Question about LG 700M 17" CRT Monitor
Having turned on computer, windows loads, however desktop page shows horiontal on screen
  • 52 Answers
Try to fight through this. This would be a setting either in your monitor, or in the display program you have installed on your computer for your monitor. Turn your monitor sideways if you need to, to fix this problem.
Posted on Mar 05, 2009
Fujitsu siemens scenicview b19-3
hi you must disable the main screen in properties section of the display panel then when you start up the computer the screen will not activate until windows has loaded and found and installed the screen drivers after that all should be good to go if you need any further help don't hesitate to contact me :)
Feb 07, 2013 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Screen lights up and goes back off with power still on. Ex.: When powering up computer, screen will show page for a few seconds then disappear untill a differant page comes up, show new page for a few...
Hi Larry,
I see that you are having issues with you LCD monitor intermittently showing Video for a few seconds then just dies to a black screen and will show windows in the desktop then go back to a black screen again on the issue ...
I believe that what you are experiencing on the issue is a screen refresh rate setting in windows.
we will need to check you video settings on the system for the issue.
Before we go and change some settings on your system we will need to boot into safe mode first.
1. From Shut down as soon as you turn your system on keep on tapping the F8 key on-top of your keyboard, this will give you the Windows Advance Options Menu.
2. On the List Select Safemode once highlighted press enter once, a bunch o things will show up on the screen this means that windows is loading in Safemode and windows will be loaded but all drivers will not so may encounter a screen that has big Icons and letters on it which is normal.
3. Log-in you windows profile if you have a password setup, once logged in do the following instructions below.
Changing the Screen Refresh rate:
1. Right Click on your Desktop/wallpaper to get the pop up options menu, click on personalize.
2. In the personalize window click on display lower left side of the window
3. Then Upper Left side of the new window click on Change Display setting then on the next page lower right side you will see Advance settings click on it.
4. you will get a small window click on the monitor TAB you will see there a drop down for the Screen Refresh rate click on the drop down and select 59 Hrtz, then Click on Apply then OK to save the settings work on your monitor.
Apr 06, 2011 | Computers & Internet
If it just keeps loading the operating screen, eg: Windows. It shows that either it is not able to cope with the load that it is given or it has been corrupted.
Open the side panel and disconnect the Hard drive, now turn on.
It should come up with a sign saying, Primary disk failure.
Does it stay stable on this screen for a while, longer than 10 minutes?
Now connect the Hard drive.
You may need to either repair windows or reinstall windows on your computer.
Remember to back up your important information as it will be lost if you reinstall windows.
Dec 21, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
My computer starts to load and when it gets to the blue windows xp screen it stops and does not load into windows.
Turn off your computer by holding down the power button (10 sec.)
Turn the computer back on and Hold down the F8 button at the top of your keyboard, until the start up menu shows, Then select "Last known Configuration that worked"
If that does work you can repeat the steps and try system restore if you have it enabled.
If still unable to load you would need service, or to reinstall windows
Sep 14, 2010 | Dell Dimension 4500 PC Desktop
Tried to do a restore with restore disc that came with the comput
There seems to be a problem with the operating system that is being installed. This often happens if you use the restore disks that came from another computer.
Are you sure that you used the disks that came with that exact computer? Does it flash a blue screen right before restarting the cycle?
Try the restore over again and if the problem persists, you may have to either order new restore disks for your computer or buy a fresh copy of Windows XP.
Apr 11, 2009 | eMachines T3604 PC Desktop
Blank Black Screen After Windows XP Loading Page
the easiest solution would be to re-install windows and hope it is not a hardware problem
Jan 12, 2009 | Dell Dimension 2400 PC Desktop
Computer wont go past a blue error screen
Your hard drive may have quit(died). No good solution other than replace the hard drive. Do you have a restore disk for you computer, to use after replacign the HD?
Here is the website for Acer PC
Dec 19, 2008 | Acer Computers & Internet
My notebook computer seems to be frozen. I only see the screen that shows the windows vista home premium page. I can't see any icons on screen.
Hello! sounds like you need to make sure the Vista Cd is in a drive, shut down p.c. then re-boot you will be asked to boot from cd by pressing any key. Let windows load files then you set location and keyboard layout the next page will ask for full install/upgrade or REPAIR? try the repair item.
Good Luck!!
Paul 'W'
Dec 01, 2008 | HP Computers & Internet
No icons..nothing!?!
Try resetting the desktop. Right click on the desktop, click properties, then open the desktop tab. Change the desktop picture and see if that works. If it doesn't try a system restore. You will be able to access the start menu by pressing the windows key. If these don't work you'll need to run a system repair with your recovery or operating system disc.
Jun 14, 2008 | Gateway MX6025 Notebook Computer...
My computer starts but before booting it shuts down.
You may have lost part of your windows program. If you have a system restore disk, you can run a system restore and probably fix your problem.
Some of your windows files have gotten deleted. When windows gets to this point all windows knows to do is restart. A virus can cause this problem.
Mar 16, 2008 | Gateway 310S (2900621) PC Desktop
LG 700M 17" CRT Monitor Logo
59 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
