Question about HTC Touch P3450 Smartphone
The touch screen does not appear to be working
Also I cannot get into settings to attempt to align the screen
    President:
  • 1,223 Answers
Needs to be replaced , if it does not respond to ur taps have u tried aligning the screen does it work at all or no area is responsive on screen then u can try hard resetting it first but after that it will be guaranteed that ur touch panel is faulty which seems like to me
but one thing u shud now do all data will be lost in factory reset process and if ur touch panel is faulty u will stuck up in initial aligning process so pls backup first b4 going ahead sync contacts and sms calender an stuff then try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if u are stuck at align process then it is now pretty sure that ur TOUCH PANEL / also called DIGITIZER is faulty u can get it replaced around 60 $ or so
pls rate me fixya for my diagnosis if u like
Posted on Mar 07, 2009
Htc prophet touch screen issue
for window phones
1. Press the "Home" key and press "Start." Use the directional pad to highlight "Settings," then press the center or "Enter" button.
2. Use the directional pad to select the System tab. Select "Screen," then press the center or "Enter" button. Select "Align Screen."
3. Using your smartphone's stylus, tap the crosshairs as they appear on your screen. Do this for as many as appear, until the calibration tool finishes. Your screen is now properly calibrated.
for Android phone
4. Press the "Home" button or capacitive area, then press "Menu." Tap "Settings."
5. Tap "Language and keyboard." Tap "Keyboard settings." Tap "Tutorial" and go through the steps that appear on your screen.
6. Once this is finished, turn your phone off and on again. Your keyboard has been adjusted, which activates a re-calibration of the capacitive touchscreen. (Capacitive screens are technically far more accurate that resistive, and so a full calibration tool is not included with Android phones.)
Aug 20, 2012 | imate JAMin Smartphone
How do the align hp ipaq 112 screen
go to start-settings-system-screen & Align Screen click it there is a + on the screen touch it 4 times where it appear
Jan 18, 2011 | HP iPAQ 112 Classic Pocket PC
My touch screen does not operate properly. When I attempt to press/touch a character another character appears. Example when touching 1, 4 apperars on the screen. How can I correct or reset the touch...
The touchscreen portion of your display is severely out of alignment. Try finding the utility(use hardware keys) to align the display (under settings). Try to align it. If it is too far out of range, it will kick out your "presses". If this happens, you *might* be able to try a reset, but it likely will not work. Otherwise, your only recourse will be replacement or repair.
Jun 23, 2010 | Samsung Behold Cell Phone
My touch screen froze, so I did a soft reset. This didn't work. So I did a hard reset. All seemed to be going to plan until the 'Align screen' appears. I align the screen as instructed but instead of going...
Whenever you do the alignment touch the spot on the screen with the stylus and hold the stylus on the mark until it moves to the next corner.... this may work
Nov 28, 2009 | HTC Touch HD Smartphone
Pocket PC 2003 Pro unable to align screen
the touch screen plug on the motherboard is disconnected
Sep 06, 2009 | HP Computers & Internet
Touch panel is not working
needs to be replaced , if it does not respong to ur taps have u tried aligning the screen does it work at all or no area is responsive on screen then u can try hard resetting it first but after that it will be guaranteed that ur touch panel is faulty which seems like to me
but one thing u shud now all data will be lost in factory reset process and if u touch panel is faulty u will stuck up in initial aligning process so pls backup first b4 going ahead sync contacts and sms calender an stuff then try this
Mar 06, 2009 | HTC Touch P3450 Smartphone
Align screen
go to start-settings-system-screen & Align Screen click it there is a + on the screen touch it 4 times where it appear ,done!
Aug 07, 2008 | O2 Xda II mini
Alignment of screen
at the time of alignemnet tap the + mark at place where it exist. it appears 5 times on screen. centre and 2 on top and 2 on bottom
Mar 28, 2008 | HTC Touch P3450 Smartphone
Need to show all the contacts and remove the favorite ones
Dear
I am facing lot of problem on alignment of screen .Everytime i align the screen the settings are not saved .Whats the best way to align the screen.
Is it a problem of Touch Pad .
K jam screen align does not work after hundred or so attempts
Well, folks i had the same problem with the damn i-mate K-JAM model but i have figured out its solution. Well screen alignment options will always come on ever reset whether it is hard or normal and further more it would be nail biting for most of us because it doesn't work at all. It seems like some sort of a bug either in Windows Pock PC edition or HTC manufacturing bug. Whatever u call it only we would be the victim of it. Here is the solution.
When the alignment screen comes Just Tag the {+} << in the exact centre it will then move to the top let corner of the screen again tag it from the middle and it will then jump to the lower left corner now don't tag it from the middle instead tag the lower left corner of the screen. It will then move to lower right corner of the screen now tag it again in the middle and finally it will fly to the top right corner now again instead of clicking in the middle just hit the top most right corner of the screen and now u r done. Screen is finally aligned whoops!
Sometimes even when the screen is aligned the touch pad malfunctions if this is the case with you u need to update the firmware like i did just search through Google the i-mate k-jam windows Pocket edition update.
Thanks
Jun 25, 2007 | i-mate K-jam Smartphone
HTC Touch P3450 Smartphone Logo
212 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
