FixYa.com
Tags:
U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router
Wireless bridge, modded XBox, and FTP issues
By Ranny - usenet poster
I have a modded XBox connected to my network via a DLink GWL-810
bridge. XBox live works fine. But...
I can't FTP to my XBox. I have set a static IP address on the XBox but
my computers don't see the XBox on the LAN. When I connect the same
XBox directly to the LAN (wired connection), FTP works fine.
What determines the IP address of a device connected to a wireless
bridge?
Thanks in advance!!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
Thanks for Trying (70)
Horner
Horner - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
On 30 Aug 2005 10:42:11 -0700, wrote:
Well, if you have similar computers connected via wireless in the same
way the Xbox is connected, and it's not an encryption issue, and the
Xobx works with a wired connection, then by process of elimination, it
has to be an Xbox or DLink DWL-810 issue. Some ideas:
1. Check the CAT5 cable between the Xbox and the DWL-810. Yeah, I
know it's dumb but it happens. Also check the polarity of the cable.
It *MIGHT* (not sure) require a crossover ethernet cable.
2. Take the Xbox out of the picture and try using the DWL-810 with
one of the other computers. If it works, then the problem is in the
Xbox (which I know nothing about).
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831.336.2558 voice #
# -cruz.ca.us
# AE6KS
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
pawa
pawa - usenet poster
Rating: 0%, 0 votes
Thanks so much Jeff!
Solution #3
Not Rated (0)
Janice
Janice - usenet poster
Rating: 0%, 0 votes
Jeff - thanks for the reply. I'm not running encryption on any of the
3 wireless routers (please see the above post for specifics). We live
in the middle of nowhere, the bears and deer don't have wireless (yet).
Thanks again,
Scott
Solution #4
Not Rated (0)
Reynolds
Reynolds - usenet poster
Rating: 0%, 0 votes
Thanks David -
I'm running 2 US Robotics USR5461 B/G Wireless routers, one LinkSys
WRT-55G wireless router, all 3 connected to 3 D-Link Gigabit switches.
There are 6 computers on the LAN, 4 ReplayTV's, and the wireless
routers. I'm using a DSL modem (Westell) and letting the modem assign
DHCP addresses to all of the above except 2 of the computers which have
static IP addresses. They're all in the 192.168.1.xxx range.
Thanks again,
Scott
Solution #5
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
On 30 Aug 2005 08:11:16 -0700, wrote:
If it works wired, then it's a wireless problem. The problem *MIGHT*
be the encryption key setup between your unspecified wireless access
point or unspecified wireless router. Try it without encryption and
see if you get an IP address on the Xbox. If that works, and you're
using WEP, then try using a Hex web key instead of ASCII.
Jeff Liebermann -cruz.ca.us
150 Felker St #D #
Santa Cruz CA 95060 #
AE6KS 831-336-2558
Solution #6
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
The DHCP server on the other side of the bridge or the static IP address
that you have configured.
You've only quoted on side of the bridge, presumably there's another
wireless router to which you are connecting. Make/model/config details.
Likewise, you haven't provided any details on the IP addressing in use.
Jeff will have to upgrade his crystal ball, he's not going to be
happy...
David.
Can you Help with these Routers problems?
Routers
Wireless and Wired Router
I currently have a desktop and... Answer This...
U.S. Robotics USRobotics USR5461 Wireless...
Hayes command of...
Does the US Robotics 33.6... Answer This...
sony vaio laptop TR2A not...
vaio laptop tr2a is not... Answer This...
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
