I have a VCR tape that I cannot eject from the unit. The green timer light flashes. I do not have the original remote; I have used a Sony remote (RM-V18A). This tape has been stuck in the unit for quite awhile. I would like to remove it (to have access to the tape) and I recently was given another VHS tape that I would like to play. I have reviewed the manual. I am concerned, since the manual notes that the time can be set up to Dec. 31, 2007 that this machine is locked up with no options. Please help me with a rescue! Thanks! Quasar VV8213
  • James Bradburn
    James Bradburn May 11, 2010
    If you pressing the eject button dont work then, you will have to take the top case off and look for a gear that controls the ejector carrier, but be sure that the proper gear will release the tape and returns it to the cassette.
  • 423 Answers
Hi
If it's a front loading unit, then open the door and use a pen knife to gently pull the tape out enough for you to grab it. Pull it out just enough (about 2 inches) and look under the tape. There will be a little pen hole about an 2 inches from the edge of the tape between the spindles.
Use a pen or a pencil in the hole to disengage the spindle lock. Then you can gently pull the tape case out without any hassle. You will have to hold the pen in there while you are pulling the tape out to keep the spindles disengaged!
This gets the tape case out, but the tape may still be stuck inside. It may be stuck on a pinch roller. Use a small flashlight and a slim object to gently free tape from what ever has caught hold of the tape. This is the best way without having to take apart the tv.
Rob
Posted on Mar 05, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Try turning offf the unit and when it turns on then press eject button for 4-5 times. If that doesn't help you need to open the top panel of the unit to remove the tape.
  • 19,396 Answers
If the VCR tape is stuck inside, then you will need to take part the unit to remove the tape without damaging the VCR.
  • 10,594 Answers
Please unplug VCR from AC outlet, replug back and eject tape.
If still problem there, slap gently on VCR cabinet while pressing eject button.
Shuts off when trying to play or record
This could be due to the VHS tape sticking on the tape reel, that triggers the overload and the shutdown. Try fast forwarding if possible.
Nov 01, 2017 | Emerson EV787 VHS VCR
VCR won't eject tape or play & powers off
It sounds as though it's jammed. If you're mechanically inclined you can unplug the unit, take the cover off, and manually eject it. Just look for the motor that drives the load basket and manually spin the shaft. The guide-posts should retract towards the tape and the basket will then lift and eject. Just be aware that whatever bit of tape that's out of the cassette won't spool back in. You will have to do that bu hand once it's out.
When you're done, plug it back in and let it cycle then put an old cheap tape in and see if it works. If not, take it in for repair.
Nov 08, 2007 | Emerson EWR20V4 DVD Recorder/VCR
MY RCA VCR - TIMER LIGHT ALWAYS FLASHES. WHEN i TRY TO RECORD OR TURN OFF VCR IT EJECTS TAPE.
If it plays a tape OK, then it could be that you have a timer set. In which case clear it! Or that you are using a blank tape where the slot at the back is open. If you are using a blank tape which is good and it still ejects the tape after setting the recording. Then it's likely the recording tab sensor - that detects the slot at the back of the tape - is either bent or broken.
Feb 22, 2013 | RCA Televison & Video
DVD side wont respond
I had this problem as well after recording a DVD. player might be in timer mode. press SET TIMER buttom to cancel timer function, press DVD to use player.
Jan 04, 2013 | Toshiba DVR620 DVD Recorder/VCR
I put a vhs tape in an the vcr turns off by it self a green light keeps flashing by where it says cst in. I have a Hitachi DVD/VCR COMBO DV-PF2U. I also can not get the tape out
Unplug the power supply for thirty seconds and plug back in, this will reset the processor and might eject the tape. If this fails the next step is remove the top of the combo unit this will give access to the vcr tape, if the tape is spewed in the machine and wrapped around the video head and other mechanical parts use scissors to cut the tape and carefully removing the particles, press power to eject the tape for normal operation. However! if the vcr tape is okay, there may be a loading problem, broken drive belt, bad idler assembly to name a few, this is where a technician will be needed but may not justify cost.
Jan 23, 2011 | Hitachi DV-PF2U DVD Player/VCR
Magnavox TV/VCR COMBO
Im thinking that maybe you a have a timer recording set. The whole unit wont function at all if you turn it on via power button (remote or unit). There should be a button at the top of the remote called 'timer set' pressing this will disable that mode and allow complete use of everything. but make sure u press timer set again when powering down, otherwise simply turning off the machine will leave the timer recording disabled.
Oct 17, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
Sony vcr model slv-m91hf
make sure the tape is not missing its tab which is on the left hand side of the tape at the back
Dec 09, 2007 | Sony SLV-M91HF VHS VCR
Televison & Video Logo
Top Televison & Video Experts
