Question about Kenmore 44102 Front Load Washer
Large rubber door seal came apart
The large rubber part that seals the door came out of place. It was pulled from its place along with 2 round wires with springs and pulled into the washing compartment with the clothes. Can this be put back in place without taking the drum apart? Thanks
  • 38 Answers
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
Posted on Mar 08, 2009
How to remove remove rubber seal between door and drum
Hi,the door seal is held in place with a wire with spring on it,just open door get hold of rubber witch is attatched where door closes,
if you pull on the rubber at the edge you will see the wire you will have to get a flathead screwdriver to prise it out,once you take the metal band off just pull the rubber off,then if you pull on the rubber the inside bit of the rubber will come out.
hope this was some help.
Apr 05, 2015 | Zanussi Washing Machines
HOW TO REMOVE RUBBER SEAL
ok if you look around the front of the rubber seal you will see a wire holding it in place on the wire there is a spring if you pull the spring off with a pair of pliers the door seal will just pull off the cabinet then take off the lid and you will see the wire that goes around the door seal where its held onto the drum some have a screw on it and some just pull off then give the seal a good pull from the front of the machine it will pull off quite easy then just push the new seal into place and replace the wire thankyou
Jan 23, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
When moving a whirlpool washing machine (Model AWM 1000) a large thin metal ring (spring-loaded at one end) came out. Where does it go to refit it and how do I refit it? On the machine there's a groove...
It goes to the outer lip of the door opening where the groove is to secure the door gasket. It definitely serve such purpose, not for nothing.
Oct 13, 2010 | Washing Machines
Rubber door seal came off along with metal ring. How do we fix it?
If you are referring to the wire hoop with a small spring, this is the front bellow clamp. The bellow is the rubber door seal. Around the perimeter of the seal where it attaches to the door frame, is a small groove in the rubber. Make sure the rubber bellow is properly seated around the door frame opening, then the wire hoop inserts into the groove in the rubber to hold the front of the bellow affixed to the door frame. Without it and the bellow will eventually come loose and the washer will leak. To reinstall, just follow these steps:
1. Make sure the bellow is firmly seated all the way around the perimeter of the door frame.
2. Begin inserting the wire hoop into the groove, starting at the twelve o' clock position.
3. Work your way around the four and eight o'clock positions. While maintaining some downward pressure to keep the hoop inserted in the groove, pull the spring apart and snap the wire hoop back in place.
A second set of hands may come in handy to hold the hoop in position to get it reseated. Make sure the wire hoop ends up at the 6 o'clock position when you are complete.
If you have any questions, please let me know. I hope this helps you.
NOTE: Overloading the washer with heavy items can contribute to premature wear on the bellow and can cause the clamps to come loose.
Dec 30, 2009 | Washing Machines
The rubber piece in the front of the washer is pulled up and the metal large ring is not in place not sure how it goes back on
If you are referring to the wire hoop retaining clamp that holds the door bellow (rubber gasket) in place, it installs the following way:
1. Install the bellow over the frame of the door opening and ensure its seated and snug all the way around the perimeter.
2. Beginning at the top of the door, start inserting the wire hoop into the rubber groove of the bellow that is located around perimeter of the door frame. Make sure to wire spring points towards the 6 o'clock position.
3. As you work your way around the door frame to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to get it to snap into place.
It would be helpful to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
The wire hoop is known as the front door bellow clamp.
If you have any problems, or further questions, please let me know. I hope this helps you.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3T door seal tear
tear may be from pulling something across it with sharp edges..to replace seall not major job front part of seal held in place with spring ..remove and pull boot away from front edge inlet tub slides out of boot opening rear held in place with LARGE screw clamp a little patience is usually all that's needed ..did 2 today
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
Rubber Seal not Sealing
This seems to be a common problem with front loaders, but there is an easy fix if you follow these simple steps:
1. The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first.
2. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions.
3. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this.
 Good luck and I hope this helps you.
Oct 24, 2007 | Kenmore Elite 45986 Front Load Washer
Washer door seal is loose
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Sep 16, 2007 | Kenmore Elite 45986 Front Load Washer
How to replace rubber door seal
when you open the door you find a this wire clamp round the edge of the door seal, this just comes off with little force, this has to go back on obviously so don't bend it, the door seal just folds back on itself, the clamp on the drum end is often a large thin spring, and that also just pulls off, the seal then also comes away with a little pull, the new seal is fitted with the groove either side of the drum lip, then the spring is put back, take note how all is removed before working on it? the front of the seal is fitted then the wire, close the door to check a tight but easy fit, check for any leaks and correct fitting before leaving machine unattended any time, sound worse that what it actually is, if i have helped rate me,
Sep 16, 2007 | Bosch WFR 145 Front Load Washer
Kenmore 44102 Front Load Washer Logo
281 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
