Toshiba M70 CD rom not working - Computers & Internet
Toshiba m70-340 cd windows recovery
If you do not have a recovery disk, contact Toshiba for one
Jul 16, 2013 | Computers & Internet
Download Wi Fi softoyer for toshiba m70-340
Go to Toshiba support website to download all drivers for your operating system
Feb 05, 2013 | Toshiba Computers & Internet
Sound card not working after new installation of Win XP on my Toshiba Satellite M70-340
Hi!
All you have to do is to install the sound/ Audio Drivers
Satellite M70-340 Sound Drivers WIN XP
Click the above link and download the Sound Drivers for Windows XP.
It is a zip file. Open the file and Install the required Drivers
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Toshiba Satellite P105-S6024 Notebook
Good Day: I am new hear. Can you help me to solve my problem in my laptop Satellite M70-289, my keyboard is not working.Only two keys is good N and B only
you need to place new keyboard
you can buy keyboard at toshiba center
the other way is place usb keyboard as external keyboard
Mar 22, 2011 | Toshiba Satellite M70 Keyboard
Were to get a toshiba cd-rom
I searched for Toshiba CD-ROM drives and found only support references to products made about ten years ago. Toshiba shows only hard drives on its storage device products page. I could be wrong, but it appears Toshiba is not in the CD/ROM drive business anymore.
Is there a particular reason you must have a Toshiba brand CD-ROM? Any CD-ROM with the same interface type should work, if you can find a driver compatible with your operating system. If I recall correctly, Toshiba uses Sony optical drives in its laptop computers. (So far as I know Toshiba always used standard interfaces, so a proprietary drive should not be an issue.) The prices on CD-R and CD- R/W devices have come down considerably in the last several years, so you may want to consider one of those if your computer is fast enough to support reliable disc burning operations (800 MHz or better should suffice).
Dec 12, 2010 | Toshiba Computers & Internet
Bios does not detect cd rom drives, the cd rom drives has power but it does not work cause bios its not detecting it and it a new drive, my toshiba satellite is a85-s107 let me know if u can fix it.
I have a Toshiba Satellite L355D that would not detect the CD Rom in the BIOS although the Rom appeared to powered up and running. I traced the problem to a ribbon cable connector that was between the jack the CD Rom plugged into and the jack on the mother board. The ribbon cable plug at the MB had backed out and was only making the power connections to the Rom making the Rom appear to be operating.
Dec 05, 2010 | Toshiba Satellite A85-S107 Notebook
My keys I, O and - does not work anymore. My Model is M70-267.
Telephone Toshiba, and order a replacement keyboard,
and ask them for the Toshiba Authorized Service Depot that is nearest to you. Take the keyboard & computer to that Depot, and pay them to correctly & safely change the keyboard.
Aug 20, 2010 | Toshiba Satellite M70 Keyboard
My toshiba satellite m70-cl3 showing fatal error and shut down, I didn't have recovery CD. I wanna recovery of my system.
Hi sanjaykvscnb, you can call toshiba tech support at 1-800-457-7777 for a recovery cd request. They are open 24/7.
Hope this help...
May 08, 2010 | Computers & Internet
Toshiba Satellite M70 FN key lock
See if F10 or F11 are lit. If so press Fn and the key that has a light below it to deactivate it.
If you cannot login, use a USB keyboard to bypass that hurdle and run Windows to reconfigure.
Hope it helps.
Sep 13, 2009 | Toshiba Satellite M70 Keyboard
I have a Toshiba M70 laptop. I want to revert to the factory settings and re-install Window XP. The Product recovery DVD ROM does not run any program but just has a large file that Windows does not...
you should be able to boot to that disk and begin the reinstall process. just put the disk in, reboot, and watch the boot process to give you a prompt similar to "press any key to boot from CD..."
That should start you install.
Jul 11, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
130 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
