Question about Dell (002TR) Motherboard
Dell xps 400 do not read keyboard, I ried differents way(powered usb, pci usb card) and nothing, somebody can help?
  • 408 Answers
Get yourself a usb to ps2 adapter and try that.
Posted on Mar 05, 2009
Xps 400, no keyboard in dos
Dear Sir:
I am recomending to go www. dell.com and go to troubleshooting section for diagnose the computer, the problem I see is driver some missing. You must need to reinstall. By that reason Run the Diagnose from Dell .
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 12, 2012 | Dell Dimension XPS 400 PC Desktop
What Wireless card to buy
A version that is Wireless N.
You can install a Wireless N adapter card in any available (Open)
white PCI slot, or use a Wireless N adapter that plugs into any available USB port.
1) Dell Support > Studio XPS 8100 Desktop PC > Service Manual,
http://support.dell.com/support/edocs/systems/studio8100/en/sm/index.htm
I would like you to click on - Technical Overview
Now on System Board Components
The number 23 points to the white PCI slot.
The numbers 24 and 26 point to a PCI-Express x1 slot.
You can buy a Wireless N adapter card to fit either a PCI slot, or a PCI-Express x1 slot.
{NOTE* Number 27 points to a PCI-Express x16 slot.
This = NO.
This expansion slot is used for a graphics card, ONLY }
Examples of a Wireless N adapter card for a PCI slot, and a PCI-Express x1 slot,
A) PCI: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4389486&CatId=2701
B) PCI-Express x1:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=788312&CatId=2702
C) USB:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5079829&CatId=2688
Why use anything but a USB Wireless N adapter?
I don't know. They allow me to toot the whistle, but not drive the train.
Information on PCI, and PCI-Express;
PCI:
http://en.wikipedia.org/wiki/PCI_local_bus
PCI-Express:
http://en.wikipedia.org/wiki/PCI_Express
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 11, 2012 | Dell Studio Xps 8100 Desktop Computer
Dell (E210882 Motherboard). No video display when power. Fans running, HDD spinning.
An steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Nov 27, 2011 | Dell Dimension XPS PC Desktop
Blinking amber light xps 420
A Blinking Amber orYellow power button means that the power supply is receiving power from thesource but is unable to properly distribute it to the components. This can becaused by a defective power supply or a defective motherboard. Just to makesure that nothing else is causing the problem, remove any PCI cards like modem,video card, sound card, etc... Remove the memory modules and disconnect cablesto CD/DVD drives. Look at the USB ports to see if any are damaged.
Feb 17, 2011 | Dell XPS 420 PC Desktop
I power upmy dell pc and it startes up then I get a screen that says:DELL DXP051 Series BIOS REVISION A00 KEYBOARD FAILURE Then it goes to a black screen and does nothing. If possible can can you tell...
when you see the error hit f1 and see if your computer resumes bootup. if it doesnt then if you have a usb keyboard try a different one and if you have a ps/2 keyboard then try a ps/2 to usb adapter. if the adapter works then you have a pin issue on your ps/2 connector and just continue to use your adapter.
Jan 30, 2011 | Dell XPS 400 PC Desktop
No color Red, Dell XPS 400, NVIDIA GeForce 7300 LE video card
Mike,
I would recommend for you to try different monitor, so that you can isolate the problem.
If same problem occur, try to plug in your video card into another PCI slot in your computer. Cleaning the gold fingers of the video card with a clean cotton cloth might help.
Use a blower to remove some dust on the PCI slot.
Or try inserting the video card in another computer. If you get the same problem on another computer, you need to replace the card.
Mar 07, 2010 | Nvidia GeForce 7300 LE 256MB PCI Express...
Wireless mouse and keyborad will not work. replaces batteries and hit reset button on mouse and keyboard. can not get access to computer
Sounds like your USB circuit may have gotten fried due to a static discharge (assuming your keyboard and mouse are USB). You can purchase an "add-on" USB pci card or a PS2 Mouse and Keyboard.
Feb 01, 2010 | Dell XPS 400 PC Desktop
Need to install PCI card in Dell xps 400, but can't remove back to get to slots. No tools for 2 little black screws what to use?
You shouldnt need to unsrew anything on the xps 400.. Everything the case opening and the pci card screws should also be a latch!
Nov 15, 2009 | Dell XPS 400 PC Desktop
Dell XPS 400 no power to usb or pci slots
I have had the same problem with my dell xps 400. What I did was purchased a usb power hub and that solved the problem for me. SAved me from buying a new mother board.
Sep 09, 2008 | Dell (002TR) Motherboard
Its a Dell XPS 400
There is no way around a bad keyboard, you will need to get a new keyboard to continue.
Feb 19, 2008 | Dell Dimension XPS 400 PC Desktop
Dell (002TR) Motherboard Logo
302 people viewed this question
Alun Cox
