Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trinitron (analog) picture suddenly ''pulsating''
Picture jumping with broken horizontal lines. sound is ok. Same effect viewing DVD or cable.
    Sergeant:
    Champion:
  • 318 Answers
The verticle has a problem check the following around that area
capacitors
zener diodes
resistors changing values
what is happening is that a voltage is not constant, its varing
Posted on Apr 09, 2009
Sound but no picture on sonny trinitron
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
May 13, 2016 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony pre-LCD 32" receives power and directly
I would take your A/B switch out of the line. And get yourself a good reciever to channel every thing.
Jan 04, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a horizontal color line across the screen...have sound .This is on Video 1
If you are comfortable working inside the set and can solder, try resoldering both the vertical IC and the input jack connections. The vertical IC will be a small flat IC attached to a heatsink with about 9-11 pins. It will be marked LA7837 or something similar.
Let me know the results.
Dan
Apr 15, 2009 | Televison & Video
Horizontal color line across the screen
Most likely a bad Vertical IC or bad connections on the vertical IC. don't continue trying it on. If you have a bad connection it could do more damage. You also could damage the CRT ( picture tube ). If you remove the cover and look at the bottom side of the PC bord with a good magnifiing glass you may see what looks like rings around the leads comming from the Vertical IC. The Vertical IC is mounted on a heat sink usually towards the front of the set looking from back. If you do see the rings around the leads try reheating with a solder iron. If this dosen't fix you most likely need a new IC.
Picture went blank during viewing
Not too many things you can do without an understanding of the circuitry in a CRT TV but there is a good chance that the failure has occurred in the high voltage area and a few things need to be measured there to find which of them has failed. Catastrophic failure of the CRT (picture tube) are rare anymore but do happen now and then.
If the flyback (horizontal output transformer) has bitten the dust, they are becoming hard to find and much more expensive than 10 years ago. Additionally, those don't normally fail alone but are killed by or kill, other components, which also need to be verified before replacing anything.
Even with the HV section dead, there are lethal voltages present inside when turned on and not always in places that look dangerous.
Sep 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Color lines/no picture
Well, if you still had a good picture before it happened, I would repair it.
This problem is usually a small part in the horizontal circuits. The service charges may be high, but the parts cost should be low.
This is a large heavy set, If you take it yourself to a shop you will save on the service call.
Jan 13, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Component Video Problem
The problem is not with your tv it's with your dvd player. You have to go into the setup on the dvd player and change your output setting to component.
Jan 18, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony TV - Loss of half the picture
sarge, it sounds like the vertical output IC went bad on you. If it was a bad connection or a bad capacitor, your picture would have been a straght line across the screen. They call the output section of the IC a push-pull type of amp, so the top half of the sweep IC went out. If you have had some soldering experience, and or experience with solid state repair, locating the bad IC and replacing it is no big deal. If you havent, stay safe and call in a pro to assist you in this repair, as there is alot of high voltage inside this puppy that is still present even if the set is unplugged. It should not cost an arm or a leg to repair this set. An honest repair on a set like this if you take it in should not exced 125 to 150 bucks. Good Luck PS Please dont forget to rate this thread.
Oct 22, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
147 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
