Question about Thermal Engineering Corporation I-Tec 150 Watt Power Inverter
Run a CPAP on a power inverter
Is the I-TEC 150 power inverter modified sine wave?
  • 608 Answers
I would not do this, you really need a pure sine wave inverter to guarantee the safety of your CPAP machine. At the price they are selling this device it could not be pure sine wave. 150W pure sine wave would be $70-$100.
Posted on Mar 23, 2010
I'm trying to run a 750 watt whirlpool compact microwave with a 2500 watt Cobra inverter. The microwave runs normally, but it won't heat. If I plug it in at my house it heats fine. I'm stumped. I load...
I assume your not using a pure sine wave inverter. A lot of electronic devices won't work on a lower cost inverter (modified sine wave) that has a square sine wave, either invest in a true sine wave inverter or don't run sensitive electronic equipment, I'm somewhat surprised you didn't damage the circuit board in the microwave...Below is a link of a inverter that would work if you want to spend the money for one.
2500W 5000 Watt Power Inverter Pure Sine Wave 12V dc 110V 120V ac LCD...
Feb 05, 2018 | Electronics - Others
Tip
WHAT IS A POWER INVERTER?
A power inverter is an electronic device that converts electricityfrom one form to another. Power inverters have become more popularrecently as the technology has become more efficient and much moreaffordable.
The most popular use for a power inverter isconverting battery electricity into mains electricity. For exampleconverting your car batteries' 12 volts DC into mains electricity 240Volt AC (Australia) or 110 Volt AC (USA).
WHAT POWER INVERTERS WILL HELP YOU DO
  1. Power inverters enablemains operated electrical equipment to be used even where there is nomains outlets, like in your car, caravan or even on your boat!
  2. Powerinverters bring creature comforts from home when you go camping orcaravaning allowing you to use your TV, fridge or electric shaver infact most of the normal mains powered conveniences from the home.
  3. You can charge your laptop in the car even if it doesn't happen tohave a 12 volt adapter. In fact a power inverter can be a very handygadget just to have in your car for those times you need to use a mainspowered appliance while you're away from a power socket.
WHAT TO LOOK FOR WHEN BUYING A POWER INVERTER
Apartfrom looking for a good quality well priced product there are a coupleof important elements to consider when selecting your power inverter:
HOW MUCH POWER IS ENOUGH ?
Powerinverters come in a range of power capacities so selecting the rightone for you is very important. Your power inverter needs to be able toprovide sufficient power for the equipment you want to use it with.
Here is a brief check list:
  1. Check the power consumption for the device you want to power
  2. Allow an additional 20% free board
  3. Add the power for all the devices you want to run at the same time
Note also that devices with induction electric motors like an power saw mayrequire 3 to 7 times the operating power when they start.
Usingan under-powered power inverter may damage it or the appliance you aretrying to use, so be sure to check the specific wattage requirementsand operating instructions for appliances / tools to be used.
PURE SINE WAVE INVERTERS
Normal mains power is known as Alternating Current (AC) and is a sine wave shape like the black line in the drawing below
Pure sine wave (black) versus modified sine wave (red)
Atypical power inverter produces a 'modified sine wave output' like thered line in the drawing above. While this works for most appliances,light dimmers, variable speed drills, sewing machine speed controls,some laser printers etc. will not operate correctly with a modifiedsine wave power inverter.
Pure sine wave power inverters areespecially designed to provide a more accurate sine wave output and socan be used with these appliances, but unfortunately they are moreexpensive.
Check with your with appliance manufacturer or itsspecifications to confirm if you can use a conventional power inverteror will need a pure sine wave inverter.
WARRANTY
One of thegreat things about electronic equipment is there is no moving parts(although there is a fan in some models) so you can expect a longserviceable life from a power inverter.
STANDARDS
Powerinverters generate dangerous mains voltages so ensure the product youchoose is approved for use with your mains voltage and supplier.
