Question about Dell Optiplex GX280 (99301) Motherboard
DELL OPTIPLES GX280 (E219542) MOBO, MID TOWER
Hi.
got this with 2x512 ram. Tried to upgrade to 2 GB PC-2 4200 533 mhz
which dell says is compatable. i tried to install this chip in every slot but all i get is several long beeps do you know what the problem is?
  • 38 Answers
Several long beeps means there is a problem with the memory. First of all make sure the memory is seated in the slot perfectly. There should be no movement whatsoever when you gently try to rock it side to side. If it still persists the bad news is the memory is most likely shorted out or defective. They are VERY sensitive to static electricity. I would go ahead and put the old memory back in for now and send the new defective memory back. Most vendors will issue you a replacement free of charge if you let them know it's not working.
Hope this helps!
Posted on Mar 05, 2009
  • 52 Answers
This is what you need to check. No matter what Dell says. Make sure that the old ram and new ram are the same speed. If the old ram is not PC-2 4200, than you need to get the same type for the upgrade. If this is correct, and you have matched them, old and new, than take your new ram, PC-2 4200, and exchange it for PC-2 5300. This will solve your problem. Some motherboards don't like certain kinds of memory. Mine came with PC-2 4200, and i tried to upgrade, it did not work. I had to go to PC-2 6400 to make it work. Also make sure the new ram is seated in it's slots. And the tips, on the ram ports, are locked onto the ram. Good luck.
    Genius:
  • 1,605 Answers
Yo have the corect memories chips. However, you have to isntall them in pair.
if the machine still give you the error beep code, then either you have the wron g memories, or one of the chip is bad. have them tested.
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Paulji786,
Below are the specs you requested on these 2 systems.
Optiplex GX280
Memory
Type
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
F0000h
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
Dell GX280 orange light on MOBO
Dell Support > Optiplex GX280 Desktop PC > User Manual,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tindex.htm
I chose the Mini-Tower model because the following information applies to all models;
Small Form Factor (SFF)
Small Desktop
Desktop
Small Mini-Tower
Mini-Tower
Computer and Software Problems > Troubleshooting Tools and Utilities > System Lights,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tools02.htm#wp1114432
Now scroll down. What do the Diagnostic Lights indicate?
Post back in a Comment.
Regards,
joecoolvette
Oct 09, 2012 | Dell OptiPlex GX280 PC Desktop
I want to upgrade my power supply for the dell gx280 small desktop
Sorry to say that a 260w PSU is the largest PSU you will get for this system as that is all the M/B is safely rated to any higher than that and it may cause a fire or worse. I run a Dell GX270 and this is maxed out on a 260w PSU. This system will only be upgradeable to these specs :
3.2Ghz CPU ( Note they must match existing letters on CPU.
3Gb Ram under XP, 4 Gb under Vista or Win 7. ( Note win 7 will run very slowly )
256Mb PCI Card or 512Mb AGP (4X or 8X )
500Gb IDE or SATA HDD
DVD Burner max ( Blu-Ray will not work as it is too advanced ).
Even the tower model of these systems only have a 260w PSU max due to limited power rating for the M/B. Tower PSU is able to be swapped out just like any other tower but the fact remains that the M/B is only rated to 260w and if you use a larger PSU it may cause a fire or worse. I hope this helps.
Sep 05, 2012 | Dell OptiPlex GX280 PC Desktop
Issues with 2gb 32ddr dell memory compatible in dell gx280
Unfortunately, the CPU on these computers may be capable of handling the 2GB memory, the motherboard isn't on either system.
The specs for the Dell GX280 are available here: http://support.dell.com/support/edocs/systems/opgx280/en/ug/specs02.htm . This system takes 400 or 533 MHz DDR2 non-ECC memory and the form-factor determines the maximum memory. In the mini-tower format, you have 4 DIMM slots and can have 4 GB of memory. In the small form factor, it takes 2 GB max.
The Dell E310 specs are available here: http://support.dell.com/support/edocs/systems/dim3100/en/sm/specs0.htm . This system can only support 2 GB (2 x 1 GB) memory.
I wish that I had better news for you.
(who had a similar Pentium 4 computer with the 1 GB limit. Since that system was running a 32-bit system and only actively addressed 3 GB, I didn't try to put 2 GB sticks in any of the 4 memory slots.)
Aug 30, 2012 | Dell Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
How much RAM can my MOBO take?
The laptop has 2 memory banks. Each bank will support 1GB 400Mhz, so maximum memory the motherboard supports is 2GB.
Regards.
Mar 11, 2010 | Dell Inspiron 1501 Notebook
Dell inspiron 5160 2 GB Ram I am using Vista Sp-2 on this laptop computer.Is there a newer and different graphics card upgrade for this system. It has a 3.20 Mhz Pentimum 4 procesor. The problem is the the...
If you plan to change the graphics card, then go in for a card that has a lot of dedicated RAM. Not shared. You may be able to do with 2 GB RAM on your PC. Ask the dealer specifically.
Aug 06, 2009 | Dell Inspiron 5160 32MB DDR AGP Graphic...
Dell gx280 memory
It sounds like the memory is the wrong type. you should get SDRAM-DDR2 at 667 MHZ. pc2-5300.
Jan 24, 2009 | Dell Optiplex GX280 (99301) Motherboard
Computers & Internet Logo
2,001 people viewed this question
Alun Cox
