Question about Sony BRAVIA KDL-46W3000 Television
TV Goes to Stand-by mode
My Sony BRAVIA KDL-46W3000 goes to stand-by Mode, a red blinking light goes on in a sequence of 6 blinks, What could be the problem?
  • 3 Answers
I don't have a solution, but I have the exact same problem
Posted on Sep 08, 2009
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
Dec 30, 2014 | Sony Televison & Video
Sony kdl-46w3000 3 blinks
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 05, 2017 | Sony BRAVIA KDL-46W3000 Television
Stand by light blinks in a 4-blink sequence after the tv works for 30 to 60 minutes
Hi saqa.
Welcome to FixYa.
My name is John, and I will be assisting you with your issue.
The four (4) blinks mean that you have no vertical Deflection, and
it goes into stand-by (safety mode) for protection. If you are not in
fear of high voltage because it can kill you! You can do this job yourself.
Let me know and I will post it here and the tools needed. Thanks for choosing FixYa.
Happy Holidays..........John
Dec 26, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My sony tv automatically goes into stand by mode and we have already changed the power supply as solution given by fixya .com
If the unit is playing normally then goes to stand-by, it could be also caused by the main board and or the ballast boards. If it is caused by the ballast boards, it should give you error code with the red stand-by light blinking 11 or 13 times. If the stand-by light does not blink a code, it is probly the main board.
I hope this helps,
Skyassoc
Dec 08, 2010 | Sony KLV32S400A 32 in. LCD TV
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Nov 19, 2010 | Televison & Video
Sony Flat
Goes from on to Standby by its self because of protection mode that activates for some internal problem. Do you see standby light blinking on tv front? What is model number of your tv? How many times standby light blinking after 3 seconds long pause? Let me know to find out possible cause of problem.
Jul 25, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Jul 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Tube 27" sony tv, stand by timer light blinking red?
It has a faulty power supply or processing boards. Must take to agents to sort out. Nothing you can do on the outside.
May 12, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No sound no picture, the stand by light blinks four times
If you have the above model, then the four blinks indicate a backlight failure. The back light inverter board might be defective or the voltage from the power supply (+24v) is low or missing.
Let me know if you require further assistance.
Dec 30, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-46W3000 Television Logo
843 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
