Question about Tomtom GO 930 GPS Receiver
Wireless data connections setup
It askes for the Access point name, What name? it askes for a user name? Not sure, my name? and login script? can I leave this blank? I have no idea
  • 515 Answers
You can get this info from your sim card provider...
Posted on Apr 13, 2009
Internet crashes my htc Smart... Help?
The first time you use your device, the Connection Setup displays a notification message to inform you that it will automatically configure your device's data connections, such as 3G/GPRS/EDGE, WAP, and MMS.
  1. On the notification message, select Yes.
  2. If your SIM card supports multiple network operator profiles, the next message displays all network profile choices. Select the profile you want to use, then select OK. The Connection Setup configures your device's data connection settings.
  3. After the Connection Setup completes configuration, tap Restart. Tip: To choose the network operator manually, select Start > Settings > Connections tab > Connection Setup The GPRS/3G settings are preconfigured on your device when you applied for this service with your wireless network provider. If you need to add another GPRS/3G connection:
  4. Tap Start > Settings > Connections tab> Connections
  5. Under My ISP, tap Add a new modem connection
  6. On the Make New Connection screen, enter a name for the connection, select Cellular Line (GPRS, 3G) on the Select a modem list, then tap Next
  7. Enter the Access point name, then tap Next. You may obtain the access point name from your wireless service provider.
  8. When prompted, enter the user name and password. (Check with your wireless service provider if a user name and password are required to connect.)
  9. Tap Finish
Feb 09, 2012 | HTC Cell Phones
Hot to secure my router from my neighbors using them. thanks
click this link to open the router login http://192.168.1.1/
When asked for username use admin and password leave it empty
then goto
SETUP -> WIRELESS SETUP -> MANUAL WIRELESS CONNECTION SETUP -> WIRELESS SECURITY MODE and select "Enable WPA > WPA -> WPA Key -> create your own password and save now if you want to access the Wireless connection you will have to enter the WPA key you just created.
Apr 11, 2011 | D-Link DIR-600 Router
My laptop have broadcom 802.11 g adapter. but IBSS 54g(tm) mode have 802.11b/ 54g auto/54g performence only. so that, my laptop cannot access all access point. how can i solve this?
Greetings - Let's go over the settings in your router:
1) On the Home menu screen go to wireless in the left column 2) Wireless band should be setup as 802.11g 3) Mode should say access point 4) SSID should have a name - should also be the same name used on the laptop 5) SSID broadcast should be enabled 6) ***Important - For now set Authentication to open system. Make sure that is how your laptop WIFI card is setup. You can setup security after you get the two connected 7) Super G mode should be disabled 6) Move one tab on top over to advanced make sure data rate is auto
Try those settings (making sure the laptop settings match) and you should be able to get connected. If not, copy this text and return here and paste in into another request for help and someone will take you the rest of the way.
Good Luck, Mikeywaf
Mar 08, 2011 | D-Link AirPlus Xtreme G DWL-2100AP...
I don't know how to reinstall the linksys access point!!! Our wireless network that we made simply disappeared, so I'm trying to re-make one. However, when I tried that with a flash drive, it couldn't work...
T
o access the Access Points Setup, and the LAN IP address has not changed, then computer must have an IP address of 192.168.1.XXX. If the Access Point is plugged in via Ethernet to a Linksys Router and the computer is also connected a Linksys router via Ethernet, then the PC should already have a correct IP address (unless the LAN IP Address of the Router has been changed). If unsure, please assign the computer a Static IP Address so it will have an IP address in the same range as the Access Points IP Address.
If the Access Point is being connected to a hub/switch/router via Ethernet, then use the cable that was provided with Access Point. If the Access Point is being connected to the computer directly, then a Cross Over cable must be used. Cross over cables can be purchased at most electronic stores.
    Remember: When ever a change is made in the Setup of the Access Point, the Apply button must be used to save the settings to the Access Point.
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Access Point.
      Default IP addresses:
    • WAP11 v2.8 - 192.168.1.251
    • WAP54G v1.1 - 192.168.1.245
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Access Points password (The default password of a Linksys Access Point is admin) into the "Password" field.
May 14, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Need to configure for wirless setupnew dsl line from one isp to another need to set up router for wireless connection
If you are setting up a new router for DSL connection, i presume that you already know the login credentials to access your router's admin interface. By default, depending on your router's model, you can access and configure it at http://192.168.1.1 or http://192.168.0.1 using a web browser and make sure that computer you are using is connected to the router through an ethernet cable.
Default login credentials:
user name: admin
password: admin (or try also leaving it blank)
When you are at the web interface, go to a link known as SETUP and there you can setup your connection. If your DSL provides you a user name and password, then you can also enter them there. Then save your settings.
To allow internet broadcasting using wifi, go to a link known as "WIRELESS" and setup encryption there using WAP, WPA2, or WEP or any other recommended encryption protocol. Through this, you can prevent other users near your place to use your internet connection without informing you.
Feb 04, 2010 | Computers & Internet
I m unable to login my access point because off forget user name
there is one button(black and pin type) in backside or front side of the wirelss acccess point.just press 15 sec.it will automatically restart
Jan 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have problem with connecting wireless...everytime when I try to connect it says my internet info is not accepted...It's keep asking my user name and password but I have no Idea what it's talking about...
