Zanussi aquacycle 1200 interlock problem BIMETAL STRIP?
When machine switched on, orange light on door on, door wont open ,sound from door clicks four times.
start/pause button light flashes but will not start any cycle.skip through a cycle but orange light on door remains on but will not open.- from what ive read it sounds like an interlock problem.
before i buy a new interlock could someone explain to me where where the bi metal strip is , if indeed the zanussi aquacycle 1200 is of that type?
i want to check to see if it has overheated by checking to see if the plastic casing is slightly discoloured.
many thanks
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Turn on my jet system 1200 fj 1254w xc just makes clicking sound
Obviously appeared family error code E40 (visible to the customer) what means a problem with door interlock. Could be: door open (mechanical failure), door interlock malfunction, the problem with main PCB (triac) or wiring. In service mode you can see exactly error code: E41,E42,E43,E44 or E45.
Dado
Jun 07, 2015 | Zanussi Washing Machines
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
Jun 28, 2011 | Zanussi Washing Machines
I have a lg wm3677hw washer dryer combo. the door lock has been acting odd. so i figured i would replace the door interlock. after replacing the interlock the door will not unlock. i hear it make 3...
  • Hi Chris,
    This is late for you, and probably you've done something already --- but.
    The door lock is easily replaced. It works with a little heater inside it that is supposed to delay the unlocking by pushing on a tiny lever that prevents the lock from sliding to unlock.
    The washer runs power through a resistor when the door is locked, and this heat keeps the bimetal strip (like in a thermostat for aquarium heater etc) bent, preventing the door from unlocking. When the washer turns off, the power to the heater/resistor is shut off, an when it cools off in a few moments, the bimetal strip relaxes and pulls the tiny lever out of the way.
    I expect there is a problem with the position or the flex of the bitmetal strip.
    If you don't have another switch handy right now, you can TEST the functionality by simply jumpering the two wires on the connector. This will bypass the lock altogether, but the latch will still work. When TESTING be careful not to let the door come open because at high speed that drum could grievously injure someone.
    ~scirocco
Bimetallic strip
How washing machine door lock works how to test interlocks
Sep 19, 2017 | LG WM-3677HW Front Load Washer / Dryer
Zanussi electolux aquacycle 1200 w/mc wont spin
Try new bushes and make sure where bushes run is clean and free from carbon H
Jan 09, 2010 | Electrolux Washing Machines
Zanussi aquacycle 1200 washing machine
The Timer/ECU is likely failed in this instance.
Jan 16, 2009 | Washing Machines
My zanussi Aquacycle 1100 wont start. A clicking noise starts after I try and start a wash. I heard it could be a door interlock that requires replacing. Is this easy to replace?
door interlock is easy to replace.
undo the plastic clamp that holds door gasket to cabinet. peel back in area of door lock. door lock is held by 2 screws on outside. undo these ans lock comes off. there may also be a small diameter hose as well to door lock which take off as well.
reassembly is just the reverse
Jun 30, 2008 | Washing Machines
Zanussi FX 1265 W, Aquacycle 1200 Door Problem, won't lock.
take a look at this link.
I have found that a lot of front loaders use the same control board manufacturer with the same solder failure issue.
try the section where you pull up on the white connecter with black wires as it is the easiest to verify the issue
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Feb 02, 2008 | Washing Machines
Door wont open
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Dec 23, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Aug 01, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
274 people viewed this question
Top Washing Machines Experts
