Question about Elna 2007 Mechanical Sewing Machine
Elna su flywheel won't turn.
The machine has been setting in storage for years. It was given to me recently and I am trying to get it ready to use. The motor tries to run when I press on the foot pedal, but the flywheel won't turn. Is there something else I should can do or should I take it in for service?
  • Elna Master
  • 1,133 Answers
I'd suggest if its been in storage for a while, then a good clean and service would be benficial to the machine. However, just double check that the clutch is engaged, either a button on the flywheel (carina) or hold the outside of the flywheel and turn the inside wheel towards you to unlock, away to lock.
Posted on Oct 02, 2011
On the Carina SU there is a button on the flywheel to disengage when winding a bobbin. Be sure this button is pushed in.
Posted on Feb 26, 2010
Elna SU 1970's model flywheel wont turn. Tried taking cover off and oiling. No cotton wrapped round bobbin, Metal bobbin case. Been serviced, but not used for 6 months. Anyclues please?
The old oil may be causing the machine to seize. You might try setting the machine within distance of a heat source, like in the sun on a warm day or within 3-4 ft of a fireplace, etc. The warmth sometimes will loosen things. If this helps, you may want to have a thorough cleaning and oiling done by a technician.
May 01, 2017 | Elna Sewing Machines
The flywheel will not turn on my elna su air electric machine
do you mean that you can't unlock the inner wheel on the flywheel to disengage the clutch? Grasp the outer flywheel and using a plastic mat for removing jar lids, get a good grip on the inner clutch wheel, then turn it towards you.
Jul 28, 2014 | Elna Sewing Machines
The flywheel on my elna su will not turn
either a jam up in the bobbin which is preventing the needle bar from coming up, internally siezed up, or the friction belt internally to the flywheel has broken/worn out.
There are a couple of different SU models, the Star Series and the Air Electronics both had an SU (supermatic) model so I'll be general in my description. Firstly remove the needle cover plate and check around the bobbin race for jam ups. Or if the machine has been packed away for a long time unused, then we could assume this is a sieze up. FIRST REMOVE THE POWER PLUG FROM THE MACHINE FOR SAFETY. You'll need to remove the top machine cover and delve into the insides with a bit of patience, good quality sewing machine oil (tri-flow is perfect if you can obtain some, bike shops have it or I got mine from Ebay) and Qtips or something similar.
There should be a couple of screws holding the top cover onto the machine so remove these and then lift and tilt the cover to the back around the lifting handle and making sure you clear the bobbin winder mechanism on the right. Really good idea to take photos with your mobile as you go so you can remember where things went. Now apply triflow to the metal moving parts you can access, in particular the top of the Elnagraph shaft which should have a red mark for oiling point, and the needle bar swing bearing. Keep oil away from the belt/s on the right side of the machine where the flywheel is driven by the motor.
You'll need to carefully clean, oil and gently move the flywheel back and forwards until things free up.
Bobbin case Elna 62c
Really you are very appreciated in your machine maintenance. If you wanted to Elna SU 62c machine bobbin case
please see the link :
http://www.ebay.com/bhp/elna-sewing-machine-bobbins .
Dec 29, 2013 | Elna Sewing Machines
How to embroider with elna su electronic
There are a couple of Elna SU models, the Star Series SU is white with a blue top panel. Or the air electronic SU is a white machine and a dozen years newer (80's). Both have a disc elnagraph reader in a flap on top of the machine and sew a range of stitches involving either side to side stitch formation or side to side and forwards and backwards, albiet revolutionary when new but not what modern computerised embroidery machines can produce now. To use, you set stitch width and length dials to zero, then insert the black disc into the elnagraph ensuring you line up the disc with a little finger underneath. There should be a red marking on the disc and the shaft to assist with this. Press down until the disc clicks into place. Now turn stitch length to S for supermatic and width to 4 and sew. You can vary the stitch width to adjust stitch and the AE also has a little dial that elongates or closes up the stitch. Try machine embroidery thread for a silky stitch especially with satin stitch where the thread is close together. Also wing needles can be interesting when using the turkish hem stitch disc.
Dec 29, 2012 | Elna Sewing Machines
ELNA Clutch slip. I have an Elna SU 68 which has served me very well over the years. Recently the clutch has started slipping after about 20 mins sewing. I have stripped and cleaned the pulley and...
Hi Dave,
not sure where you are located for a repairer but the US Swiss Elna Guru is White Sewing Center for spares and repairs.
But I would strongly suggest that you jump over to Yahoo groups and join the group called "Elna heirlooms", then search the threads there as there has been lots of discussions in the past on the Air Electronic drive belts, I can't remember now what the fix is but there are some really talented mechanics in that group, Jim is one who springs to mind.
Also, these machines do have have capacitors inside the air electronic panel for controlling the speed. Also, in this group there is some shared images of manuals/parts/repairs which should be of help to you.
Jun 01, 2012 | Elna Sewing Machines
Flywheel on elna su wont turn
when a hand wheel won't turn then the machine needs to be serviced
Feb 28, 2012 | Elna Sewing Machines
Hi, I have an Elna Carina and the flywheel is
I can direct you to a service manual for your machine but it may be something that you need a trained Elna service technician to deal with.
Link is http://www.arizonaexpressionz.com/elna_service/air_elec_carina_elec_SM.pdf
I am more familiar with the SU air electronic where you just hold the outside of the flywheel and turn the inside knob to disengage and rengage the clutch - didn't realise the Carina had a button flywheel release until I looked in the service manual.
Anyway, you could try dismantling the flywheel following the exploded diagram in the service manual if you are technically minded.
Or just take it to a reputable serviceman, I'm a big fan to supporting these guys as their knowledge is invaluable.
Jul 10, 2011 | Elna Sewing Machines
Extra discs for an vintage Elna Supermatic plus pressor feet.
Try the usual eBay route, but also approach any Sewing Repair shop as they often acquire odd bits from old machines....We had 9 disks for a lady with an Elna SU only last week, all from a machine traded 2 years ago and really beyond resale.
Aug 02, 2009 | Sewing Machines
Elna 2007 Mechanical Sewing Machine Logo
769 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