Powerinverters can also generate electro-magnetic radiation that caninterfere with other electronic equipment such as radios transmittersetc. Check for compliance with relevant standards such as C-Tick etc
SAFETY
Powerinverters can generate potentially lethal voltages so the utmost ofcare should be exercised using them to avoid accidental electrocution.
SUMMARY
To select your power inverter carefully check the power requirements for the appliance(s) you intend to use it with.
  1. Start power - Allow up to seven times for an induction motor
  2. Operating power - Allow a 20% margin
  3. Pure or modified sine wave
on Mar 04, 2010 | Electronics - Others
Can I plug a camera, shaver, or cordless tool battery charger into this Modified sine wave
Yes you can and no it won't harm it unless something is wrong with it or the charger.
The inverter output doesn't get to the battery, just the chargers output.
Aug 26, 2012 | PowerBright Power Bright 2300 Watt Power...
I bought a new Black and Decker 200 watt power invertor to plug into our car cigarette lighter to power a laptop. We did this and our car blew a fuse. We went to Saturn to fix it and they could not...
Most power inverters supply a modified sine wave output. This is different from the true sine wave you get at home. It's close enough for many applications, but not close enough for many transformers, which is what your laptop power supply is. So the problem is that your laptop's power supply does not work with a modified sine wave input. Some will, some won't. Very common problem.
Aug 23, 2010 | Black & Decker Electronics - Others
Hi i have a 400w black and decker inverter as soon as i plug my lap top in to it the power light on the inverter flashs and it wont power my laptop
The output of this inverter (and most others) is a modified sine wave, which isn't quite the same as a true sine wave - like you get from a wall outlet. Unfortunately, most transformers (which is essentially what your laptop power-supply is) require a true sine-wave. Your inverter will work fine for many other 110V applications. You can buy an inverter with a true sine-wave output, but they are more expensive.
Aug 19, 2010 | Black & Decker Power Inverter PI400AB
Frequency Inverters DC-AC
I highly suggest you invest in a good quality inverter. For most equipment either pure or modified sine wave is fine. I would suggest you install a line conditioner after a UPS for any computer products. The line conditioner stabilizes the voltage much more closely than a UPS will.
As far as building your own, I've taken apart a lot of UPS models which have a DC-AC converter in them and they are filled with lots of heavy heat sinks, transistors, resistors, capacitors, etc. You can usually find these very cheap since the batteries die but the converter is fine. Check the input voltage of the original unit and start from there to make one easily that has everything already assembled with minor modifications.
Jan 15, 2018 | Xantrex Technology Ags Harness Cable...
Charging laptop in car
Most inverters create a modified sine wave output, which is similar to, but not the same as the AC you get out of the wall. The power supply for many laptops (and most transformers in general) will not run with a modified sine wave input. There are devices available that skip the inverter and the power supply. They go directly from 12VDC to what your laptop needs.
Apr 23, 2010 | Black & Decker 200 Watt Power Inverter...
Grundfos Pump On Xantrex Modified Sine Inverter?
Look I been using solar and wind power for the last 20 years and never used public utilitiy, run your inverter to a braker box and connect your pump to it donot forgfet to ground the box and the inverter. that is all what you need...remmber modified sine wave may effect the life of the pump if it is cheep it may be ok or you need to get true Sine wave.
Feb 09, 2009 | Xantrex Technology Xantrex Freedom Xmic...
Is true sine wave better than modified sine wave.
I'm not sure what the application is but I will offer the following. As a retired electronics engineer i can say for sure that a true sine wave does not have any harmonics in it. A modified sine wave will have some harmonics and other what I would call " trash content" depending on how it is modified.
Loringh
Nov 16, 2008 | Xantrex Technology RS400 Sine Wave...
Thermal Engineering Corporation I-Tec 150 Watt Power Inverter Logo
328 people viewed this question
Top Thermal Engineering Corporation Electronics - Others Experts
Are you a Thermal Engineering Corporation Electronics - Other Expert? Answer questions, earn points and help others
