Rebooting system recovery disc
I was reinstalling my system recovery disc and it is asking me for a file location: The message asked me to type in the path for file 'asms' on WINDOWS XP Professional Service Pack. What is this file location? I don't know and the computer won't boot so that I can search for it. Thank you.
Computer keeps restarting
The system need to be reinstalled or fixed by experienced technician. But you can try to do Recovery again, choosing Advanced options, to see where is the problem.
Jul 21, 2013 | Computers & Internet
The original 250gb HD failed. I replaced it with a WD 320gb HD. I have tried to load the Lenovo restore DVD and a new, never used, Windows 7 DVD. Both drives take EXCEEDINGLY long to load (the Windows 7...
Welcome to FixYa!
It depends on how you used the recovery disc that you have, reinstalling operating system will not take 23 hours just like what you said so there's a possibility that you're having problem with the Operating System on your computer. Unfortunately, Lenovo will not provide a product key for the Operating System since the an OEM version. What you can do is reinstall the Operating System using the One Key Recovery Sofware or the Recovery Disc that came with the computer. Follow these steps for you to be able to reinstall the Operating System using the One Key Recovery.
1. Turn off the computer.
2. Press the little button near the power button, it usually do have a drawing of an icon that looks like a horse shoe or a headset.
3. There will be a window that will appear which do have three option, One Key Antivirus, One Key Recovery and System Setup. Choose One key Recovery.
4. There will be another window that will appear which do have two option, Restore from initial backup and Restore from user backup,Choose Restore from initial back up
5. It will asked you if you want to continue, Just click on OK or YES.
6. Once done, Reboot the computer.
For Recovery Disc,
1. Insert the disc inside the drive.
2. Turn off the computer then turn it back on and keep on tapping F12
3. There will a window that will appear which do have three options, HDD,ODD/DVD/CD, and NAT, choose ODD/DVD/CD
4. It will asked you to press any key immediately, you will need to press any key immediately so that it will boot from ODD.
5. It will asked you to choose a partition, choose Disc 0 partition 1
6. Reboot computer once done.
I hope this information will be helpful. Thank you for using FixYa...
May 16, 2011 | Lenovo IdeaPad Y510 Notebook
How to factory reset?
Hello and thank you for using Fixya.
First, You will need to make the recovery discs which are created using the built in program from your computer. Copy them onto a blank CD/DVD. Now insert the newly created restore disc to restore your factory settings by rebooting from the hard drive. Turn off the PC. Wait a minute. Now hold down the 0 (zero) key and push the power button once. A screen message will appear after a few seconds. Choose to reboot from HDD. (or you can choose to reboot with recovery disks using the DVD drive.) Follow the instructions. It will take about two hours to reinstall your operating system.
If you have any more question feel free to ask
-michael34
Mar 08, 2011 | Toshiba Satellite L500 Series Notebook
Need to copy of recovery discs with operating system for the vgnnw240f
Recovery disk can be save as system back up files and then reinstalling it again. Try to ask your friend to give you system back up files(same operating system) which can be save using external Hard drive or USB flash disk and install this back up to your computer to work again or if your computer is not working try to boot your computer in CDROM and use the back file to restore your system.
Dec 28, 2010 | Sony VAIO VGNNW240F Notebook
Asus F8P: Windos could not start because the following file is mission or corrupt. Windows\system32\config\system.... I don't seem to have the original setup CD-Rom Andrew
let me guess that you are using windows XP as operasting system.
Check whether you can borrow a windows XP disc from any of your friends or relatives
You wont be able to purchase this disc as according to micorosoft windows XP is end of life (EOL)
The disc will say "microsoft windows XP"
Once you have the disc boot from this disc you need to go to recovery console
You might be asked which windows installation you want to logon to
press 1 and press enter
it may ask for an admonistrator password
leave it blank and hit enter
now you will be at C:\> if it is not type this command c: hit enter that will take you to c:\>
here you need to type the following command
chkdsk /p
once it is completed type exit and while the system is rebooting choose the option that says
"last Known Good Configuration"
This will fix the issue
Dec 26, 2010 | ASUS F8P-B1B PC Notebook
Cant access system recocery
If you can find the operating system disc you should try reinstalling that. If that is the disc you are missing you can borrow one from someone and still use the key that is taped to the side of the desktop.
Insert the OS disc on startup and when prompted to "press any key to boot from CD" do so. If you are not prompted you will need to enter your BIOS and change your boot priority in the boot menu to boot from CD-ROM first.
Once the PC boots from the windows disc proceed through the menu until asked to run a repair. This will install a fresh copy of the windows files on your PC. It asks you if you would like to keep the old ones and just rename the folder just in case you still need them.
This will not remove any documents or personal files, it will only reinstall the operating system files that may have become corrupted.
Jan 06, 2010 | Compaq Presario 5000 PC Desktop
My emachine loads up PCI device listing and cant exit.
You may have to get a copy of windows xp and boot to it and reformat the hard drive and then reinstall windows. I hope this helps.
Jul 27, 2009 | E-Machines eMachines Desktop PC
Win 32 application
You didnt specify the version of Windows your using however,
This issue is commonly caused by corrupt bad, or missing files, The program is not compatible with your version of Windows, or your hardware is incompatible. You must meet or exceed all system requirements for the program. If you downloaded the program from the internet verify the download was not corrupt. If installed from the cd-rom, check the disc is clean and free of scratches and reinstall. Replace missing windows files using SFC.
Have your Windows Cd available.
Open Run-->Type SFC /SCANNOW
This command will run the windows file protection utility that will replace missing or corrupt windows files.
Good Luck
Apr 02, 2009 | Microsoft Windows XP Professional
Can't extract files on System Recovery Disc 4 for Compaq Presario model 6350US
At this point, you can try to clean your disk # 4 and see what happen,
or try to make a copy of disk # 4 (if you can copy the disk) and try again.
or
1) Contact your customer support and ask for a new set of disks.(or only # 4)
or
2) Boot your computer with another OS disk (win XP)
or
3) Boot your computer with some utility disk
Oct 19, 2008 | Gateway MX6421 Notebook
Rebooting my Dell Inspiron 6000 Laptop
rebooting a laptop means turning it off then on again not to it's original state, your are using a recovery disc which will reformat your drive the reinstall windows, loosing any documents or files you have saved.
The serial or product key code for windows is always on the underside of the laptop
Aug 15, 2008 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
David Payne
David Payne
