Question about Bose 3·2·1 II System
I have a sony PS3 and a Bose 321 gs series 2 sound system... how do i connect them to my Phillips 52pfl7403d/f7? I can get the PS3 connected just fine but I cannot figure out how to get the audio to play from the Bose. Any ideas?
U have to go to radioshackand get a 1/8 to dual rca y-adapter then u plug it in to ur tv , if its a philips like u say itis it has a audio out put for headphones on the left bottom corner on the back of the tv, just plug it in and then lower the volume on the bose system and on your tv remote press menu, tv menu will come on on the tv screen go to it, or press ok on the remote, on tv screen will say tv setting press ok on remote, go to sound, go to headphone volume, put it on 60 its the perfect setting on for your tv DO NOT go over 65 it will distotion the equilizer on the bose, well this work for me but if i find out an other way ill let you all know
Posted on Apr 04, 2009
Connecting a turntable to a Bose 3.2.1. Series II
Bose 321 GS Series II DVD Home Entertainment System is a newly redesigned, sleek media center that includes a DVD/CD player, AM/FM tuner and inputs for three additional sources. The 3 2 1 GS Series II system now has even greater ease of use and setup. The 3 2 1 GS Series II system is for customers who want the benefit of home theater sound but would prefer the simplicity of two visible speakers, a hideaway Acoustimass module and fewer wires so they don't need to run wires to the back of their room. Media center plays - DVD video (including progressive scan formats), AM/FM, CD, CD-R, CD-RW, digital 5.1, and MP3 files on CD AM/FM radio includes 20 presets, scan and seek Three audio inputs with both analog and digital coaxial jacks, and one optical digital audio input, provide greater setup flexibility Dimensions - media center, 31/6H x 133/4W x 99/10D (8.02 x 34.93 x 25.27 cm); speaker arrays, 21/2H x 51/2W x 41/8D (6.4 x 14.15 x 10.52 cm);module, 141/2H x 83/4W x 191/8D (36.7 x 22.2 x 48.5 cm) Weight in carton - 44 lbs (20 kg) One-year transferable limited warranty
and from the review
Audio-input connectivity is a bit more robust. You can connect three audio sources through analog or digital jacks. The system is compatible with MP3 CDs and can decode Dolby Digital and DTS surround soundtracks from DVDs and external sources.
Bose 3 2 1 GS Series II DVD system review
May 14, 2017 | Bose Audio Players & Recorders
Is it better too hook up a optical audio cable from a PS3 to a bose 321 series III or to hook up the optical audio cable from my TV audio out to the bose 321 system?
Hello, its always better to go the shortest route this would be ps3 right to the bose there are too many menu variables ,circuits, that would be involved if you involve the tv output as well. that theory applies to video as well always go directly from source to load without any additional switches (circuits) when possible.
Feb 22, 2011 | Bose GS Series 321GSIIIBK Theater System
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
I cant get my ps3 to come through my bose 123 system
More specifics would be helpful. To connect a PS3 to a 321 via optical, it depends on what series of 321 you have, but you need to assign the optical connection via the system menu. If this is the series 1 321, it's the settings menu. It can be assigned to any input "AUX etc.."
Dec 11, 2009 | Bose Audio Players & Recorders
My child messed with the settings on my 321 bose
Reset all EQ settings to 0 for a starter. It sounds as if it is EQ'd down all the way.
Jul 05, 2009 | Bose 321GS Series II System
How do i get my playstation 3 to connect to my bose 321 system?
Very simple. Red and White RCAs into any available input on the back of the 321. If the PS3 A/V cable can't separate the audio from the video (yellow RCA) by length of cable then get an RCA extension.
You can also connect this digitally with an optical cable (better sound) but you need to assign the optical cable to an input from your system menu. Your system menu can only be displayed on the TV from the video out of the 321. Go to "media center" and then down to "optical source"
May 30, 2009 | Sony PlayStation® 3 (60 GB) Console
Ipod nano connector for Bose 321 GS Series III
OK! The cheapeast and most simple way would for you is to get a 1/8th inch conector jack that adapts into red/white RCA jacks (it will have a couple feet of wire in between the jacks) plug the 1/8 inch adapter into the jack on I-POD and the RED/WHITE ends into the back of your systems aux inputs RED/WHITE! OR tape input ect! make sure I-POD is turned up! and you may have to adjust I pod eq to get the best sound out of system! (OH you can get this adatper at any radio shack or wall-mart!)
Please take a second and rate this response
THANK YOU!
Jan 19, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
Bose 3·2·1 II System Logo
801 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
