Question about Nintendo Wii Console
My nintendo wii has frozen after start up I start the wii and i can only move the hand on the wii screen for a few seconds than it's frozen. I can't do anything.
  • Anonymous May 16, 2009
    When I start up my Wii console, it goe to the Wii menu, works for about 10 seconds. And freezes, it won't reset or anything. The only way to turn it off is to go over and manually turn it off on the console itself. I tried pulling out the cords and it still hasn't shown any signs of recovery.
    Sergeant:
  • 320 Answers
The screen on my Wii game is frozen and even if I unplug it, it just goes back to the same frozen screen. Please help!
Please check to see if there is any dirt or dust on the disc, this will often cause the game to freeze.
If the console has stuck on a frozen screen, please unplug from power for 10m then plug back in.
Your console should reset and start working normally again.
Thanks
Mar 06, 2011 | Nintendo Wii Console
Wii Fit
what appears to have happened is the sensor within the mote has dislodged and been moved out of alignment the smacking both sides works but its only a stop gap solution, you need to open up the mote and tac some solder onto the connections, this will prevent it from going out again, also check the sensor bar is not loose as the cable from the sensor bar can sometimes become loose if it's moved around alot.
Sep 14, 2008 | Nintendo Wii Console
How to get the internet
Below are simple connection instructions from Nintendo's website on how to connect your Wii to the internet via wifi and an ethernet adapter.
Connect a Nintendo Wii to the Internet through a Wireless Router
1 Turn on your Nintendo Wii by plugging it into a power source and pressing the power button
Press the "A" button on your Wii controller to continue from the warning screen
Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
Click the "Wii Settings" box on the right.
5
Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
6
Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
7
Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
Connect a Nintendo Wii to the Internet with a Wii LAN Adapter
Insert the Wii LAN Adapter into the USB port on the back of the console.
Connect an Ethernet cable from your modem or router to the adapter.
Turn on the Wii console.
Click the "Wii" options button in the lower left hand corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options.
5
Select "Connection Status," then "Connection 3: None" and "Wired Connection."
Mar 05, 2011 | Nintendo Wii Console
Controllers not working
what stage are you at are you on a game or on the wii home screen?
Mar 22, 2009 | Nintendo Wii Console
Wii has frozen playing guitar hero
Hi. I got the same thing playing GH but without the nunchuck. Use the hand controller to re-sync. Press the sync button on the console FIRST and then the sync button on the hand controller SECOND.
I sat for hours trying to work it out - and it cleared the problem within seconds. Hope it works for you too.
Feb 20, 2009 | Nintendo Wii Console
My nintendo wii has frozen after start up screen frozen on menu
disconnect power to nintendo and also the tv, replug should be ok
Feb 19, 2009 | Nintendo Wii Console
Wii mario kart, second wheel won't turn
I tried resyncing from the main screen, but one of the wiimotes still didn't work. I read to smack the wiimote facedown in your hand a couple of times, and that worked!!!
Apparently the motion sensor can get stuck inside, although it doesn't totally make sense, because previously when the wiimote didn't steer, it still moved on the screen to choose character, car, etc.
Dec 25, 2008 | Nintendo Mario Kart (Wii) for Wii
Nintendo wii problems
Hold the Wii Remote with the button side down. Without using much force, firmly tap the button side of the remote against the palm of your other hand a few times. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard. Check for proper response.
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen.
  • Make sure you are using fresh batteries in the Wii Remote.
  • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
  • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
  • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
  • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
I hope this fixes it for you!
Jul 08, 2008 | Nintendo Wii Console
Hand sets do not seem to work
Press and hold the sync button on the Nintendo Wii remote. While holding the sync button, go over to the Nintendo Wii, and and press and hold the sync button. Wait for a few seconds, and then test the Nintendo Wii remote.
Dec 18, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
491 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
