Question about Saeco Aroma - Stainless-Steel
Saeco portafilter instructions - Saeco Aroma - Stainless-Steel
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
When using ground coffee, use coarser grind like the size of table salt grain. Feel the ground coffee for adjustment. Do not tamp, just level the cup with coffee grounds and lock the portafilter into the group ring. Pull the handle all the way to the right and hold. Turn espresso hot water switch on. Hold the portafilter pulled all the way to the right for 5 seconds (pre-infusion pressure builds up to 9 bars). Release the handle at the end of 5 seconds. Espresso shots should be max. 2-Oz. in the cup. For larger quantity, use two shots. For an Americano, add hot water instead of allowing 8-Oz. water to pump through the coffee grounds.
Posted on Jul 07, 2009
We have broken the handle on pressurized portafilter for Saeco Via Venezia espresso machine. where can we get replacement?
I don't think the handle is sold separately. Seattlecoffeegear does sells both a bottomless and an unpressurised portafilter for the Via Venezia. Both would be considered upgraded gear vs the pressurized one.
Jan 30, 2013 | Saeco VIA Venezia
Broken portafilter!
I had a brand new Via Venezia that I could barely get to make espesso, nothing or very little came out. Got a new portafilter and now it work beautifully, espesso flies out of the thing wonderfully. Bad news is a new portafilter is like $65. I can't believe they are shipping these with bad portafilters, but they are.
Dec 18, 2009 | Saeco VIA Venezia
Need portafilter plastic support peg
This merchant carries Saeco/Gaggia parts. You may have to get the disc and peg as a set. Part number/description is: "GG1038/01/A Crema disc for portafilter. Use with 2-cup basket"
Merchant site is here:
http://www.saecoparts.com/StarbucksSirenaespresso.html
The item is on the 3d row, 4th column
Nov 16, 2009 | Saeco Starbucks Sirena Espresso Machine
Replacing orange gasket in top or portafilter
here is a picf920683.png of the portafilter for the saeco
May 09, 2009 | Saeco VIA Venezia
Saeco pressurized portafilter gets stuck in the locked position
No, no... He has a Saeco pressurized portafilter which has a valve that will not allow coffee through when the portafilter handle is pushed all the way to the right. His handle is locking in the rightmost position; this is not a grounds problem.
mjtourig: Can you not just nudge the handle to the left before you pull a shot to unlock it? If it is too clogged for that, try taking your portafilter apart to clean it. You'll have to remove the 3 screws on the bottom, and be very careful the entire time that you do not lose any of the parts (in particular, there is a spring under one of the screws that will want to pop out, and a tiny white plastic thing under that spring...). Good luck!
Mar 29, 2009 | Saeco VIA Venezia
Makeing coffee
No, these machines use a pressurized portafilter to make brewing espresso easier. Be sure your coffee is ground about the fineness of table salt. Just level the coffee in the filter and insert the filter as instructed.
Mar 08, 2009 | Saeco VIA Venezia
Coffee not pouring through portafilter
if your grounds are tamped down too tight, the steam can't get through it.
Dec 30, 2008 | Saeco VIA Venezia
Leaking saeco (barista starbuck) portafilter
The boiler and the portafiltre both are bolted together at the same time, otherwise the spacing is wrong. Took me a long time to figure it put...
Nov 24, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Saeco Aroma - Stainless-Steel Logo
321 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
