Question about Solar Southwest Pottery Light Switch Plate And Outlet
How do you make plates or bowls that are strong enough for everyday food use and you can use in the dishwasher? What material should you use (what kind of clay or other) and what is the process? Can I use my oven to bake the dishes? I want to make my own dishes that are as useable as the ones you find in the store.
    Problem Solver:
  • 17 Answers
You would want to use CERAMIC clay. The easiest way to make dishes is on a potter's wheel, but could be done with rolling pin and bowl / plate / cup to form. Roll clay anwhere from 1/4 to 1/2 inch thick, using flour or cornstarch to prevent sticking to work surface / tools / forms. Lay clay over form and trim off excess clay. As it will be very soft, you may want to leave it uncovered for a day or two so it can dry out and harden to near-leather hard.
You CAN use your oven to fire (bake), and for safe food / dishwasher use, after first firing, glaze with non-lead, non-toxic pottery glaze. *Careful not to get too thick as glaze WILL run during the second firing.
Your local Arts & Crafts / Pottery store should have all you need to make what you want, as well as DIY help on / with all aspects of pottery for even the greenest of beginners.
Posted on Mar 14, 2009
In need of Bowl and blade
GENERAL ELECTRIC FOOD PROCESSOR MODEL 106622F WORK BOWL
I was able to locate a bowl for the 106622F processor on E -Bay. You may be able to find a blade on E-Bay. From what I gather, there is no source for replacement parts, other than used parts. I hope this helps ! Good Luck....
Mar 31, 2014 | GE 106622F Food Processor
Tip
Dishwasher Tip
It is probably not necessary to pre-wash your dishes like some people do, but it is important to scrape off leftover food from plates and bowls. Rinse and then load into the dishwasher.
on Aug 17, 2010 | Refrigerators
Genesis vacuum sealer manual
This is all I could find.
  1. Be careful sealing foods with marinades. Too much marinade can cause a mess as it is sucked out of the bag! Instead, try dry or wet rubs on meats before packing. Slices of lemon or other citrus are a great way to add tenderizing acid with less mess; when food thaws, the acid from the fruit will tenderize and flavor the meat.
  2. Hamburgers are great to store in the freezer in vacuum bags, but shape and freeze them solid before sealing. The force of some vacuum machines is enough to squish and deform burgers!
  3. The same goes for baked goods -- freeze them solid first, and then make sure to use the lowest power setting on the machine. Typically this is the one for moist foods; less suction helps avoid pulling all the air from baked goods.
  4. My trick for freezing soup: I freeze it in plastic microwave-safe soup bowls, then pop the soup "ice cubes" out of the bowls by running hot water over the bowl for a few seconds. Frozen individually, each one is a perfect single serving of soup ready to be put back into the bowl and popped in the microwave!
  5. For items that will be opened and resealed, make sure to use a very long bag so that there is plenty of room to cut it open and then re-vacuum. The best example of this is for cheeses in the fridge. Most bag materials are strong enough to stand up to repeated use and many bags may be washed and reused.
  6. Do NOT wash and reuse bags used to freeze raw meat or poultry! Be sure to clean the parts of the machine completely between different types of meat and poultry to avoid cross-contamination of bacteria.
  7. Make sure to thoroughly read the directions that come with the machine. Used incorrectly, vacuum machines can be quite messy.
  8. Hope that helps. The instructions are supplied with the machine.
Dec 20, 2013 | Computers & Internet
Which dog bowl should I buy in order to keep the feeding area clean?
You should pick the elevated dog bowl for cleaner feeding area. You clean the surface of the feeder table rather than the floor. In addition, the elevated dog bowl can minimize the behavior of dogs that like to splash in their water bowls.
Sep 02, 2012 | Alessi Pets - Others
How often should I clean my cat's bowl?
You should clean your cat bowl daily and put in the dishwasher every few days (if it's on a dry food diet). If your cat eats canned food then put the bowl in the dishwasher daily.
Sep 02, 2012 | Alessi Cats
Why does my sunbean mixmaster bowl don't spin?
the spinning plate under the bowl does not have any power to spin the bowl; it only aks as a "lazy susan" carousel that allows the bowl to turn from the movement of the material being wipped in the bowl.
the beaters are purposely off-center of the bowl in ordwer to create a dragging motion of the material in the bowl, thus pulling (that is, spinning) the bowl slowly. If the beaters are not off to the side of the bowl, you will not get the pulling/spinning motion. Also, if the plate under the bowl does not move very easily, then the bowl will not spin. You may have to remove the spin plate and clean the center pivot for the plate to move freely. Good Luck, Macgivor.
Nov 27, 2010 | Sunbeam 2346 Heritage MixMaster Series...
My old mother has bought the Magimix 3200 but is not strong enough to open the lid once it is shut, actually most of the time I'm not strong enough. Can this be fixed?
Cuisinart Elite Food Processors don't require the twist action but the lid clips on, they are very easy to use with a number of great features including seal tight interlocking bowls, blade lock so the blade doesn't fall out when you're pouring out the results a pouring spout, plus a storage box for all of the blades:
http://www.cuisinart.co.uk/products-detail.php?ProductID=53&ProductCategoryID=0&ProductGroupID=1&DiscontinuedOnly=N
http://www.cuisinart.com/products/food_processors/fp-14dc.html
Sep 28, 2010 | Magimix 3200 Food Processor
The dishes do not get clean. Food is left on plates, in bowls, on silverware. Coffee stains are building in cups. Milk leaves a "film" on glasses. When the cycle is finished, it appears that the water...
Hi, it sounds like your dishwasher is plugged up with soap deposits, and/or Calcium deposits.
In an empty dishwasher, put 2 cereal/soup bowls full of vinegar on bottom shelf, and run your dishwasher.
This should clean out all the deposits.
I do this about once every six weeks as our water is very hard.
Fred
Sep 30, 2009 | Dishwashers
Food particles remain on dishes
This was fixed on my unit by taking out the chopper assembly and cleaning the screen. There is full spray on top now. The screen on the chopper assembly actually had some plastic on it that was hard to see, but was blocking most of the holes. Since this was blocked, the pump couldn't pull enough water to push it to the upper spay arms. My chopper was actually broken so it wasn't clearing the screen, so I had to replace it. That will probably help prevent this from happening again, but if you ask me, the unit was designed poorly for handling normal debris that comes off of plates. I'd recommend inspecting this regularly to keep it clean.
Mar 03, 2008 | KitchenAid KUDR01TJ Dishwasher
Smeg dishwasher
riff...not sure what the bits are...first, they may be food crumbs or the like. Dishwashers have macerators to grind up food particles but they have no really good way to get rid of them in the wash cycle. Scrape plates of any solids before loading them. If the material is shaped like water droplets, you may have hard water stains. Use Jet Dri or a cleaning product which claims to help and use the amount specified. Your water temp may be low...it should be 125F or better. If you can run the hot tap and put your hand under it...it isn't hot enough. You can also use the heated water setting to deal with this.
Dec 11, 2007 | Smeg DWI614 Built-in Dishwasher
Solar Southwest Pottery Light Switch Plate And Outlet Logo
125 people viewed this question
Top Solar Electrical Supplies Experts
Steve
loft404
loft404
Level 1 Expert
Craig Butler
Craig Butler
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
