These components will cause all kinds of problems like not turning on, no backlight or no video and are known to do this after the TV has been off for a few hours or days. You will need service on this TV.
Jun 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Sony KDF-60WF655 plays for 1 minute and then shuts down
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
My Panansonic TV shuts down every few minutes and the LED blinks three times
I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
regards
Oct 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Anoying
My mom and dad had this problem, after replacing the bulb everything is working great again.
Jan 25, 2008 | Hitachi 50VG825 50 in. LCD HDTV
Tv shutting off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Dec 02, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Open Questions:
Samsung HL-S5086W 50" HDTV Logo
110 people viewed this question
Henry  Thomas
Henry Thomas
