Question about Canon PowerShot SD1000 Digital Camera
Camera Frozen - Canon Powershot SD1000
After charging the battery fully, I put it in the camera, turned it on and took a couple pictures. As I flipped from view mode to picture mode, the camera simply turned off and the lens was stuck expanded. I removed the battery, charged it again, inserted it later, and the camera still won't turn on. Help!
  • btalbs Mar 06, 2009
    I'd have to buy another battery (it is the rechargable kind). I could try it!
  • 78 Answers
Have you tried using a different set of batteries ?
Posted on Mar 05, 2009
  • Mr fix.it Mar 07, 2009
    I would try the batteries somewhere else first and see how they behave however a set of new rechargeable batteries are always handy.
    I have had a similar problem but the camera was under rouch humid conditions and found that the board was fried.
My Canon powershot SD1000 screen isn't working. Iv'e charged the battery but when I turn the camera on, the screent is black. It won't take any pictures
It's very likely the CCD sensor that needs to be replaced. If you need to have it serviced, this place is excellent for the Powershots and not much at all if you need to have one fixed: www.camerasandparts.com
Before having it fixed, press the DISP button first and make sure you just didn't turn the display off. If you end up needing service for the Canon, that place above is really great for these cameras.
Apr 15, 2012 | Canon PowerShot SD1000 Digital Camera
When i try to veiw photos the camera turns off Canon Powershoot SD1000
Ensure that the battery is fully charged. If the battery is fully charged and the problem continues, export all the photos to a computer and format the memory card.
If there is an issue with the memory card, formatting may resolve the issue.
Mar 01, 2011 | Canon PowerShot SD1000 Digital Camera
My canon powershot SD 1000 is taking fuzzy pictures
Please make sure that you're using fully charged battery pack.
Remove the battery and reinsert after 1 minute.
Reset the camera by following the reset procedure from the manual of the Camera.
If the issue persists again, service is required
Dec 31, 2010 | Canon PowerShot SD1000 Digital Camera
Canon sd1000 camera won't turn on. battery is fully charged.
Make sure or Check out following thing :-
  • Direction of your battery might be wrong, Check out and put it again.
  • Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
  • Check whether Memory Card/Battery Cover is properly closed.
  • Load new or fully charged battery.
  • Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 05, 2010 | Canon PowerShot SD1000 Digital Camera
Camera just died mid-use. Battery is fully
They do, occasionally. Try removing the battery, leaving it out for an hour or so, and then put it back in again. If the manual says that there is a reset use that, but removing the battery usually does the trick.
Jan 03, 2010 | Canon PowerShot SD1000 Digital Camera
Flash Does not work. canon sd1000
This happened to my SD1000 and I followed the step by step instructions shown here:
http://www.ifixit.com/Guide/Replacing+Canon+PowerShot+SD1000+Broken+Flash+Unit/7778/1
and when I got to step 15, I found that the small plug that connects the flash to the camera body had been disconnected when the camera had been dropped. I simply pressed the connection back in tight and reassembled the camera - and it works. Maybe this happened to yours too??
Dec 10, 2009 | Canon PowerShot SD1000 Digital Camera
My Canon PowerShot SD1000 shoots completely black pictures. The lens is open and there is no damage to the lens or the screen. The battery is fully charged and I've even tried a different memory card. It...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 06, 2009 | Canon PowerShot SD1000 Digital Camera
My Canon Powershot SD1000 has a fully charged battery but won't turn on at all.
Does your camera turn on when it's in playback mode? I have a similiar problem with mine. It only turns on in playback mode.
Sep 25, 2009 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
249 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
