Question about Goldstar MV-1526 Microwave Oven
Looking for new door for microwave - Goldstar MV-1526 Microwave Oven
  • camaras4 Mar 29, 2009
    need a new door for microwave in white
    MV-1526W
    Champion:
  • 246 Answers
Go to www.applianceart.com and purchase their vinyl option in white to cover your microwave door and get the look you want without having to go through the hassle of replacing the door.
Posted on Aug 29, 2011
What color is it?
Please reply via email: info@drop-click.com
Posted on Mar 14, 2009
Anyone perhaps know why my LG microwave LMV1683ST will not function with a new door assembly?
I hate to be the bearer or conduit of bad news, but IF the old (broken) door works, but the new door does not, the new door may not be the exact replacement part! Otherwise, the operation would be identical. Clearly, the problem is not with the microwave circuits because they work fine with the original door! Is there a flexible circuit strip that plugs to or from the door, to the control board in the main unit? If so, does it look any different than the original counterpart to it?
Apr 18, 2017 | LG Microwave Ovens
Tip
HOW TO REPLACE THE DOOR OF A MACROWAVE OVEN
GeneralElectric is internationally known as a premier manufacturer of ranges,ovens, stove-tops and various other household appliances. ConsumerReports ranks General Electric appliances high on functionality andtheir low rate of repair. Currently, manufactures microwave ovensand wall ovens. Microwave oven doors are designed to be removed andreplaced by professional repairmen because a "leak test" must beperformed upon replacement to ensure ions are not coming off themicrowave's magnetron. With wall oven doors, removal and replacement bythe owner is a straightforward task that is safe for any owner tocomplete.
Here are step by step Instruction on how to fix in your microwave door below.
step1.
If your microwave door is cracked or the latch is broken, you may be able to replace it instead of purchasing a new microwave. Check the manufacturer's website to find out how to order a replacement door that is compatible with your specific make and model or visit any technician store that deal with microwave and oven around your local area to get one.
step2
Your owner's manual may also list a part number, which you can use as a reference when looking for a new microwave door.
step3.
Difficulty or note able part : Moderately Easy Instructions material needed Replacement door with Screwdriver a technician tool .
step4.
Unplug the microwave and set it on a table or workbench. If you have a built-in microwave, you may have to remove some mounting screws or retention clips to get the microwave out of the support bracket.
step5.
Open the door and take out the glass tray.Pry off a corner of the plastic panel on the inside of the door with a screwdriver or butter knife. Once it is loose, work the screwdriver or knife all the way around the glass and remove the panel.
step6.
Ask someone to hold the microwave door as you disconnect it from the hinges.
NOTE:
Depending on the design of your microwave door, you may have to remove a set of screws or slide a pin out of the hinge to release the door.
step7.
Remove and discard the old door. Have your assistant hold the replacement door up to the hinges.
step8.
Attach the door to the hinges by reversing the previous step. Snap the plastic inner panel into place around the glass.
step9.
Move the microwave back to its original location. Insert and tighten the necessary mounting screws if you are working on a built-in microwave.
step10.
Set the glass tray back inside the microwave and close the door.
Good luck.
Thank you and thanks for using visiting fixya.
on Oct 27, 2010 | Microwave Ovens
Kenmore microwave model 665.69682992. I am attempting to replace the door on this model. I ordered the new door but find that the hinges are installed in the new door and cannot figure how to get the new...
I am looking to replace my Kenmore model 665.61612100 combination microwave with an updated model of the same size and specifications. Any suggestions???
Sep 08, 2010 | Kenmore 62622 Microwave Oven
Microwave needs a new door. How much should the
Please contact a appliance parts supplier in your area for a price for this door. Is this a "Viking" device? You dont give much detail on this.
FixYa.com does not sell appliance parts though there are appliance parts advertisers here.
You may also want to consider posting this question in the "Local Repair" section of this web site. There, local to your area repair shops can contact you directly.
Thanks for your interest in FixYa.com
Jan 18, 2010 | Microwave Ovens
I need to replace the door on the microwave. I have a new GE Spacemaker Excel Microwave with a broken handle and door. I want to put my "old" microwave door on it.
Hi First I do not recommend replacing the new door unless you know it fits exactly like the old one and the wattage rating is the same and the seals and door locks are the same. However are you just wanting to change the face plate so it will match your kitchen then that may be do able. To find out you need to look at the wattage output of both units to see if they are rated the same, however you can go to this web site. Type in both model numbers and look at the two different doors if they have the same parts number you can change it, best bet is to call them and ask if they are interchangeable. If you then decide to tackle the repair get back to us so we can tell you what to do and not to do in order to replace it. Hope this helps. http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1640SJ
Dec 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dacor microwave model DCM24s broken door latches
Many times restaurant supply houses can have what you are looking for in terms of hinges. However, when the hinges, seals, megatron tubes go....generally its time to go shopping for a new unit!
Nov 09, 2009 | Dacor DCM24SS Convection Microwave Oven
Need to replace broken door handle. Cannot get to screws inside door to release broken handle and replace with new handle.
Look for a removable insert around the inside window. If not there may be screws along the outside edges to separate the door sections. Eric
Aug 02, 2009 | GE JVM1650 1000 Watts Microwave Oven
Front Plastic door is cracked and needs replacement.
Do not use a microwave with a cracked door as it could be emitting dangerous microwaves.
Sadly the cost of replacing the door would be more that the cost of a new microwave. Look for a good sale and treat yourself.
Jun 11, 2009 | Microwave Ovens
Microwave
The door can be replaced, just call the service center. Not too sure about the spot on the back panel though. However, it may work out cheaper to just buy a new microwave altogether...
May 21, 2008 | GE Microwave Ovens
Microwave oven
You'll need a new door handle.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 23, 2007 | Jenn-Air M439 Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
