Question about Salton EX20 Coffee Maker, Espresso Machine
Machine makes coffee very slow. I have been using for 1 year.
I have tried cleaning the parts on the outside. Still works very slow. How do you clean the inside? Or could there be some other problem.
    New Friend:
  • 18 Answers
Mix 3 parts viniger to 1 part water and run through it a couple of times. Then run plain water through it twice.
Posted on Mar 06, 2009
Jura impressa s8, the display shows" please wait" and doesn't switch to the Coffee Ready.
This error is because:
1- Flow meter is blocked & not sending signal of water flow.
2- Entire hydraulic system is filled with Calcium deposits and slowed down flow of water.
Solution:
1- Open the machine and manually clean flow meter. It is located between the water tank & the pump.
2- Follow this by manually descaling the machine. Seelink. Do not use automatic descaling method suggested by Jura.
Stop using Filter cartridges as the machine reminders for descaling are silenced by use of filters. Services Unlimited Inc Parts Guru Since 1988
Apr 22, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
My coffer pot gurgles and it takes 20 min to make a pot of coffee!
I had the same problem with a regular coffee pot. The problem was a large piece of coffee ground that was lodged in the water tube check-valve going to the element. This prevented water from getting to the element quickly enough, and what water did get there mostly turned to steam. We had to remove/replace the tube.
Nov 17, 2012 | KitchenAid KCM511 Coffee Maker
The coffee is very slow coming out.we have decalcified the machine many many times,taken the grindchute assembly out and cleaned it,and now we are running out of options Please help
Coffee coming out too slow could be a number of problems.
I'd start with the grinder and make sure it is set to the right settings. If the coffee's too fine it will cause the coffee to come out slowly.
Next it could be a dirty brew group. The internal part of the brew group has a glass ball inside of it which is used to during the infusion process. Take the ball out and make sure that area is all clean.
Restrictions in that area can cause the coffee to come out slower.
Your next possible scenario is the pump. Vibratory pumps do go bad from time to time, and a bad pump would cause the coffee to come out slow.
If its a newer saeco machine with the J style boiler, it could be clogged due to lack of descaling.
Slow coffee can be caused by any one of these issues. Usually it is the first one.... the grinder settings.
A tip is to never go under the 3 setting under any saeco machine as the machines for some reason cannot handle anything lower all that well.
Also remember these machines are ment to produce an "espresso like" coffee, and not traditional espresso. They are not capable of producing espresso that you would otherwise be able to make in a traditional handle machine.
Hope this helps.
Mar 29, 2011 | Saeco Vienna SuperAutomatica Coffee...
Ho do i clean the taming filter n my ura F9
you can not, not with out taking machine apart my mom put coffee in the top powder fill and forgot to push the powder button grinder then put more coffee in and when the piston tried to tamp the coffee in was completely clogged up error code came up , $ 250 to service I completely took unit apart I would not req. in less you are a very tech minded person nightmare of parts all working together but anyway the tamping screen is screwed to the piston and is in middle of the machine water is push from the bottom, thur coffee , thur screen , thru piston, up thur a small hose and falls down into the service head and out the two ports to cup I was able to complete remove coffee and remove screen and clean got machine back online ran cleanning program all ok if machine completely clogs and error code comes up it can not be fixed any other way if coffee comes out slow or you get a short cup of coffee you can run a cleaning program to remove the coffee stuck in the piston area the problem is caused by old coffee grounds sticking to the dosing part this part both puts coffee into the piston and take it out make a cup of coffee and look down the door on top of the machine with a flash light when the dosing door opens up and the used coffee puck is drop into the used bin , if you see used grounds on top of the dosing part then next time you make coffee it will end up mixing with new coffee after a while this can cause clogging . try to use diff. coffees some are ground to fine and most of the problems come from the powder dosing door. by the way I and my mom both have a F9 unit I have had the slow and short problems with my machine but it only happens when I use the powder dosing door good luck to all steve
Dec 31, 2010 | Jura Capresso Impressa F9 Espresso Machine
Water flow has slowed down.
remove the spray head and clean it .also run the cleaning spring through the spray head tube this is what makes them slow down is minerals in the water.
Jul 02, 2009 | Bunn NHB Coffee Maker
Francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Mar 13, 2009 | FrancisFrancis! X5 Espresso Machine
Long brewing time
Clean it out with 1/3 caraffe distilled white vinegar and 2/3 caraffe water. Once it is clean, it should take the normal amount of time and will make slightly less noise since it isn't busy steaming off as much water. Also, double-check the filter basket and make sure it is not slowing down the rate of draining coffee.
Mar 21, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Ventilate
you didnt use the machine for a long time start the machine remove the water container if you have a turker blaster fill with water the hole were the water container goes put the blaster in it and apply pressure and try to ventilate and for descaling the machine use descaler not vinergar. vinegar remove calcium in little piece descaler melt it use 1 part descaling produit 1 part water put that in water container start machine open valve turn it off after a few second let it rest for 15 minute and repeat untill empty do 2 or 3 rinse cycle with clean water it important that stuff is corosif thanks for using fixya pierre
Feb 10, 2008 | Saeco Vienna Espresso Machine
No water ever makes it through the pump
I just got mine working again. There was scale in the outlet port for the coffee basket.
Try cleaning by running through a solution of CLR and water (1 to 4 parts) and keep running until the blockage dissolves and flow is restored. Then run another solution again just to clean it for good.
MAKE SURE TO RINSE OUT THE RESERVIOUR VERY WELL. Should run clear without foam after about a gallon of clean water.
Nov 22, 2007 | DeLonghi EC701 Espresso Machine
Salton EX20 Coffee Maker, Espresso Machine Logo
388 people viewed this question
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gil Shultz
Jay Plesset
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
