Question about Brother IntelliFAX 4100 Laser Fax
Shadow of printing elsewhere on envelopes and other pages
Mostly seen when I print envelopes. I have what looks like the toner isnt drying because I will have a light image of the address to the left of the original print.
What can be done?
    Genius:
  • 2,120 Answers
Have your FUSER replaced.
Posted on Mar 06, 2009
Samsung clp 315 printing shadow images
Ghosting appears often because of bad toner. If cartridges have been refilled, they have wrong toner in them. If drum has worn out it will usually tell you. All parts for this machine cost too much. If toner is not the problem, probably best to get a new machine rather than pay to get it fixed. Brothers are cheaper to run.
Sep 01, 2014 | Samsung CLP 315 Laser Printer
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
Feb 01, 2011 | HP LaserJet 4ML Printer
I have an old workhorse that has never had problems. HP Laserjet 5 - printing a shadow down the left side of page. Advice?
Check for wear, damage or scratches on the drum. Try wiping the drum very gently with a very soft dry cloth. Never use any solvent or chemicals on the drum. If any damage or marls are seen on the drum, or there is a slight build-up of toner on the edge of the drum, you will have to replace the toner cartridge/drum assembly.
Jan 29, 2011 | Office Equipment & Supplies
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
HP Laserjet 1100 - prints test page text & image on envelopes
try to uninstall the drivers and reinstall them it should fix it
Jul 20, 2009 | HP LaserJet 1100 Printer
HP CP1515N ONly prints half a page
There are 2 reasons for this either the ink is drying out nor your page settings isnt set to the correct size of the paper you are printing to.
Apr 19, 2009 | Canon PIXMA MX310 All-In-One Printer
Shadow print from 2200d laser printer
This shadow, or backgrounding, is generally caused by excess debris remaining on the drum. This is mostly caused by the wiper blade not dislodging all the waste toner. You will need to replace the cartridge (C4096A).
Mar 22, 2009 | HP LaserJet 2200D Printer
Prints dry colour powder on paper
You aren't fusing (melting) the toner to the paper. The probable cause for this is having the "envelope feed" levers in the "envelope", or up, position. This leaves a wider path for the paper, which does not allow the toner to be fused onto the paper properly.
The envelope feed levers are the two small green levers at the rear of the printer, one on each side, that are visible when the printer's top is lifted.
Dec 16, 2008 | Xerox Phaser 6120/YN Laser Printer
Printer leaves look of burn marks as granular shadow over page
If the paper really is being burnt then there is a fault with the fuser roller temperature control. This would also make a smell. If this gray sheen is made of toner then this may be the laser unit not putting out enough power. The optics could be dirty. One thing to try before attempting repair- Reduce the print density to minimum in the printer advanced settings. This increases the Laser power. Good luck
Sep 22, 2007 | Lexmark C524 Laser Printer
Brother IntelliFAX 4100 Laser Fax Logo
89 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
