Question about Electronics - Others
I have a markvision 2G memory stick and I typed my name to identify my flash drive when plugged in, the name disappear and marked removable disk G. When try to open it prompt please insert disk into drive. I try different systems and the same error occurred. So i am asking for some immediate help thank you.
SOURCE: Remove Write Protection
= =", im sick of this,
many website teach me that method,
but it doesn't helps = =".
At REGEDIT,
1) i right click the "control"and cr8 new key name "StorageDevicePolicies"
2) after that, i cr8 a "DWORD" there name "WriteProtect"
3) i wonder it should change to "1" or "0"
*but i hav tried "1" and "0" but also the disk is still
"writeprotected"
4) im mad because i did this many time and it didn't help....
pls teach me.....
my email:hihichew@hotmail.com
if posible u could email to me please,
thank you.
Posted on Jun 02, 2009
  • 8 Answers
SOURCE: Please can you help me? When I insert memory 2GB
is it compatebal with the psp
Posted on Jun 11, 2009
bob_computer
  • 3153 Answers
SOURCE: SanDisk Usb Flash 8GB unable to format
TRY SOME OF THESE STEPS BEFORE YOU THROW IT
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 17, 2009
SOURCE: Please insert a disk into Drive E
Transcend provides a online recovery tool.just download that and format your pendrive with it.....that will solve your problem 100%.....
Posted on Dec 31, 2009
laikexpert
  • 281 Answers
SOURCE: detecting , not open shows err Please insert a disk into drive D:
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 02, 2010
I CANT FORMAT MY MEMORY CARD....I DONT KNOW HOW TO FIX IT.
  1. Open control panel.
  2. Open administrative tools.
  3. Open Computer management.
  4. In the left column click disk management.
  5. This populate all the disk present
  6. Locate your memory card
  7. Then you can delete the partition entire and build new one
  8. You can format with Fat Or FAT32 file system
  9. Do not perform quick format.
Another options are available to format via cmd
To do that
At the run Menu type:CMD
then a command promt window will open
Type format x: /fs:fat32
Note that x is volume label (memory card drive label may d, e or f)
ok
try this
Feb 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
I have an 8gb maxell usb memory stick which asks for passwords with ''Unlock an Enhanced memory stick''. I put in the password but nothing seems to unlock it. There is nothing on the disk as it is a few...
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
3.b) Format memory stick
Feb 06, 2010 | Electronics - Others
I deleted Photos from my 2G Memory Stick Duo on my computer, now the camera says there are no images but has only 100mb memory space available
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format Memory Stick Duo
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 25, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
The problem is with my 1GB memory stick. I don't
Check your computer
with antivirus and antispyware program and format 1GB memory stick.
2. Format 1GB memory stick
Jan 21, 2010 | Electronics - Others
How to use a flash drive
It doesn't matter to which USB port you connect the flash stick.
It should appear as an additional disk in My Computer, with a total capacity close to the rated one. To identify which drive letter is it, observe the open My Computer window and plug (or unplug) the stick - it will be the drive that appears (or disappears respectively) from the screen.
How to use it? I prefer not to use any special backup software, which I find not very intuitive. I just make folders that make sense for me, and copy the files (that I want to back up or transfer to some other location) to these folders.
Dec 29, 2009 | Computers & Internet
'Please insert a disk in to the removable disk drive k"
Same thing happens to me .My 8gb silicon usb flash drive got the same error, please insert a disk into drive, the name of my drive weas changed into Removable Disk instead of the name(Sanctuary which is what i used) It said ni media ,and it was registered as XXXXXXXX U167CONTROL USB DEVICE can anyone help me with this.
Nov 25, 2009 | Electronics - Others
Pendrive markvision
format again by
start menu>
all programs>
run>type cmd
format it by typing.if your drive is f then type in dos
format f:
if your drive is g then type
format g:
go to my computer on windows vista right click on my computer click on manage
click on disk management
right click on your disk and format it
Mar 25, 2009 | Transcend (589307) Media
Sandisk m2 2g card got currupted.....
format it on the PC with FAT16 type file format
Dec 09, 2008 | SanDisk 2GB Memory Stick Micro M2 Memory...
Sandisk m2 2g card currupted
the write is corrupted..myt due be due to some hardware error..!!
HOW D OI FORMAT A SONY 2G MEMORY STICK
The code is 0000. im no expert. but i think this is it.MMMMKAY!
May 24, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Electronics - Others Logo
613 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
