Question about Black & Decker Cst2000 12 - Volt Cordless Grass Hog 12" Trimmer/Edger with Auto Feed Spool Afs
The battery casing will not open. I push on both
The battery casing will not open. I push on both side buttons, I have had another person try also, but cannot get it open to change the battery. Any suggestions?
  • vanessaeden Mar 05, 2009
    Thank you! I am on the phone with them now.
  • kristyrier Apr 18, 2009
    I am also having a problem opening the battery casing to charge the battery on this same model. Unfortunately, I am unable to locate the manual and the service number is only operational M - F and I have decided to trim the grass on Saturday afternoon. Any one out there have this model?
Chron startstop button stuck
put a spot of WD40 down the sides of the button then try pull and pushing with tweezers
Mar 27, 2015 | Swatch Irony Chrono #YOS414G Watch for Men
My asus tablet wont turn on
The battery connector in the Nexus 7 (2012 model) is notoriously problematic. Sometimes dropping the device can cause issues that prevent the Nexus 7 from charging altogether. A hard reset may not work. Fortunately, it is quite easy to fix.
However this will void your warranty.
Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.34689589-4d42-4ff6-a950-042de234083f.png
Nov 04, 2013 | ASUS Tablets & eReaders
My Nexus asus will not turn on even though it be charged over night Had it since Nov 25 2012
You could try to do a hard reset. Press and hold the power button and the volume up button simultaneously for 10-30 seconds and see if the device will then turn on.
Hope that helps!
Aug 05, 2013 | Universal Google Nexus7 7"" Capacitive...
My nexus 7 will not turn on
You can try a hard reset. Hold down the power button and the volume buttons at the same time. The device should then power on and you can follow the on-screen prompts.
Hope that helps!
Mar 18, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
How to open it to clean it
small form factor desktop cases. With these you just push the buttons at the back on each side of the case and it lifts up there's a button on each side of the case towards the back.. press in and pull open the case, it's easier to open one side at a time.
(it's a hinged case design, lifts at the back and hinges at the front.)
hope this helps
Nov 06, 2009 | Dell GX280 Tower PC Desktop
How do i replace the presario v2000 battery? I cannot take the old battery out.
The cover may have been jammed if the laptop was dropped.
1. Use a stiff letter opener and run it along the edges of the battery cover.
2. Move the mechanical lock switch to open
3. Use the stiff letter opener to pry the battery out.
4. The goop you find is probably dried-up coffee, or some energy drink...
Sep 28, 2009 | HP Compaq Presario V2000 Notebook
Remote not used for 9 months...some buttons don't work...some do...installed new batteries. Took batteries out and pushed all buttons...reinstalled but some buttons still don't work
open remote, remove rubber button, clean the carbon contact side with soap, hot water and toothbrush, dry, reassemble. Case of coca cola...
Sep 24, 2009 | Televison & Video
Do not know how to open a Dell Dimension 4300 case
Lay your computer on the side there should be a big button on top and also one on the bottom push both of these buttons and pull the sides back toward you.....it really takes two people to do this...
If this is not your type of case you can go to the dell website and they have instructions for different cases.
Dec 06, 2008 | Dell Dimension 4300 PC Desktop
Open Gateway ES2 300X case
Most of these towers are vertical style, therefore the big button is just to the left of the Gateway symbol. Push it in and pull the left panel away from the case.
Apr 30, 2008 | Computers & Internet
Black & Decker Cst2000 12 - Volt Cordless Grass Hog 12" Trimmer/Edger with Auto Feed Spool Afs Logo
118 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