Perhaps the request for User Name and Password are from your router? If you do not know the login requirements, might I suggest you redo the setup of your router? Point your Interenet Explorer at http://192.168.2.1 . Log in ships without a password, so just click Submit and proceed with setting your Network Name (SSID) and whatever security you want to use.
Answer: Pressing Enter at login request will get you in to your router. BUT please do as outlined above to secure your router. There is a manual available from router Login as well, accessed as stated above.
Dec 18, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i connect my ps3 to the internet via wireless connection
Please find below:
  1. On the XMB™ home menu, go to icn_settings.gif(Settings) > icn_networksettings.gif(Network Settings) and press the icn_btnx_color.gifbutton.
  2. Then go to icn_settingitem.gif(Internet Connection) and select [Enabled].
  3. Then scroll down to icn_settingitem.gif(Internet Connection Settings) and press the icn_btnx_color.gifbutton.
    Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
  4. Select [Custom] and press the icn_btnx_color.gifbutton.
  5. Select [Wireless] as your connection method and press the icn_btnx_color.gifbutton.
  6. Select the WLAN Setting.
    Choose how you wish to connect the Internet. For most users, "Scan" will be the option to choose.
    wirelesscustom06.gif //
    • Scan - This will scan for any wireless access points in the area. Choose this option if you are not sure of the name of your wireless access point (SSID).
    • Enter Manually - Choose this option if you know the name of your wireless network (SSID) and/or your SSID does not appear if you chose the "Scan" option.
      You will need to contact the person who setup or maintains your network to obtain this information.
    • Automatic - Choose this option only if your wireless access point supports automatic configuration (i.e., AOSS).
      Select the security setting that you want to use and press the icn_btnx_color.gifbutton.
    The security setting varies depending on the access point. Contact the person who maintains the access point for information on which setting to select.
    wirelesscustom07.gif //
  7. If you selected a Security Setting, enter your security key with the keyboard.
    Press the [Start] button to exit the onscreen keyboard.
    Press right on the directional pad to proceed to the next screen.
    The encryption key is displayed as a series of eight [*] no matter how long the key may be. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
    wirelesscustom08.gif //
  8. On the IP Address Settings screen, you will need to select one of the following three "Custom" options: Automatic, Manual or PPPoE.
    PPPoE is usually used for DSL broadband connections that require you to enter a user ID and password. You would normally only use this connection type if you have a wireless access point without a router. It should only be used if you are connecting directly to your ISP without using a home gateway router OR using a router that does not authenticate your PPPoE connection for you.
    To use PPPoE settings:
    • On the [IP Address Settings] screen, select [PPPoE] and press the right directional button.
    • You will be asked for your PPPoE user name (or user ID) and password. You will need to get this from your ISP.
      Note : When entering user names and passwords, keep in mind that User Names and Passwords are often case sensitive, so make sure that you enter them EXACTLY the same as they were created, including the same UPPER and lowercase letters, where appropriate.
    • Once you have entered the user name and password, press the right directional button to continue through the following screens.
    • Enter any DNS and proxy settings you may need.
    • Check your settings to make sure that they are correct.
  9. Once complete, a list of settings will appear. Make sure all settings are correct and then press icn_btnx_color.gifbutton to save the settings.
  10. Press the icn_btnx_color.gifbutton to test the connection.
  11. When the test is complete (usually less than a minute), it will display the results ("Succeeded" or "Failed"). If you have successfully connected to your network, congratulations, you have completed the network setup process.
Hope it helped.
Nov 17, 2009 | Sony Video Game Consoles & Games
How do you set up WAP or other encryption
You can secure your Wireless Network from your ZyAIR Acces Point.
Login to the Access Point as follows (make sure that it is connected to the Computer):
1. Start the Web Browser like Internet Explorer or Firefor or Safari.
2. Type 192.168.1.2 as the URL.
3. Type "1234" (default) as Password.
4. Go to the Wireless LAN Setup option.
5. Set the Wireless Network Password (either WEP or WPA type).
Done.
You may also refer the User Guide of the ZyAIR Acces Point page # from 40 to 60 for more information about this.
Good Luck!!!!!!!!!!!
Nov 11, 2009 | Zyxel ZyAIR B-3000 802.11b (ZAB3000)...
My wireless access point SMC
Thank you cgahongayire.
Follow these steps to retrieve the wireless key:
1) Connect a computer wired directly to your accesspoint.
2) Assign a static IP on the computer with the range of 192.168.2.x (x is any number from 3-253).
3) If it prompts you for a user name and a password, user name is admin and password is smcadmin and click Login.
4) Select Advanced Setup. It will give you the window for the access point.
5) Select Security under Radio Interface 2. You can see which security is set on your AP. If it is set as WPA, the shared key is your network key. If WEP, the network key across the selected key is your password.
Take note that these instructions are if the IP settings of the Wireless AP have not been changed. If it is, you have to ask what is the IP first.
May 06, 2008 | SMC (SMC2555W-AG UK) 802.11a, 802.11g/b...
Tomtom GO 930 GPS Receiver Logo
74 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
