Question about Refrigerators
The refrigerator and freezer rubber door seals are too hot to touch.
  • 4 Answers
Pull fridge out and clean the grill on the back , its a hot pipe running around the door for condensation , if the grill on the back is clogged with dust it will get very hot , see how that goes enjoy
Posted on Mar 05, 2009
Why does the rubber sealer on refridgerator door and freezer door get hot
Inside the frame is a warm bit of pipework, or sometimes a mullion heater, that stops the seal freezing to the frame.
Aug 21, 2014 | LG LSC26905TT Side by Side Refrigerator
My freezer has too much frost, door does not open easily because frost is frozen on the track. What is wrong?
SOUNDS LIKE THE DOOR SEALS ARE NOT TOUCHING ALL ROUND,USE A CLOTH/ HOT WATER TO MOLD THE RUBBERS TO FIT.
Aug 10, 2010 | LG Refrigerators
Door seal between fridge & freezer is hot is this normal ?
No, there is a heater in the seal of the doors to keep the doors from icing up, if it is hot to the touch then the heaters are going bad and must be replaced. You can replace it yourself by removing the door seals, and then removing the heating element that runs the whole door. When you do this make sure that the unit is unplugged.
May 17, 2010 | Kenmore 53092 / 53094 Side by Side...
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Kitchen Aid side-by-side refrigerator making dishwasher sounds
The freezer door frame should be warm where the door seal is located. This is to keep the rubber seal plyable and to prevent the door seal from freezing. Could it be that the cold seal is not properly mating with the frame and you are hearing the fan noise through the crack ?
Aug 05, 2009 | Refrigerators
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Freezer side is hot outside
There is no problem at all. The outside of the freezer is hot because it is rejecting heat from the inside of freezer compartment to the outside surroundings, this is a normal refrigeration cycle. As for the seals being hot, this may be to prevent the door from freezing shut. i know that commercial and industrial freezers have heated seals for this reason.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
Top freezer opens when lower door is shut
This could be the door rubbers, try boiling some water and pour it slowly over the rubber,it would turn soft and wold return to the original state.
now close the door and with a hair dryer set on hot,blow on the rubber untill it seals all over.
let the door stand close for at least 6 ours...
Let me know if it worked..
Good luck.
Sep 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
Refrigerators Logo
769 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
