Question about HP Digital Printers - Hewlett-Packard All-In-One Printer, Scanner, Copier from Sears
I reloaded my HP C4280 printer's cartridge recently. It is full, but the printer dosen't start to print - it says that the cartrigdes is empty or unavailable. How can I reset it? Is there any software for this? Thank you.
There is no way to reset the embidded chip on the cartridge. I suggest purchasing another printer manufactured by a different company. Sometimes you can buy them as little as $40.00. But be aware that it too may have an embidded chip. One way to outsmart HP is for everyone not to purchase an HP printer.
Posted on Mar 17, 2009
I can't print anything off the computer since I put in a new cartrigde.
Now way related to cartridge &Printer driver, check USB cable,reload drivers once again.
Dec 22, 2011 | HP Officejet 5510 All-In-One Thermal...
Printer will not print color only black and white. new cartridge installed.
Hello friend,
Recently on the market we are having fake,imitation, compatible cartridge and also faulty cartrigde.
may be this is the problem...
Dec 18, 2009 | HP DeskJet 3650 InkJet Printer
0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
PRINTTER HP1350 CARTRIDGE LIGHT
It sounds like the printer thinks one or more of the cartridges are empty, even when they aren't.
Your only option would be to purchase new cartridges, install them and see if the light continues to flash. If it does, I would suggest you contact HP:
http://h10025.www1.hp.com/ewfrf/wc/conta...
(You can speak to an online technician, call support, or e-mail them, I would suggest the first option)
Sep 17, 2008 | HP PSC 1350 All-In-One Thermal Printer
Test sheets will print, but nothng I try to print works
Remove the 1610 printer using add remove programs adn the reload it. Sound like software rather than hardware
Apr 21, 2008 | HP PSC 1610 All-In-One InkJet Printer
Hp c4280 printer/print cartridges
Have you checked to make sure that you have the correct replacement cartridge?
In general if it simply will not go into position and you know you have the correct cartridge, then you need to take it back to where you bought it and request a replacement - because it is defective.
Apr 14, 2008 | HP PhotoSmart C4280 Laser Printer
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
Red is printing pink.
have u used this printer quite a bit....? if so the following may be the problem and I just did run across this recently in a printer we had in the shop....I recently read in one of my technical magazines that there may be a design flaw in the placement of the laser scanners and the openings that protect them....it seems that excess toner dust can readily get in to scanner area and specifically inside the scanner assembly and accumalate on the scanner glass and lens. Just cleaning through the opening in the back of the printer will not eliminate the issue. Machine will have to be disassembled, scanner removed and opened and the glass/lens cleaned with a q-tip....the placement of the fan (behind cartridges, lower right) seems to speed this process up and it usually becomes first notable with the magenta cartridge, seeing as it is at the bottom of the printer closest to the fan. Hope this helps..
Inkworks
Oct 04, 2007 | HP Color LaserJet 2600n Printer
HP Digital Printers - Hewlett-Packard All-In-One Printer, Scanner, Copier from Sears Logo
492 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
