Question about Measuring Tools & Sensors
How you use a stanley center square #46-101
How do you use a stanley center square #46-101, looking for an instuction manual.
    Problem Solver:
  • 5 Answers
No need for a manual. Just hold it so that the two edges of the "vee" line up with the circumference of the circle and scribe a line along the steel rule. Then turn approx. 90 degrees and scribe another line along the rule that intersects the first. The point of intersection is exactly the center of the circle. This tools only function is to find the center of circles.
Posted on Apr 21, 2010
What do all the numbers on a framing square mean and how do read them?
The numbers on the side of a framing square are used for many things. The small leg allows you to quickly lay out a wall on16" centers. The other rows of numbers help you figure the correct sizes to cut for hip roofs (roofs that have slope on all four sides.)You can get an instruction Manual from Stanley or it may be availabile on the net. Google (framing square instructions)
Aug 05, 2013 | Stanley Homeowner Carpenters Framing...
I can't find a user manual for stanley 15 amp automatic battery charger BC1509 no matter where I look. Can you help??????
Go here for the Stanley BC1509 15 AMP Battery Charger Manual:
http://www.baccusglobal.com/stanley/bc1509.php
Jul 15, 2011 | Stanley Black & Decker Stanley Bc1509 15...
Why is the time not corrisponding to real time will work for twenty min then will not keep correct time. Please e-mail me instuctions maybe I missed something but many reviews that second plug non...
You posted under Stanley analog timer.
If dial is not keeping time, then clock motor is bad, or polarity on your outlet is reversed.
Try timer on different circuit breaker outlet and with different load (lamp)
Test outlet with circuit analyzer.
Open following link for step-by-step instructions setting analog timers.
http://waterheatertimer.org/How-to-set-timers.html
Open following link to identify same-similar timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#49664
Jun 26, 2011 | Stanley 38448 TimeIt Duo TwoOutlet 24 Hour...
I need an instuction manual for a plane that is over 100 years old. Stanley no 45 plane.
Something like this? http://www.tooltrip.com/tooltrip9/stanley/comb-planes/45man.pdf
Jun 15, 2011 | Garden
I need instuctions for the Stanley 69-702 staple gun
How do I load and use Stanley E type J nails/ tacs (0-69-708) into my Stanley 69-702 nailgun. I'm led to believe they are compatable
Aug 19, 2010 | Stanley Tools Staple/Brad Nail Gun
Directions on how to use a square to cut common rafters we have a stanley squ and no manual, on use
A standard square is used primarily for drawing 90 degree angles. Simply hold the fat side of your square firmly against the length of rafter. The skinny side of the square should be lying accross the rafter, forming a 90 degree angle with the side. Use a pencil to draw a line along the edge of the square and use this line as a guide while sawing the rafters.
Sep 27, 2009 | Carpenter Stanley 45-500 Handyman Steel 's...
Have a stanley tre550 and need to know how to use
The staples are NOT loaded on top of the pull out shaft; they are inserted directly into the slot that opens when you pull the shaft out. If the nose of the tool is not placed firmly against a surface, it will not fire. Go to Stanley’s website’s knowledge base and type in the model number, and you can get a PDF of directions. http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm Below is the graphic from their pdf. Here is a step by step: Unplug the tool. Squeeze the end of the shaft at the rear bottom of the tool and pull out the shaft. Flip the tool over on it’s back. Insert the staples, (points up) and then slide the shaft back in. Plug it in, press the on button (under the the power cord in the back). Press the nose squarely against the material and press the trigger.c901269.jpg
Mar 29, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
Measuring Tools & Sensors Logo
1,619 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
