My Sceptre X22 Gamer will only recognize the vga input and not the HDMI. I need the HDMI for the HD Direct TV receiver.
  • Lamarw Mar 05, 2009
    I don't consider that an answer...maybe a sarcastic response!!!
  • 679 Answers
Check to make sure that the reciever doesn't require you to select the output type in the receiver menu. One of mine had choices like component,s video, hdmi, etc. I hope that's all it is. If it's the actual HDMI out, you really should let sceptre fix it. It is difficult to repair these flat panels, and you will void the warantee if you open it. Does that Gamer model use the DVI out from the video card?
Posted on Mar 05, 2009
  • 154 Answers
Do you need a hdmi cable?
  • crysiszone Mar 05, 2009
    there is a convertor for connecting a vga to hdmi, but what I am saying is that it is a waste of money to use one, hdmi = high definition media interface
    vga = video graphics adapter
    hdmi is for high def content ie high bandwidth
    a vga connection cannot supply enough bandwidth, it will work but not like you want it to.
I have a bose acoustomas system. It does not have HDMI inputs on the bose amp which denies me hooking a blu ray dvd to the system to access sound for the speakers thru the amp. I want to have dvd and hdmi...
Simple.Depending on the number of HD gadgets you have,you need either 2 or 4 channel HDMI converter.Connect the HDMI output to your tv and connect other equipments to the various HDMI,VGA,component and composite inputs,including your Bose System.
Dec 04, 2013 | Bose Audio Players & Recorders
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
Where do I plug in headphones?
Looking at the specs for your TV, it does not appear to have the jack for earphones.
You will have to connect an audio receiver to your TV and use the reciever's jack.
Connectivity
  • HDMI ports qty4
  • PC interfaceVGA (HD-15)
  • Input/Output connections3 x HDMI (19 pin HDMI Type A) - Rear,
    1 x HDMI (19 pin HDMI Type A) - Side,
    2 x Component video input (RCA phono x 3) - Rear,
    1 x Composite video/audio input (RCA phono x 3) - Side,
    2 x USB (4 pin USB Type A) - Side,
    1 x Ethernet (RJ-45) - Rear,
    2 x Audio line-in (RCA phono x 2) - Rear,
    1 x VGA input (15 pin HD D-Sub (HD-15)) - Rear
  • Video interfaceHDMI,
    Component,
    Composite
Jul 14, 2012 | Samsung PN50B650 50-Inch 1080p Plasma HDTV
Sceptre x23BV-naga 23" LCD HDTV needs a digital tuner replacement
just get a hd standalone tuner and hook it up to one of the inputs. way cheaper solution.
Apr 09, 2010 | Televison & Video
I have a yamaha receiver with HDMI outputs for direct tv, and a DVD player. How do I hook up the direct tv, HD DVD, and yamaha receiver? Where do the inputs go?
Does the Yamaha have HDMI inputs? Usually you would connect the directv and dvd player via individual HDMI cables to the Yamaha (input)and then the Yamaha (output) to your TV also via HDMI.
Dec 21, 2009 | Yamaha HTR-5640 Receiver
No hdmi input?
You can use the component inputs on your Tv which is almost as good.
Mar 30, 2009 | Panasonic PT-47WX51 47" Rear Projection...
Connect pc to hd tv
use a vga to dvi or a vga to vga connector lead from the back of your notebook, to the tv dependong on your tv connection inputs, although you will only get 720i not 1080i as you will need a notebook with an hdmi port for that resolution.
Dec 03, 2007 | HP Pavilion dv8000t Notebook
Upgraded DirectTV satelite TO HD
direct tv hd receiver is hdmi or rgb which is a different signal than the rgbhv input on the back of older mitsubishi tv . You can buy a converter that converts the format for about 90 dollars online. It converts rgb or component to vga/rgbhv
Oct 24, 2007 | Mitsubishi WS-55805 55" Rear Projection...
No Video
have you gone through the menu to assign which signals the receiver recognizes?  I had to change the source when i switched to the Dish Network HD receiver.
Aug 24, 2007 | Pioneer VSX-1016 Receiver
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
