Question about Garland ED-30SFT Deep Fryer
Boiling grease i have a dean gas deep fryer sr142gps it is two years old. out of the blue when it is idle it will start to boil out of control with the setting at 350.this does not happen at any certain time.
  • 30 Answers
When the issue starts have you actually checked the grease temperature? You can also checkto see if there is excessive grease build up on the themostat.Sometimes uncooked food particles can cause a boiling type motion in the fryer while they cook. be sure to do regular filterings of the grease,this will cut down on the suspended particles.If the grease temp is above 350, shut power off and check continuity on the thermostat,it could be sticking closed,in which case it will need to be replaced
Posted on Mar 07, 2009
What is the best way to get fryolators clean
Boiling out the fryer tank with the use of grease cutter will get rid of the soil that have build up on it. Make sure to refer with the boil out chemical guide for the right amount of solution and the right boil out temperature.
Feb 17, 2011 | Pitco Frialator SG18S Deep Fryer
How do i stop the grease from boiling over
Make sure there is no water in whatever you are placing in the grease....grease and water together equals bad boil over.... the water turns to steam rapidly and very bad things happen...
Oct 11, 2010 | Rival CF105 Deep Fryer
I have a Adcraft DF-6L and it was not cleaned as it should. The elements have a coating on them from the solids from frying. How is the best way to clean these without damaging them? Any help is greatly...
After cleaning fryers for 25 years, I always revert back to EasyOff oven cleaner. Be very careful when you try to scrub or scrape the elements. There are two thermostat cap tubes. If either one is damaged the fryer won't work. The cap tubes have a small charge of gas which expands and contracts to tell the thermostat when to come on and go off. You probably can't get them perfectly clean. Start by putting water in the fryer pan and letting it boil for a few minutes. Pour the water out and if it was really greasy, boil it again. When you have floated most of the grease that will melt away, then spray the elements with the EasyOff, or store brand oven cleaner. Let it stand for 30 minutes and then rewet the element and scrub carefully with a good stiff nylon bristle brush. A steel brush might damage the cap tubes. Rinse completely clean before using the fryer.
Sep 30, 2010 | Adcraft DF-6L/2 Deep Fryer
I need to know how to lite the pilot on my frymaster fryer
fry099_16_4.gifMake sure the thermostat is turned off. Units burners will light as soon a pilot in it is on. fry099_16_5.gif 3-2 Lighting the Pilot and Burner Figure 1 Figure 2 3. Push the knob in and light the pilot. Continue to hold the knob in for about 60 seconds after the flame appears on the pilot. Release the knob. The pilot should remain lit.
I suggest that you boil it out before using. This cleans the pot of any contaminants here is how to do this.
Boiling Out the frypot To ensure that the frypot is free of any contamination resulting from its manufacture, shipping, and handling during installation, the frypot must be boiled out before first use. Frymaster recommends boiling out the frypot each time the oil or shortening is changed. 1. Before lighting the burner, close the frypot drain valve and fill the frypot with a mixture of cold water and boil-out solution or detergent. Fill to the lower oil-level line. 2. Light the fryer in accordance with the lighting instructions in Section 3.1. 3. Simmer the solution for one hour.
I would attempt to paste the complete owners manual but it's just way to large. I do warranty for Frymaster is how I have access to it. Good luck
Oct 17, 2009 | Frymaster Dean GF14 Deep Fryer
I have two dean sr142gps fryers and am looking for an owners manual. I want to know how to adjust the flame onthe burners.
The only way to adjust the flame is by changing the orfices on the burner tube manifold. Dean is owned by Frymaster & you can contact their technical Dept @800-551-8633
Jul 19, 2009 | Kitchen Appliances - Others
We have a dean deep fryer model SR42GNS on start it makes a big boom and a large blue flame comes out of stack on top?
is the fryer propane or natrual gas?It sounds like the orfices,burners or baffles may be clogged and needs cleaning.let me know.
Apr 08, 2009 | Frymaster Dean 2424G Deep Fryer
I usually boil water in mine to clean it out. I let it boil for one full timer. To clean the outside I just use Windex and some elbow grease. Hopes this helps.
Mar 18, 2009 | Rival CW400 Chef's Fry Cool Touch Deep...
What soap product can be used in boiling and cleaning the fryer pots?
Hello, I would suggest you use a product meant to be used in a fryer, there are many, MR Muscle has one, try a google search for "fryer boil out", a big list will pop up, and you can order what suits you best online at most places.
Hope this helped, and thank you.
Mar 07, 2009 | Frymaster Dean Kitchen Appliances - Others
DEAN SR142GPS Flame Issue
A gas valve is actually 2 valves in one. The first is your pilot valve, when the pilot is lit, the flame heats a thermocouple or thermopile & that heat produces a millivolt signal that is sent to main gas valve( second part) & tells it that pilot is established and to open to allow main burners to light. The 3 "little flames" were coming from the orfices on the burner manifold. If you are absolutely sure you put the gas valve back in the same direction as it came out (arrow on bottom of valve pointing to the fryer/burners) & any springs or adjustment screws were not mucked with, then there is a malfunction in the gas valve. It needs to be replaced.
Jul 24, 2008 | Kitchen Appliances - Others
Wells 35lbs fryer double vat
This sounds to me as if your thermostat is not cycling the unit off. But I can see a second problem as well there should be a high limit cutoff to prevent it from running on and boiling over. I would check both. The thermostat is the dial or knob to regulate temperature and the high limit is the safty to prevent boil over or run on.
Mar 29, 2008 | Wells F-686 Deep Fryer
Garland ED-30SFT Deep Fryer Logo
178 people viewed this question
Top Garland Kitchen Appliances - Others Experts
Paul Carew
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Garland Kitchen Appliances - Other Expert? Answer questions, earn points and help others
