Question about Sony VAIO VGN-NR120E/S Notebook
When lap top turned on, error message saying 'smart network stopped working and was closed. a problem caused the application to stop working correctly. windows will notify you if a solution is available.'
  • 52 Answers
So, uninstall the program. If the computer needs it bad enough than it will ask for you to reinstall it.
Posted on Mar 05, 2009
Updater has stopped working ... error message pop up
turn it off in startup .
clik your start run
type msconfig
look in top right for startups
unchek
SoftwareUpdater.exe apply close restart system
Aug 03, 2014 | Microsoft Windows 7 Home Premium 64BIT...
I'm getting an error that says MFC application has stopped working. It's coming up when I open my PED-Basic. I have deleted the program and reinstalled but i still keep getting this message. When I...
if you have win 7 or vista on your laptop .. the program may be written for win xp .. if so, you can check to see if ugraded software is available from brother for your operating system .. .. or you can load your present software using windows " Compaaibillity Mode" chose XP or whatever operating system the brother software was written for .. right click on your program loader on your disk (setup or whateve) . then select "compatability mode"
Jan 27, 2010 | Brother SE-270D Computerized Sewing...
Windows service executable has stopped working
You do not mention this in your post, but you should try using windows update to update your vista service pack.
Jeff
Sep 02, 2009 | Microsoft Windows Vista Home Premium with...
ArcSoft Connect Notifier has stopped working
ArcSoft Connect Notifier has stopped... Solve Every time I switch on my lap-top,I get the same msg, "ArcCon.ac - Unable To Locate... (More) Every time I switch on my lap-top,I get the same msg, "ArcCon.ac - Unable To Locate Component" in the title bar with "This application has failed to start because ArcCon.dll was not found. Re-installing the application may fix this problem." Can any1 help?
Aug 08, 2009 | Arcsoft Print Creations - Cards &...
Wireless WLAN
go here to download your wireless driver
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WLH&osl=en&catid=&impid=&SystemID=LAT_PNT_PM_D610
Feb 17, 2009 | Dell Latitude D610 Notebook PC
HP all in one printer and vista will not work
Well what i would recomment you would be to uninstall the software for your printer & then reinstall the entire application suit for the printer...
Jan 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Application crash
hello,
i was trying to login on My BDO Internet Banking and the website is crashing everytime i open it...
here is the application error...
Problem signature:
Problem Event Name: APPCRASH
Application Name: iexplore.exe
Application Version: 7.0.6001.18000
Application Timestamp: 47918f11
Fault Module Name: StackHash_fd00
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000005
Exception Offset: 03590cc6
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
can anyone help me please....i appreciate it!!!
Oct 23, 2008 | Yahoo Messenger
MFC Applicaton stopped working
If your operating system is Windows 7, please try this tutorial (it's in an easy spanish): http://autorneto.com/tecnologia/gadgets/brother-en-windows-7/
Else, if you don't have this operating system, please specify which one do you have.
Hope my tutorial helps; write comments on the tutorial's page and here also. Make it known if it worked for you (only if you have Windows 7).
Good luck
Sep 26, 2008 | Brother SE-270D Computerized Sewing...
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Sep 18, 2008 | Computers & Internet
Aspire 5610-2762 Orbicam not working
plz try by reloading the webcam software if you have webcam
May 27, 2008 | Acer Aspire 5610-4648 Notebook
Sony VAIO VGN-NR120E/S Notebook Logo
89 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
